Benzinkopf's 2012 VW POLO 6R MK5 1.2TSI 105HP DSG
Jay-Jay
Drives: Polo 6R HL 1.2TSI 77kw, Audi S1 MY2018
Re: Benzinkopf's 2012 VW POLO 6R MK5 1.2TSI 105HP DSG
Post by Jay-Jay »
I'm pretty sure the driving conditions have a big influence on the life of the chain.
The fact that you drive 70% on highway doesn't stress much the timing components.
At this point, considering your experience, we can say that a little rattle at start-up can be considered normal for this engine.
Anyway, thank you for sharing your experience! :)
benzinkopf wrote: Sun Jul 07, 2019 11:01 pm
ciclo wrote::lol: ... 8)
oh yes ... from now on I will give the 3AA sw so that nobody does business with it. :wink: :lol:
Some things to explain here (not related to this thread) ... but I prefer not to do it.
As you all know, I have always shared the information or my personal help free of charge.
Ciclo, funny world we re living. sometimes maybe we just have to accept, some ppl see opportunities while some see free stuffs are better. I have to agree though, for some ppl, we must put a price tag for them so they appreciate more. [emoji12] but one thing for sure, getting free information on one hand and charging them on the other hand mostly unacceptable.
Exact. 8)
I can only say that I complied with the established rules.
Peace and love. ✌
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
Exact. 8)
Peace and love. [emoji111]
Well. since you re here, allow me to get free info from you!
1. As i already installed the TPMS module without the sensors, after hour drive, the system shut off, and i lost the menu. VCDS scan shows its missing signal(obviously). So is it okay for me to continue powering up till i installed the sensors?
2. is there anything i should be worry with the existing indirect tpms? Should i turn it off (change the coding in ABS module?)
3. For the parameter setting, using RDKeditor, I should put in list of my preferred size tyres? How do i know whats the “best” pressures let says for 205/45R17? or 215/45R17? Haha. sounds like a stupid question, but i think thats my question. lol.
4. Any difference in Comfort and Standard Adaptation Settings?
1 Yes, no problem.
2 No, do not touch it.
3 There are many tire pressure tables online. The best tire pressures depend on the type of driving (personal taste), and type of asphalt/road. I personally like that the pressures are high for a uniform wear. I have 2.5 bar on all four wheels that with the variations in temperatures on the wheels move between 2.4 and 2.8 bars (I love it to check it).
Make a list with the size of tires that will be installed in your car.
4 They only are references for the driver to remember or adapt the pressures according to need or personal taste. In our Direct TPMS only standard or full is possible.
benzinkopf
thank you Ciclo. I will try the RDKeditor soon and visit my friend with OdisE to flash. Hope i can create special test menu as well. [emoji1362]
benzinkopf
Okay. The valves installed. but...
the Module still lying around at the back. any best suggestion for best placement position for the polo? behind the bumper metal bar? on top of the bar? on the inside rear bumper? [emoji848]
hmthakur
Drives: Polo gt tsi 1.2 dsg
Post by hmthakur »
benzinkopf wrote:Image
I had installed the module on wheel well where reverse sensor module is installed
benzinkopf
Thank you. will have a look again. I think the area near my PDC module is already tight with my 230V inverter back there. [emoji23] So i might need another place.
benzinkopf wrote: Tue Jul 09, 2019 8:44 am Image
8)
benzinkopf wrote: Mon Jul 08, 2019 12:23 pm thank you Ciclo. I will try the RDKeditor soon and visit my friend with OdisE to flash. Hope i can create special test menu as well. [emoji1362]
So the data file of tire pressures were transferred with ODIS, is it correct?
Have you made an autoscan to check if there is a new fault related to the IC?
benzinkopf
8)
Not yet. I need to visit my friend for his odis E. Right now i just select any tyre type that fits me from the existing list.
Yes. I do see the error in 17 module. seems like the same errors i got with blindspot. Something like unsupported generation of vcds. maybe thats the limitation with hex-can now which i believe its time to upgrade to hex Net to continue support RossTech. But the fault can be erased.
i will rescan and post the new scan.
