Ferris
Drives: 1.4 TSI TwinCharger
Post by Ferris »
So, I gave it a try, but VCDS will throw the following error: Coding rejected / Error 31: Request out of range" while setting the new coding.
My WRMs are in a Seat Ibiza 6J (PQ25) and also used in the Skoda Fabia 5J. But you've mentioned the Jetta and the Amarok and after some research I found out that they have the same problem..:-(
The new Ibiza 6P (MQB) WRMs do support auto folding with car lock and have the part numbers "6R0 959 801 DT / 6R0 959 802 EE" - but I suppose that there are the same problems on my Ibiza 6J (PQ25) as with the Polo 6C (MQB) WRMs "6R0 959 801 CE / 6R0 959 802 CJ" which won't support auto folding when locking the car in the Polo 6R (PQ25) either. (The "6R0 959 801 BD / 6R0 959 802 BF" can't be ordered any more for the Polo 6R and have been exchanged to "6R0 959 801 CE / 6R0 959 802 CJ" with loosing auto fold via car lock...)
Thank you for the link to the video - unfortunately PQ25 WRM can't be accessed via channel 42 separately and can only be reached at channel 09 as subsystem of the BCM. So there is no chance to change EEPROM values with VCP right now AFAIK.
Yes, everything you mention is right, the conclusion is that they only work with the 8 in the software (for the entire PQ25).
We also know (thanks to a good friend 8)) that you can also install the WRMs from Beetle or Cabrio:
LHD
Subsystem 2 - Part No SW: 6R0 959 801 BF HW: 6R0 959 801 BF Labels: 6R0-959-801.CLB
    Component: J386__TSG_FT 004 8662
Subsystem 3 - Part No SW: 6R0 959 802 BM HW: 6R0 959 802 BM Labels: 6R0-959-802.CLB
    Component: J387__TSG_BT 004 8662
but they have a fun behavior...
I love it... :lol:
Ferris
Post by Ferris »
There is an explanation for this "fun behavior": The windows in the doors of the Beatle don't have a frame - so the window opens a litte bit when opening the door and closes completely when door has been closed.
Unfortunately the window mechanism in the Ibiza 6J/6P is working opposite to the one in the Polo 6R/6C - so the window is closing when it should open and vice versa when using Polo/Beetle WRMs...
Any chance that the Ibiza 6P MQB WRMs can be coded in some way so that the signal from the PQ25 BCM to unfold when ignition is turned on will be interpreted correctly?
Ferris wrote: Thu Feb 22, 2018 8:21 pm Unfortunately the window mechanism in the Ibiza 6J/6P is working opposite to the one in the Polo 6R/6C - so the window is closing when it should open and vice versa when using Polo/Beetle WRMs...
hmm... it can be changed by coding.
Adam87
Drives: T5.2
Post by Adam87 »
ciclo wrote:Yes, everything you mention is right, the conclusion is that they only work with the 8 in the software (for the entire PQ25).
There is one exception (so far) to the 8*** rule, the T5 7E0 959 801 K does not have enough pins and does not work, maybe some 6R ones are similar?
Ferris
Post by Ferris »
ciclo wrote: Thu Feb 22, 2018 8:38 pm hmm... it can be changed by coding.
That's what I thought too! But my information from a german Polo forum is that neither VCDS nor VCP was able to find a coding that will change the behavior of the motor direction. (The manual mirror fold was also activated in "L" position then and not in "fold" position...)
If the internal WRM behavior can be changed by coding, then the Beetle WRM "fun behavior" should also be controlled by coding in theory!
Hi Adam :D , you're right with the exception. I do not know any 6R WRMs with that HW/SW configuration. (there are many)
The evidence: (Right for RHD)
What is clear, is that the WRMs should have these pins: (LHD)
and in turn comply with 8**** rule. (8 or higher).
Ferris wrote: Thu Feb 22, 2018 9:06 pm
Play/test (activate/deactivate) with the bit3 and 4 of Byte2. One or other.
