federicodrdpro
Drives: White Polo 6R TDI
Post by federicodrdpro »
Ciclo, is possible to update all clusters with VCP? https://www.youtube.com/watch?v=qoa3X9OW1v4
A VW Amarok 2H0920871B HW H03 SW1005 14/01/2015 is compatible with HBA and other retrofit?
Which is the difference between mirror 3G0 857 511 AE and 7E0 857 511 G :?:
1- I don't know if VCP can update all IC softwares. I suppose not.
2- Yes, it's compatible with Direct TPMS, HBA, etc...
3-
3G0 857 511 AE ... for MQB platform.
7E0 857 511 G... for PQ25 platform.
federicodrdpro
Ok thanks, and 3G0 857 511 АС is compatible? :? https://www.uk-polos.net/viewtopic.php? ... 60#p524658
Yes, because it does not have the function/camera for HBA.
Example https://www.drive2.ru/o/b/486212564091404685/
lukafoto
Drives: A2 Polo 6R conversion !
Post by lukafoto »
iichel wrote: Fri Aug 11, 2017 7:27 am Since he already has the 6R wiring loom, I guess it's simply a matter of placing a compatible 6R ABS unit and code it.
The A2 is based on the (9N3) Polo platform but the electronics are all 6R. I guess a 6R ABS or ESP unit would be best, since it can communicate with the CAN network.
I have a 6R ESP 9.0i unit for sale, maybe it's something for you. I guess a ABS8.2 or ESP 8.2i would also work. R
emember that you'll need a vagcom/vcds to make it work, every abs or ESP pump needs a unique coding based on many parameters. We can aid you with this of course.
That's great thankyou!
I just managed to get the original key to be recognised by the ECU and so no more immobiliser trouble!
I ordered an ABS unit locally but it turned out to be 6R0 907 379R instead of the correct 6R0 907 379AF .
Also VAGCOM error codes suggest I need HVAC and Airbag controllers connected.
federicodrdpro
Ciclo, how is possible to update the IC SW? Is there a tutorial or same? Where? :lol:
My IC SW is 0251 and I am thinking to update it to 0256. (Staging and...?) :?
I updated my old BlueGT IC with original VCP.
Tutorial? Connects with IC, Select the file with the right software and click on flash button...
I don't know if it's necessary to previously enter some access code. I didn't do it.
I have to warn that I did this because I already had the new GTI IC. Precondition to me to do it.
My only intention to update the software in my old BlueGT IC was to discover the truth about Direct TPMS and its compatibility with our PQ25 platform on 6R, T5.2, etc... (based on previous assumptions) :lol:
New Autoscan (nothing new)
Thursday,04,January,2018,13:14:08:06516
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.8.1.0
Data version: 20171130 DS276.6
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: Reversing Light as LED (under test)
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 65 77 0B
VIN: WVWZZZ6RZDY0CICLO   Mileage: 29190km-18137miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 5466
   Revision: --H10---    Serial number: 00000000000000
   Coding: 001100D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
   ROD: EV_ECM12TFS02103F906070FP.rod
   VCID: 6A2772FCC7D047D895-803E
Readiness: 0110 0101
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D300401700
   Shop #: WSC 40308 002 104857
   VCID: 02BF42B42BD8B78055-8056
   Serial number: 08021613470174
   Coding: 01
   ROD: EV_LWSKLOVW25X_VW25.rod
   VCID: 7E334A383734DF6C35-802A
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 38E9DE5607D6737AE5-806C
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 122170091
   Coding: 3CB02FBF48E32400B3380F916CEB9FDCDAC0672F600D30D0200000130800
   VCID: 2BE4F431F397CDA19D-807E
   Component: RLHS 220816 0  42  0106
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU003041440937042
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU006031440656541
   Coding: 1000AB
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 7 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H03 0103
   Serial number: 27140003142720054516
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU003051200017821
   Coding: 18BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU010051200012315
   Coding: 18BC32
Address 10: Park/Steer Assist (J446)       Labels:| 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361212601014
   Coding: 308001
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3EF3CA7837F45F2C35-806A
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01JKVVP
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   VCID: 4A07B29C473007F895-801E
   Serial number: 3575HRB405N1C4LI7929
   Serial number: 358
   Serial number: 3515RRB405B17ABS901.
