Page 28 of 32
Posted: Sat Jan 22, 2022 9:10 pm
by Mattypologti6r14
Any part number for a shark fin antenna with fm and dab?? thanks
Posted: Sat Jan 22, 2022 9:24 pm
by iichel
That does not exist.
Posted: Sat Feb 12, 2022 3:11 pm
by amer6R
I've bought a rear caliper rebuild kit with pistons. Some kits come with brass bushing, and some kits do not come. Does someone where does this brass part goes?
- IMG-298914e900eee9f493f37294854657cf-V.jpg (2.59 MiB) Viewed 35219 times
Edit, I have confirmed my thougts.
- d82a3d8s-960.jpg (115 KiB) Viewed 35200 times
just buy new callipers, the circlip that holds the parking brake mechanism is a nightmare to install and remove.
also, do not wire brush the part where the bajno golt goes. Do not or it will leak. I will try today to sand it flush and try it that way. If it doesnt work hoses and new callipers
the first calliper was a nightmare it took me 2h for the circlip.
The second one i dismanteld in 15 minutes, but guess what the piston wouldnt wind in witouth force from the top. So again i dismanteld it 8 times to re check everything. And i managed to slide the piston in and it was pushing out slowly applying the handbrake mechanisam. the issue was that circlip.
It took me 8 bloody hrs for 2 callipers, and i think my steel wire wheel strached the part where thencrush washer goes. So i got a leak thanks god for pressure bleeder.
really bad desing the shaft from behind was completly rusted, and water gets in from thenbackside. Nice money maker desing.
If i was to do it again id just buy new callipers.
Posted: Tue Mar 01, 2022 5:54 pm
by iAkos
Mart!n-GTI-DK wrote: Mon Nov 04, 2013 3:08 pm
A list of special Polo R WRC parts:
Front Bumper:
6R0 807 217 AF AWA - (Comes paintet Candy White from the factory)
Cover for towing eye:
6R0 807 241 E AWA - (Comes paintet Candy White from the factory)
Middle grill:
6R0 853 677 F 041
Cover Left:
6R0 854 661 BUS
Cover Right:
6R0 854 662 BUS
Cover cap for sprinkler Left:
6R0 955 109 D GRU
Cover cap for sprinkler Right:
6R0 955 110 D GRU
Retainer for spoiler:
6R0 805 915 H 9B9
I'm not sure if any bracket pieces are needed underneath the bumper... But it doesn't look like it...
All gloss black R WRC front grill:
6R0 853 651 AC 041
Gloss black diffuser (GTI/BlueGT/R WRC):
6R6 807 568 N 041
Gloss black towing eye cover rear (GTI/BlueGT/R WRC):
6R6 807 441 A 041
Hello! Im new here. Can i get some help?
Ive got european polo 6r 1.4 86hp 2010 and i want to upgrade my front bumper to a WRC one. Is
6R0 807 217 AF AWA compatible with my polo? Ive got fog lights also but there is a solution for fog lights ? Or it must be taken out?
Thanks for your help!:)
Posted: Tue Mar 01, 2022 6:18 pm
by iichel
Polo 6R R WRC bumper does not support foglights, unless you do mods with aftermarket/custom LEDS.
Posted: Tue Mar 01, 2022 10:46 pm
by iAkos
Thanks. All 6R WRC front bumper compatible with all 6R polos ?
Posted: Wed Mar 02, 2022 7:24 am
by iichel
All polo 6r and 6c yes
Posted: Sat Mar 05, 2022 9:45 pm
by vieri69
hello what is this Grey piece number ? Central pillar B
Posted: Sat Mar 05, 2022 10:16 pm
by iichel
The easiest way is to take it out. The part number is written on it.
Posted: Sat Mar 05, 2022 10:28 pm
by vieri69
iichel wrote: Sat Mar 05, 2022 10:16 pm
You know how i do this ?
by vieri69
Posted: Wed Mar 16, 2022 11:09 am
by iAkos
iichel wrote: Wed Mar 02, 2022 7:24 am
Hello!
The stock cover caps for sprinkler are compatible with wrc bumper?
Posted: Mon Mar 21, 2022 1:05 pm
by amer6R
Are there any documentation on KFK transmission short shifter mods ? Something like people were doing on 1.9 TDI relocating the pin? Did anyone do it?
Or if someone has one can you take the picture with a ruler next to so I could see if modding the stock one is possible?
Edit: Never mind, i Think I have figured it out. Will check tomorrow on the car to see if its possible.
Edit its possible.
Posted: Thu May 12, 2022 9:52 am
by amer6R
If anyone is in doubt:
Blueprint solid mass flywheel clutch set conversion from mk4 1.9 tdi (5sp) will fit on 1.6 TDI and most importantly will hold torque of 1549 turbo ~180hp.
Warning: the clutch material is soft-ish it's not for hard launches from standstill ( will wear out quickly)
Valeo solid mass conversion holding 240hp on 1.9 tdi no isssues
Posted: Mon May 16, 2022 8:37 pm
by Noiseprojekt
Does anyone know if these exist that fits with the R-line rear spoiler?
The ones i bought only fits the regular small spoiler