Ferris wrote: Thu Feb 22, 2018 9:06 pm If the internal WRM behavior can be changed by coding, then the Beetle WRM "fun behavior" should also be controlled by coding in theory!
I'm afraid it's part of the EEPROM.
Ferris
Post by Ferris »
ciclo wrote: Thu Feb 22, 2018 9:17 pm Play/test (activate/deactivate) with the bit3 and 4 of Byte2. One or other.
I'll try to find the BD/BF WRMs and give it a try! But what about the wrong behavior with the manual folding in position "L"?
Adam87
Drives: T5.2
Post by Adam87 »
ciclo wrote:Hi Adam :D , you're right with the exception. I do not know any 6R WRMs with that HW/SW configuration. (there are many)
Hey Fernando [emoji3],you are most correct, as long as the pins are there and 8*** SW then it should work just fine.
With the WRM with odd behaviour, doesn’t the WRM detect different resistance dependent on switch position?
Ferris wrote: Thu Feb 22, 2018 9:59 pm
What is the mirrors switch reference number (part number)?
Adam87 wrote: Thu Feb 22, 2018 11:30 pm
Take a look here :arrow: viewtopic.php?f=56&t=70884&start=30#p530790
Adam87
Drives: T5.2
Post by Adam87 »
Take a look here [emoji666] viewtopic.php?f=56&t=70884&start=30#p530790
Thanks Fernando, great news I suppose [emoji3], I would like to have got ACC working like OEM, but best to have it working at least until that day [emoji4]
CoolMan1985
Drives: Polo 6r 1,6TDI BlueMotion
Post by CoolMan1985 »
ciclo wrote: Fri Jan 26, 2018 9:40 am Hi CoolMan1985, welcome.
Yes, A :arrow: here, please tell me the Model Year (MY), year of manufacture, tenth digit of the VIN ... or post an autoscan if you have VCDS. Thanks
Hey ciclo
sorry for my late reply :oops: I have made a autoscan for you :) the car it`s a 2013 model.
Lørdag,24,Februar,2018,15:47:32:63534
VCDS -- Windows baseret VAG/VAS emulator - Kører på Windows 10 x64
VCDS version: NEZ 18.2.0.3  HEX-V2 CB: 0.4411.4
Dataversion: 20180222 DS287.0
www.vcds.dk
Stelnummer: WVWZZZ6RZDY015110   Indreg.nr.:
Kørestrækning: 217920km   Reparationsordre:
Modeltype: 6R-VW25 (6R0)
Søgt på: 01 03 08 09 15 17 19 25 44 56 61
Stelnummer: WVWZZZ6RZDY015110   Kørestrækning: 217920km
01-Motor -- Status: Ok 0000
03-ABS bremser -- Status: Fejlfunktion 0010
04-Styrevinkel -- Status: Ok 0000
08-Klimaanlæg -- Status: Ok 0000
09-Centralelektrik -- Status: Ok 0000
15-Airbags -- Status: Ok 0000
17-Instrument -- Status: Ok 0000
19-CAN Gateway -- Status: Ok 0000
25-Startspærre -- Status: Ok 0000
44-Servostyring -- Status: Ok 0000
56-Radio -- Status: Fejlfunktion 0010
61-Batteriregulering -- Status: Ok 0000
Styreenhed  01: Motor (J623-CAYB)     Forklaringsfil:. NEZ\03L-906-023-CAY.clb
   Styreenhedsnr: SW: 03L 906 023 ME    HW: 03L 907 425 B
   Komponent	: R4 1.6l TDI   H33 9978
   Revision: --H33---    Serienummer:
   Kodning	: 00114016002401080000
   Forhandler	: WSC 00788 648 00255
   ASAM datasæt: EV_ECM16TDI02103L906023ME 003014
   ROD: EV_ECM16TDI02103L906023PL.rod
   VCID: 75B4E936E54EB44F51E-8020
Ingen fejlkoder fundet.
