Page 4 of 6
Posted: Sat Feb 09, 2008 8:26 am
by JarnoVWPolo6N
A 3F cam has engraved in it: 030 AF
Posted: Thu Apr 17, 2008 12:41 am
by Hardcore
quick question:
would this improve the 1.4 16v ? and would i use the same camshaft as you have done in this demonstration? the one out of the 1.3 lire GT ??
Posted: Thu Apr 17, 2008 4:10 pm
by JarnoVWPolo6N
Hardcore wrote:quick question:
quick answer: the 16v has 2 cams, the 8v just one, and both are NOT to swap, will never fit
Posted: Thu Apr 17, 2008 11:04 pm
by polo-sib
Jarno which one would be best and give a more likely fit?
G40
GT
MK3 Golf
As i got a belt change coming up and tempted by your idea.
Posted: Sat Apr 19, 2008 12:02 am
by JarnoVWPolo6N
Well, make sure to get one from a Polo engine, most Golf engines run the "big-blocks" from which the cam doesn't fit, ok, some Golf mk3's drive around with small-blocks, but those cams are at most 204 degrees, not much of an up-grade, GT cam is 219, getting a Schrick one is 268 degrees
A G40 one won't be very helpfull, since it's a-symetric, meaning the inlet-valves are open less time then the exhaus-valves, meaning little to no up-grade, since your inlet timing isn't increasing (which is the biggest gain coming to cams and NA-engines)
So... just go for the GT one, from a mk3 GT with engine code 3F (NOT engine code NZ!!!)
Posted: Sat Apr 19, 2008 12:04 am
by JarnoVWPolo6N
By the way people, don't expect major increases in performance or so. Depending on your engine it can be quit small, for instance, an 1,6 8v AEE engine already has a 204 degree cam, so swapping it with a 219 degree one doesn't change that much. but a 1,3 8v ADX engine starts from 188 degrees on it's cam, now swapping for 219 does gain noticeble performance.
Eventhough, getting a 260+ sportscam is always the best option for performance, combine it with minor other up-grades (induction, fuel pressure, header/manifold) and your off getting quicker
Posted: Sat Apr 19, 2008 12:06 am
by polo-sib
Ah cheers, where is the best place to look around (think dealerships would stock new ones?) as I am very interested in getting this done now and now I know what to look for thanks to you. And I need the Mk3 GT polo? Just to make sure.
My change will be on the 1.4 8v Mk4 and maybe the AER 1.0 in the future lol
Thanks in advance and once again
Posted: Sat Apr 19, 2008 7:35 pm
by JarnoVWPolo6N
Got my old one from Ebay, german sold it to me for about 60 Euro's (dunno what that in pounds sterling is), best place to get one from cheaper is either Ebay or a scrapyard. Dealer would charge you a fortune I recon.
Posted: Mon Apr 21, 2008 1:29 am
by polo-sib
JarnoVWPolo6N wrote:Got my old one from Ebay, german sold it to me for about 60 Euro's (dunno what that in pounds sterling is), best place to get one from cheaper is either Ebay or a scrapyard. Dealer would charge you a fortune I recon.
Ah thanks will look into it, so i need the GT one, how much of a gain you think i will gain as on a mk4 1.4 8v?
Posted: Mon Apr 21, 2008 10:46 am
by JarnoVWPolo6N
polo-sib wrote:JarnoVWPolo6N wrote:Got my old one from Ebay, german sold it to me for about 60 Euro's (dunno what that in pounds sterling is), best place to get one from cheaper is either Ebay or a scrapyard. Dealer would charge you a fortune I recon.
Depends on any other mods already/to be made. Won't gain that much on a further standard engine, but will run "smoother & happier" on higher rev's
Posted: Sun May 18, 2008 3:14 am
by yosin
hmm sounds quite interesting....i have a1.4 AEX engine 8v...alot of difference to ur mates one as u sed earlier in the thread?/...
Posted: Mon May 19, 2008 9:00 pm
by JarnoVWPolo6N
yosin wrote:hmm sounds quite interesting....i have a1.4 AEX engine 8v...alot of difference to ur mates one as u sed earlier in the thread?/...
according to him, yes
Posted: Fri May 30, 2008 4:05 pm
by Higgo
so theres not really any point doing this to my 1.6 8v 6n then mate??
cheers Dan
Posted: Mon Jun 16, 2008 3:44 pm
by Hardcore
im still confused about this. a 1.4 8v. would i take the cam out of the 1.4GT orrr. from the 1.0GT or what lol?? does it matter?
Posted: Mon Jun 16, 2008 7:04 pm
by JarnoVWPolo6N
Hardcore wrote:im still confused about this. a 1.4 8v. would i take the cam out of the 1.4GT orrr. from the 1.0GT or what lol?? does it matter?
Are you serious about this?
my god, do you even know what a Polo GT is!? The GT's used to retrieve the cam from which is discussed here, is the GT from the mk3 Polo's, with engine-code 3F. This was a 1.3 8v with 75bhp. There have never been 1.4 or 1.0 GT-versions!
