ag69
Drives: 1.2TSi 77Kw 7DSG
Re: iichels Polo 6R 1.2TDI Bluemotion --> OEM++ R-Line conversion
Post by ag69 »
benzinkopf wrote: Fri Aug 23, 2019 5:00 pm oh i was expecting to see the rossaline with new chassis + panoramic roof[emoji12]. good to know that its all good!
+ 1
I agree 1000%
TheLizardKing
Drives: VW GT TSI 1.2
Post by TheLizardKing »
iichel wrote: Fri Aug 23, 2019 4:33 pm To all who have the gas strut for lifting the bonnet:
The body shop suggested that the bonnet might have bended slightly due to the use of the gas strut.
I was somewhat lucky to have it replaced after the accident, it was indeed damaged by the front collision.
So have a look at whether this also the case for your polo. And if so, try to correct the issue before the damage gets any worse.
I enjoyed mine a lot, but perhaps it's better not to have it... I'm a bit in doubt whether I'll place it back.
Hi Michel,
I had installed a 350N gas strut for lifting the bonnet of my Polo. It would make a fairly loud creaking sound from near the hinge when I pulled the bonnet down. Also, it stopped "popping up" when I would pull the release lever. The VW technicians suggested that I put in another one on the other side to balance the load. So I bought another 350N strut and installed it on the other side. Needless to say, 700N is too much for a poor Polo, and it became pretty difficult to close the bonnet. And just like your car, the bonnet on mine started bending too. I ended up removing both, and going back to the stock setup.
But I really wanted that mod, so I then went ahead and purchased 2 struts of 150N each. I will install them shortly. I hope that I will not face any of the previous problems with 300N of balanced force. I think the two main problems are these:
  1. The angle of the strut is too low (it is horizontal in the closed position), and the strut is too long. If you look at OEM setups (e.g. Jetta), they have a short strut mounted almost vertically.
  2. The engine bay of the Polo doesn't have proper mounts for the struts, because of which the load gets transmitted to the bonnet and fender, leading to their deformation.
ag69
Post by ag69 »
sorry to hijack original thread
hope this can be helpful
viewtopic.php?f=56&t=69996#p522764
A question to whom it could concern. I'm playing around a bit with the GRA_High emulator. I bought one from RoFireman from the Drive2.ru forum.
The software was pre-loaded and worked well in Russia. It doesn't work on my car though, I guess since I got a diesel. Most of the Russian Polo 6Rs are a 1.4 MPI or 1.6MPI (petrol) engine.
Now it's connected to the instrument CAN network and a +15 power supply.
Does anyone maybe know the correct can message for GRA_High on a TDI engine? Thanks 8)
H2Deetoo
Drives: VW UP/Passat B6
Post by H2Deetoo »
I have gathered this info about GRA HIGH, I would not have expected there would be any difference between diesel or petrol.
Most likely not properly implemented by your Russian friends.
288 [8] 8F 6F 20 04 00 53 FE 00 //still
288 [8] 8F 8D 30 04 00 5A 68 00 //driving
288 Len:8 Data: 8F 9D 70 00 1E 5F 94 00
70 = 0111 0000 = CruiseControl ON ;
00 = GRA HIGH does not used by Engine ,
1E = 30dec - speed set in CC
Have you ever logged the output of your engine ecu?
Rgs H2Deetoo
New mod!
867 853 687 VW Polo type 86c logo from a 1989 VW Polo, my birth year :)
Not sure yet where to put it though... left middle or right side of the bootlid.
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
from the design of it. it seems better on the left. due to the shade effect going to the right[emoji2960]
Yes, sounds logical.
Original place for the 6R is on the left. It has the engine type on the right.
Original place for the 86c is on the right. It has Volkswagen written on the left.
VW Käfer (New Beetle) sometimes has Käfer written in the middle with no further mentioning of engine type.
I'm not planning on writing the engine type (humble 1.2 TDI) on the rear. Perhaps 1200 written in 1950-1970 beetle font would be nice :mrgreen:
benzinkopf
the best part of this, its 1989 badge logo on the modern polo with keyless. [emoji41]
vento2013
Drives: 6R Polo(Vento)1.6TDi, Skoda Fabia 1.2MPi
Post by vento2013 »
Hi, Iichel, these 6C buttons will work for 6R? Or need any modification?
Need to change AC vent and frame for infotainment system that i know.
Just wanted to know about buttons!
Thanks.
Plug and play :)
vento2013
Post by vento2013 »
Thank you!! :D
still have many questions regarding KESSY!!
I'm thinking about adding 199 398 500 A to my mods. Any ideas from you guys?
CNK
Drives: 6R
Post by CNK »
Here in Poland I can't order it.. ;-D
It is a good addition.
I'm not going to add them because I have read in some forums that an activation code is needed to open the sausage package ... you have to go to the VW dealer to open them with their tools.
In most VW dealers they will tell you that it cannot be added, but in reality they don't know how to do it ...
