Nem87
Drives: skoda yeti
Re: iichels Polo 6R 1.2TDI Bluemotion --> OEM++ R-Line conversion
Post by Nem87 »
ciclo wrote: Tue Oct 09, 2018 6:02 am The important thing is the hardware 5Q0 907 273, the software 3AA 907 273 can be flashed to the F version in all those previously mentioned ...
To flash it's necessary to have original VCP and the original flash file.
Image F version
F is the version that works in/with our MFD/A Instrument Cluster, from 0705 software onwards.
Tested.
I can't share these flash files. Maybe others can do it.
It's a luxury to check the tire pressures in real time while driving , especially after going through a gigantic bump (bad roads) in which it gives the impression of having broken the tire.
Hello friend! Could you please help me find this flash? I recently bought an antenna from Poland, they said that it's already flashed in 3AA 907 273 F but it's not.
I need help!
Hello friend, welcome, could you please post a complete autoscan from your Skoda Yeti with that TPM unit installed?
I need to check it out.
If possible, take a picture of that TPM unit and post it here.
Nem87
Drives: skoda yeti
Post by Nem87 »
Sorry but I'm using Russian version of VCDS and it saves autoscan in Russian language.
https://yadi.sk/i/N4d_rtDb5PtdWA
 Friday,25,January,2019,19:57:36:10463
ВАСЯ -- программа для диагностики автомобилей концерна VAG запущена на Windows XP x86
ВАСЯ Версия: 16.9.4.3
Версия 16.9.0: 20160919 DS256
Мастерская:
Код мастерской: 011 01357 000200
VIN: XW8LB65L8GHхххххх   Номерной знак:
Пробег: 16160km-10041mi   Номер заказ-наряда: Skoda Yeti
Шасси: 5L (7N0)
Список: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 52 5F 62 65 72
VIN: XW8LB65L8GHхххххх   Пробег: 16160km-10041miles
01- Электроника двигателя -- Статус: OK 0000
02- Электроника КП -- Статус: OK 0000
03- Электроника тормозной системы -- Статус: OK 0000
04- Датчик угла поворота рулевого колеса -- Статус: OK 0000
08- Электроника кондиционера / отопителя -- Статус: OK 0000
09- Блок управления бортовой сети -- Статус: OK 0000
10- Парковочный ассистент II -- Статус: OK 0000
15- Подушки безопасности -- Статус: OK 0000
16- Электроника рулевой колонки -- Статус: OK 0000
17- Комбинация приборов -- Статус: OK 0000
19- Диагностический интерфейс шин данных -- Статус: OK 0000
22- Электроника полного привода -- Статус: OK 0000
25- Иммобилайзер -- Статус: OK 0000
42- Электроника двери водителя -- Статус: OK 0000
44- Усилитель руля -- Статус: OK 0000
46- Центральный модуль систем комфорта -- Статус: OK 0000
52- Электроника двери переднего пассажира -- Статус: OK 0000
5F- Электроника информирования -- Статус: OK 0000
62- Электроника задней левой двери -- Статус: OK 0000
65- Система контроля давления в шинах -- Статус: OK 0000
72- Электроника задней правой двери -- Статус: OK 0000
Адрес 01:  Электроника двигателя (CDA)       Label: 06J-907-115-CDA.clb
   Part No SW: 5L0 907 115 G    HW: 1Z0 907 115 F
   Компонент: 1.8l R4/4V TFSI     0010
   Ревизия: AAH18---    Серийный номер:
   Кодировка: 0203000C1C0F0160
   Мастерская #: WSC 33361 790 00003
   VCID: 2F66EFA5BE35933985-807A
Неисправности не найдены.