Readiness: 0 0 0 0 1
Styreenhed  03: ABS bremser (J104)     Forklaringsfil:. NEZ\6R0-907-37x-ESP82.clb
   Styreenhedsnr: SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Komponent	: ESP8.2i front H05 0001
   Revision: --------
   Kodning	: 210228E3416E00B7842614E382D100521300
   VCID: 025E82EAA44093F764C-8056
1 fejl fundet:
02214 - Dæktrykadvarsel
            002 - Under nedre grænseværdi - Periodisk
             Fryseramme:
                    Fejl status  : 00100010
                    Fejlprioritet: 0
                    Fejlhyppighed: 2
                    Nulstiltæller: 171
                    Kørestrækning: 217726 km
                    Tidsindikation: 0
                    Dato: 2012.07.13
                    Tid: 15:40:43
             Fryseramme:
                    Hex værdi: 0x0000
                    Hex værdi: 0x8000
                    Hex værdi: 0x1203
                    Hex værdi: 0x2BBD
                    Hex værdi: 0x497F
                    Hex værdi: 0x7F7E
                    Hex værdi: 0x7F00
Styreenhed  08: Klimaanlæg (J255)     Forklaringsfil: NEZ\6R0-907-044.clb
   Styreenhedsnr: SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Komponent	: Climatronic   H11 0711
   Revision: V0000000
   VCID: 382A2002B25C09278A8-806C
Styreenhed  09: Centralelektrik (J519)     Forklaringsfil:. NEZ\6R0-937-08x-09.clb
   Styreenhedsnr: SW: 6R0 937 088 F    HW: 6R0 937 088
   Komponent	: BCM PQ25 Re4  H50 0353
   Revision: BU050001    Serienummer: 0456 151120596
   Kodning	: 24B02BB80821000021300DF02D0B8FD05F80612F7E060049200000000000
   Forhandler	: WSC 12345 678 987654
   VCID: 41DC4DE6E18648EF3D6-8014
   Undersystem 1 - Styreenhedsnr:: 1K0 955 559 AH  Forklaringsfil: NEZ\1K0-955-559-AG.CLB
   Komponent	: RLS 230512 05  54  0403
   Kodning	: 03302D
   Undersystem 2 - Styreenhedsnr: SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Forklaringsfil: NEZ\6R0-959-801-1.CLB
   Komponent	: J386__TSG_FT  008 1611
   Serienummer: KU0KU020051200010555
   Kodning	: 58BC30
   Undersystem 3 - Styreenhedsnr: SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Forklaringsfil: NEZ\6R0-959-802-1.CLB
   Komponent	: J387__TSG_BT  008 1611
   Serienummer: KU0KU014051200013396
   Kodning	: 58BC30
   Undersystem 4 - Styreenhedsnr: SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Komponent	: J388__TSG_HL  008 1611
   Serienummer: KU0KU014051200015077
   Kodning	: 58BC32
   Undersystem 5 - Styreenhedsnr: SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Komponent	: J389__TSG_HR  008 1611
   Serienummer: KU0KU015051200016374
   Kodning	: 58BC32
Styreenhed  15: Airbags (J234)     Forklaringsfil:| NEZ\5K0-959-655.clb
   Styreenhedsnr: SW: 6R0 959 655 L    HW: 6R0 959 655 L
   Komponent	: VW10Airbag01J H10 0020
   Revision: --------    Serienummer: 003GY006KAHK
   Kodning	: 00314A
   Forhandler	: WSC 01383 785 00200
   ASAM datasæt: EV_AirbaVW10BPAVW250 A01001
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4BC06FCED34A92BFD7A-801E