   Serial number: 3525RRB405B181TUDPKC
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 6RD 920 870 A    HW: 6RD 920 870 A
   Component: KOMBI         H04 0805
   Coding: 140E01
   Shop #: WSC 00233 572 00000
   VCID: 47F8BC854B0315ED7D-8012
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 002200
   VCID: 68197EE6C7A653CA65-803C
Address 20: High Beam Assist. (J844)       Labels:. 8S0-857-511.clb
   Revision: AA001001
   Coding: 0404001C00000000000000
   Shop #: WSC 03607 002 104857
   ROD: N/A
   VCID: 2EE3EA48F784BFBCB5-807A
No ASAM data for: "EV_HighBeamAssisAU316" (VW25)
   Component: IMMO          H04 0805
   Shop #: WSC 00000 000 00000
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 010100
   VCID: 2AE7F23CCF90C79895-807E
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 C
   Component: RNS-MID       H06 5274
   Revision: AB001001    Serial number: VWZ6Z7L7654213
   Coding: 04000442040000A10001
   Shop #: WSC 12345 123 12345
   VCID: 37E8DC5503D3757DFD-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V15  8515
   Part No: 6R0 423 156 B
   Coding: 11221
   Shop #: WSC 00788
   VCID: 2FE0EC4D77BBA545BD-807A
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   VCID: 77285C150B13F5BDFD-8022
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
   Serial number: 40000000050821
   ROD: EV_RDKBERU30.rod
   VCID: 37E8DC550BD3757DFD-8062
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664158506
   Coding: 0501000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3BF4D4613BC76D111D-806E
End-------------------------(Elapsed Time: 04:21)--------------------------
Jay-Jay
Drives: Polo 6R HL 1.2TSI 77kw, Audi S1 MY2018
Post by Jay-Jay »
ciclo wrote: [...] Connects with IC, Select the file with the right software and click on flash button...
What do you mean with "select the file with the right software"?
Does VCP already have IC updates in it OR is there another software which let you download the IC updates?
I would like to update my GTI IC. This is from my last Autoscan:
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 870 A HW: 6R0 920 870 A
Component: KOMBI H03 0505
Coding: 140A01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
VCID: 336F6E689A2E776
VCP is the tool. The files with the original/right software, which nobody should have except VW and customers who paid for them, must be found on the Net.
Some of them are really hard to find, especially the one you are looking for.
I cann't provide you with these files, they are not my property ... I am truly sorry. Please do not ask me about them, my answer will always be not. (I don't have permission to share them)
In any case, I recommend buying a new IC, just like I did.
edit:
Hmm... on the other hand, you can contact spacewalker (for example) and I'm sure he can update the software of your IC to the best software version possible at a very reasonable price.
Jay-Jay
Post by Jay-Jay »
Thank you for the info, ciclo! :)
You can be sure that it is the best info I can give you. :)
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
Hi ciclo, not sure ive asked before or not and this is out of topic abit, but do u know how exactly or maybe Why errors/faults read by vcds will not have the right Date/Time eventho the mileage data is correct? do you know how to solve this?
Don't know, I think that in the Ross-tech forum you will find the answer. I'm sorry I can't help you in this issue.
Bobytp
Drives: GT
Post by Bobytp »
Hi Ciclo,
Amazing list of modifications. I have been trying to code mirror folding while locking on Key fob on my Polo 1.2 DSG 6R model. While accessing J386 and J387 modules VCDS shows 000000, control module not codded.
I played around with settings on J386 module as trial and error and got into a bit of problem with front power windows (on the driver side switch controls the left front window switch now controls the right front window and right front window switch now controls the left front window) and the folding mirrors (Mirror folds close in L-0-R positions and opens when in the earlier close position). Any leads would be much appreciated. :(
Hi, welcome
Put the original coding of each door, look in the Debug folder of VCDS program for the changes you made.
Locked