Готовность: 0000 0000
Адрес 02:  Электроника КП        Label: 02E-927-770.clb
   Part No SW: 02E 300 016 F    HW: 02E 927 770 AL
   Компонент: GSG DSG AG6     531 4013
   Ревизия: 06253104    Серийный номер: 00001510150446
   Кодировка: 0000020
   VCID: 1736374526A57BF9FD-8042
Адрес 03:  Электроника тормозной системы (J104)       Label: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 CB    HW: 1K0 907 379 CB
   Компонент: ESP MK60EC1   H46 0174
   Ревизия: 00H46001
   Кодировка: 913F400E092201FD890B02E7901E8049A0000020
   Мастерская #: WSC 33361 790 00031
   VCID: 74EC20C9D793F0E138-8020
Адрес 08:  Электроника кондиционера / отопителя (J255)       Label: 5K0-907-044.clb
   Part No SW: 3T0 907 044 CJ    HW: 3T0 907 044 CJ
   Компонент: Climatronic   H19 0709
   Ревизия: 00001009
   Кодировка: 0010000002
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_SK12.rod
   VCID: 7CFC08E9F7C3B8A170-8028
Адрес 09:  Блок управления бортовой сети (J519)       Label: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 086 AD    HW: 1K0 937 086 AD
   Компонент: BCM PQ35  M   112 0903
   Ревизия: AC112903
   Кодировка: 66000ABCA00518C4400800C0510081EC4B7000AE526D8F60E48140000040
   VCID: 72E026D1AD87FED12A-8026
   Подсистема 1 - Part No: 5L1 955 119 B  Label: 1KX-955-119.CLB
   Компонент: SK356  26  0610
   Кодировка: 00F7B5
   Подсистема 2 - Part No: 5K7 955 559 B  Label: 5K7-955-559.CLB
   Компонент: RLS 260515 03  37  0059
   Кодировка: 02085D
Адрес 10:  Парковочный ассистент II (J446)       Label: 1Z0-919-475-V2.clb
   Part No SW: 1Z0 919 475 G    HW: 7N0 919 475
   Компонент: PARKHILFE 8K  H06 0011
   Ревизия: --H06---    Серийный номер: 28231518902539
   Кодировка: 108107
   ASAM Dataset: EV_EPHVA18SKxxx0000 002001
   ROD: EV_EPHVA18SKxxx0000.rod
   VCID: 458AAD0DC48939695F-8010
Адрес 15:  Подушки безопасности (J234)       Label: 5K0-959-655.clb
   Part No SW: 5C0 959 655 C    HW: 5C0 959 655 C
   Компонент: AirbagVW10    014 0613
   Серийный номер: 003G6RAEHFT8
   Кодировка: 00005451
   Мастерская #: WSC 73430 790 00999
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3260E6D16507BED1EA-8066
   Датчик удара боковой подушки безопасности водителя:
   Подсистема 1 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Компонент: S.Sens.Fahr.V  H02 ----
   Серийный номер: 3572MSME37596B53ZZZ%
   Датчик удара боковой подушки безопасности переднего пассажира:
   Подсистема 2 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Компонент: S.Sens.Beif.V  H02 ----
   Серийный номер: 3582MSME6A6B2C54ZZZ7
   Датчик удара задней боковой подушки безопасности со стороны ВОД:
   Подсистема 3 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Компонент: S.Sens.Fahr.H  H02 ----
   Серийный номер: 3516KSME55035C38ZZZU
   Датчик удара задней боковой подушки безопасности со стороны ПП:
   Подсистема 4 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Компонент: S.Sens.Beif.H  H02 ----
   Серийный номер: 3526KSME7A255C38ZZZ%
Адрес 16:  Электроника рулевой колонки (J527)       Label: 5K0-953-569.clb
   Part No SW: 5K0 953 521 FL    HW: 5K0 953 569 BD
   Компонент: LENKS.MODUL   018 0230
   Ревизия: FF010042    Серийный номер: 20150918201592
   Кодировка: 1882140000
   ASAM Dataset: EV_SMLSNGVOLWSR8C 001001
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 7BFE0BF5F2CDBF9979-802E
   Блок управления многофункционального рулевого колеса:
   Подсистема 1 - Part No SW: 5E0 919 719 L    HW: 5E0 919 719 L
   Компонент: E221__MFL-PR6  H02 0150
   Серийный номер: 000000000D1011040915
   Кодировка: 820000
Адрес 17:  Комбинация приборов (J285)       Label: 5K0-920-xxx-17.clb
   Part No SW: 5L0 920 840 S    HW: 5L0 920 840 S
   Компонент: KOMBI         H03 1007
   Серийный номер: 00000000000000
   Кодировка: 120E000100
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05730
   ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
   VCID: 3B7ECBF5B24D7F9939-806E
Адрес 19:  Диагностический интерфейс шин данных (J533)       Label: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 AT    HW: 7N0 907 530 AK
   Компонент: J533  Gateway H57 1663
   Ревизия:   H57       Серийный номер: 040815F1001412
   Кодировка: 356322
   VCID: 020076119D27CE513A-8056
Адрес 22:  Электроника полного привода (J492)       Label: 0CQ-907-554.clb
   Part No SW: 0AY 907 554 J    HW: 0CQ 525 130
   Компонент: Haldex4Motion H52 7531
   Серийный номер: HA1-00024.08.15
   Кодировка: 0301
   Мастерская #: WSC 73430 790 00003
   ASAM Dataset: EV_AllWheelContrHA1VW37X 002015
   ROD: EV_AllWheelContrHA1VW37X_VW36.rod
   VCID: 52A0865105C79ED1CA-8006
Адрес 25:  Иммобилайзер (J334)       Label: 5K0-920-xxx-25.clb
   Компонент: IMMO          H03 1007
   Кодировка: 000000
   VCID: 6AD03EB18D57361192-803E
Адрес 42:  Электроника двери водителя (J386)       Label: 7N0-959-793.clb
