Polo 6R - Useful Part Numbers
yeah just get the BlueGT spoiler
Noiseprojekt
Drives: VW Polo -14 1,2 TSI R-Line
Post by Noiseprojekt »
iichel wrote: Tue May 17, 2022 11:12 am yeah just get the BlueGT spoiler
Wow, thanks!
I did not know that them existed!
Now i just got to find the part number
EDIT:
53 Left 6R6805945
54 Right 6R6805946
But i dont know if you'll need part 51, 6R6827989 "Bracket for spoiler" as well
Does anyone know what these clips are called?
The EGT wire clips into it on the turbo housing. It seems that KK3 dont fit on 1549vz 🤔
Can someone tell me what is the part number of terminal pins (male and female) for rear door connector ( 1K0 937 702 C) ?
MCP 2.8 and MCP 1.5
Thank you!
wolfie
Post by wolfie »
In the past if I've wanted part number info I've used the parts catalogs on 7zap.com. They've generally been very good. However they appear to have updated the site and now it's a complete dogs dinner. Really struggling to use it now.
Where else can you gain access to VW part numbers??
wolfie wrote: Sat Feb 25, 2023 2:04 pm In the past if I've wanted part number info I've used the parts catalogs on 7zap.com. They've generally been very good. However they appear to have updated the site and now it's a complete dogs dinner. Really struggling to use it now.
Try this;
https://webautocats.com/en-gb/etka/volkswagen/
wolfie
Post by wolfie »
Cheers that was quick... :D
Thanks for the link.
Cruzor
Drives: VENTO 1.5TDI
Post by Cruzor »
1.Hi, does anybody know the part number for this beige trim piece? It’s also available in black which is what I’m looking for. I checked in ifinterface but it shows only the smaller fuse box door(you can see it’s a separate piece) in the diagram, so I’m asking here. Is this even removable?
Edit- 2. Also If someone can share the terminals and block part numbers needed for an 654 g85 steering sensor it’d be fantastic.
the lower dash trim is not a separate part
G85 is connected to the T41 connector of the slip ring, those are all MQS
Cruzor
Post by Cruzor »
Thank you for the help. Ahh that’s a bummer, I found a black glovebox for cheap and thought to make the whole dash black :|
Christian_13
Drives: Polo 6R Highline 1.2 TSI 6-Gear
Post by Christian_13 »
Hello,
we have an 2012 Polo 6R 1.2TSI and want to change the Highline-Steering wheel to the genuine R-Line from the 6R
The basic one with no DSG-paddles or multifunction
I´m looking for the OEM-part.nr
I hope it is still available.
I only found the 6R0419091SBRU for the WRC
limparka
Drives: 6R 1.4
Post by limparka »
Hello Guys!
I would like to change my front fog lights on my Polo 6R 2009. The right one is damaged so I thinking about to change all of them to a new one. Is the Polo 6R GTI Fog lights fits into the stock bumper? I know that the front bumpers are not the same, but maybe the lights have the same dimensions. The lights what I found are the next: 6R0941061F and 6R0941062F. I only have manual fog lights so I only need the light with only 1 bulb.
Thank you for your help. :)
CNK
Drives: 6R
Post by CNK »
limparka wrote: Mon Apr 29, 2024 2:20 pm Hello Guys!
No, will not fit, the shape is different (Polo 6R - additional front lights)
Only fog lights for standard bumper of 6R are: 6R0941061C + 6R0941062C.
However, you may want to consider adding fog lights + DRLs (additional wiring harness will be required) ;-)
