Posted: Mon Jun 14, 2004 11:38 pm
Oh hell no, only when I have to get somewhere quick (or am trying to see how fast the car will go after some kind of change to it). It makes an awful noise and of course isn't very economical...... hence the main reason i was after the 5-speed. 65 up to 90 the engine is just too loud (at any throttle opening), particularly towards full speed. Much rather do 70-75 in a slightly higher gear and only change down when i really have to be somewhere.
I'm making it run in the 4500-5500rpm range for an extended period after all, and it's hard to make an argument that such treatment will do the engine or the fuel consumption any good. (Hell anything past 70 puts me into the 4000rpm range - ouch. rather stay at 3500 or less.)
Plus it tends to get me stranded in the outside lane uphill with the speed rapidly dropping thru the lower 80s and down, with a beemer behind and nowhere to pull across to
In my own driving experience, the more i open the throttle, the faster the engine spins and the car goes.. i don't have to open it wider at lower speeds on the level, unless it's really labouring (like... 1200rpm or less). And that's not a terribly good idea anyway - the car starts to shake.. it's only getting 20 spins per second from the engine after all, and with the 4-speed, thats what... maybe 20mph in top?
Against a major load, ie up a relatively steep hill, a speed lower (and higher?) than best torque will require a greater throttle setting to maintain the same speed, i'll grant that. But I have no qualms against changing down to go easier up a gradient!
S'not like i'm constantly going uphill, like i suppose the non-gearbox/roadwheel linked ECU might assume at 90mph.
(i suppose what that comes out to is attempting to produce the same acceleration in the higher gear as the lower, but thats not what im trying to do)
So what are the answers anyway?
