I have the male connector, one of the h4 connectors, the live feed and the relays all bunched up in the one I’ve bought, just doesn’t seem long enough to mealexperkins wrote: Wed Oct 06, 2021 11:46 am Have you got a pic? All the looms run back to the fuse box on these
Headlight upgrade
benmachin95
- Drives: MK2F/MK3 Polo Genesis
Re: Headlight upgrade
- image.jpg (2.77 MiB) Viewed 53636 times
- image.jpg (5.76 MiB) Viewed 53636 times
Ah, you have a relay loom for brighter lights
Basically, you need to connect the red to the + on the battery, brown to the chassis or - on the battery
The existing headlamp plug goes into the male plug, then the female plug goes onto the back of your bulbs
Can you post a pic up of the full new headlamp loom?
benmachin95
Hi really appreciate the help!alexperkins wrote: Wed Oct 06, 2021 5:11 pm Ah, you have a relay loom for brighter lights
So has the current loom plug? to be plugged into the male connector?
If so then the cable is nowhere near long enough.
Cheers,
Ben
Pop up a pic of the full loom so I can work it out visually
A link to what you bought will also help
benmachin95
It’s alright mate i cracked it, really appreciate the help!
Some before and after pics
- 81B96E7F-702A-4C3A-A687-20D4DD3FF42D.jpeg (5.14 MiB) Viewed 53609 times
- 30149DB5-D1A2-4184-87DC-8EA67A068A74.jpeg (4.19 MiB) Viewed 53609 times
- 7A14C970-0E46-462B-9F14-C9CF416242F5.jpeg (3.83 MiB) Viewed 53609 times
Big improvement mate!!
Also, I’d disconnect the big coil resistor with the yellow wires by the fuse box. They have a habit of bursting into flames as they overheat