   Crashsensor til sideairbag i førerside:
   Serienummer: 3575HRB405T1E4S2DGDW
   Crashsensor til sideairbag i passagerside:
   Serienummer: 3585HRB405V1E4S21PCV
   Crashsensor til sideairbag bagi i førersiden:
   Serienummer: 3515RRB405B18B74A0OZ
   Crashsensor til sideairbag bagi i passagerside:
   Serienummer: 3525RRB405318BCID991
Styreenhed  17: Instrument (J285)     Forklaringsfil:| NEZ\5K0-920-xxx-17.clb-SRI1
   Styreenhedsnr: SW: 6R0 920 861 K    HW: 6R0 920 861 K
   Komponent	: KOMBI         H02 0305
   Serienummer: 00000011763025
   Kodning	: 140E01
   ASAM datasæt: EV_DashBoardUDSJCIPQ25 A01720
   ROD: EV_DashBoardUDSJCIPQ25_A01_VW25.rod
   VCID: 3D2431169DFE2C0F59E-8068
Styreenhed  19: CAN Gateway (J533)     Forklaringsfil:. NEZ\6R0-907-530-V2.clb
   Styreenhedsnr: SW: 6R0 907 530 E    HW: 1K0 907 951
   Komponent	: J533  Gateway H38 0041
   Revision:   H38       Serienummer: 110512F2001017
   Kodning	: 2500C2
   VCID: 35342936A54EF44F91E-8060
Styreenhed  25: Startspærre (J285)     Forklaringsfil:. NEZ\5K0-920-xxx-25.clb
   Komponent	: IMMO          H02 0015
   Serienummer:
   ASAM datasæt: EV_ImmobUDSJCIPQ25 A01003
   ROD: EV_ImmobUDSJCIPQ25.rod
Styreenhed  44: Servostyring      Forklaringsfil: NEZ\6Q0-423-156.clb
   Styreenhedsnr:: 6R0 423 156 C
   Komponent	: LenkhilfeTRW        V278
   Kodning	: 11230
   Forhandler	: WSC 12787
   VCID: 303A1822536CD167C28-8064
Styreenhed  56: Radio (J503)     Forklaringsfil:. NEZ\5M0-035-1xx-56.clb
   Styreenhedsnr: SW: 5M0 035 186 J    HW: 5M0 035 186 J
   Komponent	: Radio RCD310  042 0082
   Revision: 01000001    Serienummer: VWZ1Z2M4142398
   Kodning	: 05000400020001
   VCID: 3330172EAB3AEA7FBFA-8066
1 fejl fundet:
00856 - Antenne - på radio
            007 - Kortslutning til stel
             Fryseramme:
                    Fejl status  : 01100111
                    Fejlprioritet: 5
                    Fejlhyppighed: 1
                    Nulstiltæller: 135
                    Kørestrækning: 217920 km
                    Tidsindikation: 0
                    Dato: 2012.07.17
                    Tid: 15:44:48
Styreenhed  61: Batteriregulering (J840)     Forklaringsfil:. NEZ\1K0-907-534.clb
   Styreenhedsnr: SW: 6R0 907 534     HW: 1K0 907 951
   Komponent	: Batt.regelung H38 0041
   Kodning	: 030B1A59
   VCID: 74B2D432EEB4AD47660-8020
   Undersystem 1 - Styreenhedsnr: SW: 6R0 915 181 E    HW: 6R0 915 181 E
   Komponent	: J367-BDM  H08 0181
   Serienummer: 00000000004970234865
Slutning-(Forløbet tid: 01:13, VBat. start/slut: 11.6V/11.6V. VIgn 11.5V)--
CoolMan1985 wrote: Sun Feb 25, 2018 5:58 pm
Hey ciclo
Hi CoolMan1985.
There is no problem at all.
Thanks for the autoscan.
You can install the automatic light wiring ("A" in the sale).
You will have your automatic lights and CH/LH functions, etc ...
Now I send you my email by private message so you can contact me and I can explain the payment and shipping processes of your A wiring.
Fast, easy, safe, efficient, and perfect for you ... you can be totally sure. :wink:
Locked
