Small details
More information in September.
I wonder what it is, is it for your front pdc?
Enjoy the holidays
Enjoy the holidays
JaegerStriker
- Drives: 6C GTI
how hard was it to get the covers of and on again?
thinking of doing something similar to my 6c gti
Do it exactly the same. I think it's the best video ever posted online
about the Heated Seat Elements installation/retrofit on a VW. (IMHO, ...my opinion is irrelevant
Removing and intalling the covers is absolutely simple with the hook tool (cheap tool), shown in the third image of the video. It's not necessary to pull hard to extract the cover tension wires with this tool. Very, very easy
Advice: Place the Heated Seat Element resistance/wire over the cover horizontal tension wire, never below them (logically). It's very easy to understand when you are in the installation process.
I recommend you ELSAWIN process.
https://workshop-manuals.com/volkswagen ... d_padding/
Apart:
The wires belonging to the heated seat elements (HSE) were modified during the installation process, because they belong to the Skoda Rapid/Seat Toledo (cheaper than those from 6R and equally effective).
Pay special attention to the second image of the video (GO
) to compare them if you buy this HSE model.
Apart:
Making a stopper.
To avoid draining the wiper reservoir when removing my front bumper.
https://i.imgur.com/q110lB7.jpg
They were the only materials I had at my disposal at that time.
I have to change the battery console due to a manufacturing defect.
In my case, the threaded insert in the plastic of original battery console (which holds the lower housing of the air filter) wasn't properly tightened to the plastic, making impossible to loosen the screw by conventional methods.
The original battery console reference number was replaced by the following one:
This is the threaded insert to which I refer.
I also will put a new cover for the battery, the one that I used when I upgraded to the
new bigger battery is not exactly the one that corresponds to it.
https://uk-polos.net/viewtopic.php?f=56 ... 14#p540414
you can turn your car into a professional photo studio with all the wall-mounted flashlights
Highly recommended (HQ)
https://www.aliexpress.com/item/Portabl ... 4c4drDPLBD
Buy the big size, the small size is equally effective but the battery has a shorter duration.
J367 retrofit, power straight from the engine fuse box, fuse holder C?