   Part No SW: 7N0 959 793 J    HW: 7N0 959 793 G
   Компонент: TSG FA        H04 0561
   Ревизия:             Серийный номер: 0000165584517
   Кодировка: 01150320D000231003
   VCID: 4992A13DE091DD09BB-801C
Адрес 44:  Усилитель руля        Label: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 R
   Компонент: EPS_ZFLS Kl. 70     3501
   Ревизия: 00H22000
   VCID: 3972D1FD70714D892B-806C
Адрес 52:  Электроника двери переднего пассажира (J387)       Label: 7N0-959-792.clb
   Part No SW: 7N0 959 792 J    HW: 7N0 959 792 G
   Компонент: TSG BF        H04 0561
   Ревизия:             Серийный номер: 0000164720283
   Кодировка: 01150120D000231003
   VCID: 4894A439FB9B2401A4-801C
Адрес 5F:  Электроника информирования (J794)       Label: Не найден
   Part No SW: 5L0 035 200 B    HW: 5L0 035 200 B
   Компонент: MU-S--ER      H22 0245
   Серийный номер: SKZAZ2R8849231
   Кодировка: 03130600FF00000011110001000910002F0000C40120810000
   Мастерская #: WSC 73430 790 00031
   ROD: EV_MUStd4CTSAT_SK25.rod
   VCID: 1D3A256D0C9911A927-8048
Адрес 62:  Электроника задней левой двери (J388)       Label: 7N0-959-795.clb
   Part No SW: 7N0 959 795 F    HW: 7N0 959 795 E
   Компонент: TSG HL        H04 0561
   Ревизия:             Серийный номер: 0000166793028
   Кодировка: 010001200000531003
   VCID: 4796A705F6852B79AD-8012
Адрес 65:  Система контроля давления в шинах (J502)       Label: 3AA-907-273.clb
   Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
   Компонент: RDKBERU30     H04 0009
   Заводской номер: 30000000065686
   Метка файла ASAM/ODX: EV_RDKBERU30 006001
   ROD: EV_RDKBERU30_006_VW37.rod
Адрес 72:  Электроника задней правой двери (J389)       Label: 7N0-959-795.clb
   Компонент: TSG HR        H04 0561
   Ревизия:             Серийный номер: 0000164930757
Конец------------------------(Elapsed Time: 03:21)-------------------------
Many thanks for the info, and yes, the installed TPMS unit is for MQB platform.
You need this one:
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
I'm not going to share any flash files, as I mentioned. What do you want from me?
Another option is to buy a new unit here: https://www.ebay.co.uk/itm/Neu-Original ... ctupt=true
Related info:
viewtopic.php?f=56&t=58703&start=3645#p525012
viewtopic.php?f=56&t=58703&start=4035#p529334
viewtopic.php?f=58&t=72376#p546569
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
somehow i miss the update from this car and topic. [emoji848] still there iichel?
Yes very much alive :mrgreen: don't worry. I'm just running out of ideas for any mods and time is quite scarce lately. The car had a set of new tires recently (hankook V12 215/40r17 but that's not particularly exciting I guess)
So, some sad news unfortunately. On a starting traffic jam on a wet highway, the car has been rear-ended by an Audi A6 and pushed into the car in front.
The crash on the rear was quite severe, the Audi shot its airbags out. In total there were four cars involved in the accident, I was the second in the line.
benzinkopf
oh no. sorry to hear that[emoji29]
I sincerely regret that this accident has occurred, I hope that no one was damaged.
My deepest condolences, I know there is a huge part of you in your 6R.
The whole world loses a great 6R.
" ... and every end has a new beginning"
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
so sorry to read this. :(
Some good news. The repair company has repaired the car. It's been approved for road use again. A major relief to myself.
The damage was close to terminal, I was lucky.
A complete new front end (bumper, fenders, grills, fog light, covers, bumper retainers, head light repair kit) and new rear bumper and spoiler.
To all who have the gas strut for lifting the bonnet:
The body shop suggested that the bonnet might have bended slightly due to the use of the gas strut.
I was somewhat lucky to have it replaced after the accident, it was indeed damaged by the front collision.
So have a look at whether this also the case for your polo. And if so, try to correct the issue before the damage gets any worse.
I enjoyed mine a lot, but perhaps it's better not to have it... I'm a bit in doubt whether I'll place it back.
benzinkopf
oh i was expecting to see the rossaline with new chassis + panoramic roof[emoji12]. good to know that its all good!
Super good news!
My OEM gas strut is not able to bend the bonnet, and is able to keep the bonnet open in case of strong air gusts and prevent the bonnet from hitting you unexpectedly.😂
CNK
Drives: 6R
Post by CNK »
Welcome among the living! It's good to see your car in all its glory :)
Jetseg also mentioned problems with gas struts, but from what I remember, the problem was with the model from AliExpress.
ag69
Post by ag69 »
Great news !!!
A new beginning for mods.
Long live your polo.
