Cornishdrummer's Progress Thread -Im back(pg 34)
cornishdrummer
Re: Cornishdrummer's Progress Thread - DASH SMOKING(pg 29)
Post by cornishdrummer »
Cheers mate, Spoke to Alex this morning he told me what it was, and got myself one off ebay, which should be here by Saturday I hope.
cornishdrummer
New wiper stalk came today, gonna try and get it fitted tomorro.
cornishdrummer
cornishdrummer wrote:New wiper stalk came today, gonna try and get it fitted tomorro.
Im having problems removing the airbag :roll:
red6n2
Cornishdrummer's Progress Thread - airbag help needed(pg 30)
Post by red6n2 »
Make sure you disconnected the battery !.
cornishdrummer
Re: Cornishdrummer's Progress Thread - airbag help needed(pg
Still aveing probs lol
benmkiv
Post by benmkiv »
At the back there's two holes with done sprung c clips holdin the airbag in, they're an absolute pain to spring out bit be persistant you just need to get a small screwdriver In there and lever them off. Whatever you do if you get one off do not Petrie airbag fall back in and clip on you'll go insane. You access then from two holes in the rear of the wheel.
cornishdrummer
Done it :D
Drove 15miles to sort the ecu out, wiper seems fine at the moment as well :D :D :D :D :D :D
cornishdrummer
Re: Cornishdrummer's Progress Thread - Fixed (pg 30)
Everything still seems to be fine, I take it if there was still a problem it would of happened right away again ?
cornishdrummer
Re: Cornishdrummer's Progress Thread - Plate holder help (pg
I got home from work today and noticed my number plate holder was loses at the front, so had to take it off and use the velcro again :(
What does everyone else use to kept the number plate holder secure ?
Endi_GTI
Re: Cornishdrummer's Progress Thread - plate holder help (pg
Post by Endi_GTI »
Mines on self tappers in the original holes from the PDI. Or you could use a good double sided tape.
6N2 GTI 00
Post by 6N2 GTI 00 »
Self tappers are probably your best bet as Matt said
Mine is mounted to the lower grille but I used custom made plastic brackets to support mine
What other plans have you got for it then mate? will you be lowering it this year?
cornishdrummer
Thanks Matt & Ben, I screwed mine but will try the self tappers over the weekend, Im hoping I can get it sorted then.
I want to sort some wheels out at some point
cornishdrummer
I got the self tappers this morning so will try and sort it morro if its dry. :)
Im also gonna try and get these soon as well.
GTI Grill VW badge
Lower honeycomb Grill
Drivers seat adjustment winder
GTI grill badge
2 x engine strut mount cover.
cornishdrummer
Re: Cornishdrummer's Progress Thread - VAGCOM (pg 30)
My VAGCOM 409.1 lead came this morning is it worth running a check on the car or not ?
Endi_GTI
Post by Endi_GTI »
For sure mate. Always worth checking how the little olop is running with a quick fault code check