Ok, waiting for the autoscan ... pleaaaase do not clear the DTCs ... thanks!!! :lol:
Let me explain: what I want to say is that you do not click on Clear all DTCs to erase the sporadic faults.
benzinkopf
ciclo wrote:Ok, waiting for the autoscan ... pleaaaase do not clear the DTCs ... thanks!!! :lol:
aye aye sir. Here’s the scan
 Wednesday,10,July,2019,13:43:04:15298
VCDS Version: 19.6.1.0 (x64)
Data version: 20190529 DS308.0
www.Ross-Tech.com
Workshop Code: 123 12345 012345
VIN: WVWZZZ6RZCUBENZIN   License Plate: BENZINKOPF
Mileage: 270680km-168192mi   Repair Order: 190710
Chassis Type: 6R-VW25 (01 - BENZIN)
Scan: 01 02 03 04 08 09 10 15 17 19 25 2E 37 3C 44 55 56 65 6C 77
VIN: WVWZZZ6RZCUBENZIN   Mileage: 270680km-168192miles
Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 HF    HW: 03F 907 309 J
   Component: SIMOS10.22H03 2698
   Revision: --H03---    Serial number:
   Coding: 002500F6202400080000
   Shop #: WSC 31414 790 50316
   ASAM Dataset: EV_ECM12TFS02103F906070HF 004004
   ROD: EV_ECM12TFS02103F906070FP.rod
   VCID: 6DDBC694BCAA3C2742-8038
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 0AM-927-769.clb
   Part No SW: 0AM 300 060 G    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 5270
   Revision: 00043014    Serial number: CU501411296648
   Coding: 0000020
   Shop #: WSC 25802 001 1048576
   VCID: 2E590198BA2C873F3B-50C8
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 230228E3416E00B4C42C14E382D800801700
   Shop #: WSC 12345 123 12345
   VCID: 0717943CB216F677D8-8052
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
   Part No SW: 6R0 820 045 G    HW: 6R0 820 045 G
   Component: Man AC         02 0101
   Revision: 0002S 02
   VCID: 326115E86D14A3DF5F-8066
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 259161638
   Coding: 3CB02BBF48A10E00133A0F917EEB9ED9DAC0672F602D30D0200400130800
   VCID: 2A510D8845C4EB1FE7-807E
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 180812 05  54  0403
   Coding: 07302D
   Subsystem 2 - Part No SW: 6R0 959 802 BH    HW: 6R0 959 802 BH  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU028041441182089
   Coding: 1400A3
   Subsystem 3 - Part No SW: 6R0 959 801 BC    HW: 6R0 959 801 BC  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU008051441286886
   Coding: 0400A3
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B
   Component: E221__MFL-TAS  H30 0032
   Serial number: 0122863
   Coding: 830000
   Subsystem 7 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU030061100015373
   Coding: 08BC32
   Subsystem 8 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU001071100015810
   Coding: 08BC32
Address 10: Park/Steer Assist (J446)       Labels:| 6R0-919-475.clb
   Part No SW: 6R0 919 475 B    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0012
   Revision: --------    Serial number: 47301119600512
   Coding: 308101
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3D7B36D4AC4A6CA7B2-8068
   Component: VW10Airbag027 H09 0020
   Revision: --------    Serial number: 003GX00RY8XP
   Coding: 003237
   Shop #: WSC 31414 790 31414
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4A916D08ED84CB1F07-801E
   Serial number: 3575HRB405H0IRE2COP8
   Serial number: 3585HRB405J0ISD6C8T3
   Serial number: 3515RRB405J0LMIQ6PBL
   Serial number: 3525RRB405H0LMIQCGRX
   Part No SW: 6RD 920 870 A    HW: 6RD 920 870 A
   Component: KOMBI         H05 0805
   Coding: 141C01
   VCID: 4797543CFE96367718-8012
1 Fault Found:
12658432 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 53
                    Reset counter: 201
                    Mileage: 270633 km
                    Date: 2019.07.10
                    Time: 01:30:37
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 002305
   VCID: 68D5B7809B48190F31-803C
   Component: IMMO          H05 0805
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6AD1CD888D442B1F27-803E
   Part No SW: 5N0 035 342 E    HW: 5N0 035 342 E
   Component: SG EXT.PLAYER H13 0240
   Revision: A1001003    Serial number: 7660415697
   Coding: 010000
   VCID: 2953F28440C2E007EE-807C
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 D
   Component: RNS-MID       H70 5274
   Revision: AB001001    Serial number: VWZ6Z7M2235046
   Coding: 04000402040000A00001
   VCID: 377724FC867646F768-8062
   Subsystem 1 - Part No: 7L6 919 859 J
   Component: SIMA V4  7769
Address 3C: Lane Change (J769)       Labels:| 5Q0-907-566.clb
   Part No SW: 7E0 907 566 C    HW: 4H0 907 566 F
   Component: SWA Master    H06 0030
   Serial number: 0372892839
   Coding: 030312
   ASAM Dataset: EV_LaneChangAssis 001028
   ROD: EV_LaneChangAssis_VN75.rod
   VCID: 30651FE06B1891CF29-8064
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 7E0 907 568 C    HW: 4H0 907 568 F
   Component: SWA Slave  H08 0030
   Serial number: 0432634593
   Coding: 030312
3 Faults Found:
267776 - Data Set Implausible
          B2012 00 [009] - -
                    Fault Priority: 3
                    Fault Frequency: 21
                    Reset counter: 161
                    Mileage: 270541 km
                    Date: 2019.07.08
                    Time: 18:23:38
729349 - Control Module for Lane Change Assistance
          C1114 54 [009] - Missing Calibration / Basic Setting
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 154
                    Mileage: 270541 km
                    Date: 2019.07.08
                    Time: 18:10:51
729605 - Control Module 2 for Lane Change Assistance
          C1115 54 [009] - Missing Calibration / Basic Setting
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 154
                    Mileage: 270541 km
                    Date: 2019.07.08
                    Time: 18:10:51
   Part No: 6R0 423 156 B
   Coding: 11230
   Shop #: WSC 31414
   VCID: 2F671C9CEA268E3730-807A
   Revision: --------    Serial number: --------------
   Coding: 0316000001000000
   VCID: 77F7E4FCCEF686F7A8-8022
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
   Serial number: 30000000023712
   ROD: EV_RDKBERU30_005.rod
   VCID: 377724FC8E7646F768-8062
Address 6C: Back-up Cam.        Labels: 5N0-907-441.clb
   Part No SW: 3AE 907 441     HW: 3AE 907 441
   Component: J772__Rearview      0020
   Revision: 00H13000    Serial number: 525PA8-J41D320
   Coding: 0020006
   VCID: 72E1D5E86D94E3DF9F-8026
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007663752927
   Coding: 0A10000000010110
   Shop #: WSC 43038 123 12345
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A713DC8BD645B9F97-806E
End-------------------------(Elapsed Time: 04:30)--------------------------
Many thanks. 👌🤝
Everything is as it should be 'according to the circumstances'.
benzinkopf
ciclo wrote:Many thanks. [emoji108][emoji1666]
So nothing should worry me right? [emoji23] the same way i dont worry with my Lane Change error. Keep telling missing calibration. but the system works fine. I checked the dynamic calibration is still running but the dynamic calibration km-driven counter already stop at 15000km. I really think there’s limitation being put in place for old gen VCDS cable. Hence I cant see the exact error and calibrate the thing.
benzinkopf
btw. so as it happened, one morning, i started the car with “Check tire pressures” warning on which was due to cold air pressure lower the specified bar. It was 1.9 bar if not mistaken and my specified value is 2.2 bar. Then I went straight to pump the tires to 2.2 bar accordingly and all tires showed exactly 2.2 as well. But seems like the “image” still showed shaded tires instead of full white tire.
How exactly we should reset that?
