autolights
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Re: autolights
Post by Mart!n-GTI-DK »
I can't sat what the law says in other countries. But in Denmark It's not mandatory to have a rear foglight.
BUT if it is on the car it has to work. But I have changed put the left taillight and don't have the rear foglight anymore.
Also, I have never experienced fog so thick that a rear foglight made any difference in terms of seeing the car infront of me.
Watcher
autolights
Post by Watcher »
The problem with pin 6 that needs to be on pin 7 is only for cars with factory installed fog lights.
When i installed the kit on Martin's polo we had the same problem with the high beam, its a coding issue because they forgot to write it in the instructions. One of the last byte's you can choose high beam via kl 58, choose this and your high beam will work again...
Sent from my Aiiiiiiightphone
Re: autolights
Mart!n-GTI-DK wrote:I can't sat what the law says in other countries. But in Denmark It's not mandatory to have a rear foglight.
Ok :wink: ... I would like to have two reverse lights and I saw this picture. Seems like a good solution, but for my (r-line) would involve an extraordinary expense.
http://www.fob-schrank.net/product/2915
Re: autolights
Watcher wrote:The problem with pin 6 that needs to be on pin 7 is only for cars with factory installed fog lights.
Right. Anyway says that encoded correctly and then check it again when finished installation. In any case, this byte:
joelburbidge
Re: autolights
Post by joelburbidge »
i've found this
Plug Pin Cross-section Cable color Terminal
A 1 - - High beam relay output (Kl.56b) (When retrofitting high beam assist system)
A 2 2.5 ge / sw Left low beam output (Kl.56bL) (only for vehicles with stop-start system or for vehicles with gas discharge lamps)
A 3 - - Battery cut-off relay output
A 4 0.35 br / sw Output signal Interior light, door contact switch
A 5 0.5 gr Lamp for LED daytime running light right
A 5 1.0 ge / br Lamp daytime running light right
A 6 1.0 gr / ws Output rear fog lamp (only for vehicles with automatic stop-start system or retrofit headlights)
A 7 1.5 wh / ye / ye Input signal switch for fog lights
A 8 - - Output isolation relays for CAN-bus drive
A 9 - - -
A 10 0.5 gray / red Output motor for tailgate
A 11 1.5 vi / ws Output motor for central locking "lock" for all doors
A 12 1.0 vi / gr Output motor for central locking, driver's door
A 13 1.5 br / rt Output motor for central locking "safe" for all doors
A 14 2.5 br Input signal mass (31), Central
A 15 1.0 vi / ye Output motor for central locking, passenger door and rear doors
A 16 2.5 rt Input supply (30), Central
A 17 0.5 gn / rd Input unit for central locking, rear left door
A 18 0.5 gn / gr Input unit for central locking, rear right door
A 19 0.35 br / ye Input signal drivers side door switch
A 20 0.35 br / rt Door switch input signal, passenger side
A 21 0.5 green / yellow Input unit for central locking, passenger door
A 22 0.5 gn / bl Input unit for central locking, driver's door
A 23 0.5 vi / ws Input signal button for unlocking in the tailgate handle
A 24 0.5 green / yellow Central input signal, the driver's door
A 25 0.35 br / gn Input signal Interior Locking Button
A 26 0.5 br / ws Door switch input signal, rear right door
A 27 0.5 sw / gn Input signal bonnet contact switch
A 28 0.5 bl / ye Input signal hazard light button
A 29 0.35 br / sw Input signal horn activation
A 30 0.5 gn / bl Input signal tailgate lock, position 2
A 31 0.5 bl / rd Input tailgate lock, position 1
A 32 0.35 sw / gn Input signal indicator switch right
A 33 0.35 black / white Input signal indicator switch left
A 34 0.35 br / gr Door switch input signal, rear left door
A 35 - - Output control unit for sliding roof
A 36 0.5 rd / ye Signal off seat heating
A 37 - - Input signal switch for automatic light control (Kl.AFL)
A 38 1.0 bl / bl Output heated exterior mirrors
A 39 - - Input signal ground (terminal 31)
A 40 0.5 gray / red Output signal lamps for parking light right (Kl.58R)
A 41 0.5 gr / sw Output signal lamps for parking light left (Kl.58L)
A 42 0.5 bl / br Input supply (Kl.86s) for Ignition
A 43 0.35 black / red Input signal brake pedal position sensor
A 44 0.5 bl / bl / black / yellow Input, plus compound 2 (Kl.15a) in interior wiring harness
A 45 0.5 gr / ye Input signal for parking light, light switch position "parking light" and "headlight" / (Kl.58_in)
A 46 - - -
A 47 - - -
A 48 - - Output control unit for sliding roof
A 49 0.5 vi Output relay for headlight washer system
A 50 - - -
A 51 - - Output relay for entry-level and footwell lights
A 52 0.5 bl / ye Output relay for fuel supply
A 53 - - -
A 54 0.5 black / red Input supply (75a) for Zündanlassschalter1)
A 55 0.5 vi / gr Output relay for starter interlock (only vehicles with automatic transmission)
A 56 0.35 gr / bl Output signal indicator for warning lights
A 57 0.35 bl / gn Output indicator light for indoor surveillance shutdown
A 58 0.35 red / black Output indicator light for SAFE operation of the Central
A 59 0.35 br / gr Output indicator light for interior locking
A 60 0.35 wh / ye Output indicator light for heated rear window
A 61 - - -
A 62 0.5 wh / gn Output high beam (+ Kl.56aL Kl56aR) (only for vehicles with stop-start system or for vehicles with gas discharge lamps)
A 63 2.5 - Input supply (30), left headlight (only for vehicles with stop-start system)
A 64 1.0 black / red Input supply (30), heated outside mirrors
A 65 1.0 red / black Output power (30G), interior light and trunk light
A 66 1.0 rt / vi Input supply (30), Indoor Lighting
A 67 - - -
A 68 2.5 rd / ye Input supply (30), windshield (only for vehicles with stop-start system)
A 69 2.5 ws / sw Output wipers, position 1
A 70 2.5 br Input signal for wiper mass
A 71 2.5 green / yellow Output wipers, 2 position
A 72 1.5 black / yellow Output signal horn
A 73 2.5 rd / ye Input supply (30), horn
B 1 1.0 gray / red Input control for switch and instrument lighting (58)
B 2 2.5 gr / vi Right low beam output (Kl.56bR) (only for vehicles with stop-start system or for vehicles with gas discharge lamps)
B 3 0.5 gr / ye Lamp LED daytime running lights left (Kl.TFL)
B 3 1.0 ge / br Lamp daytime running light left (Kl.TFL)
B 4 - - -
B 5 0.5 gn Parking light, front left (Kl.58l)
B 6 0.5 gn / ws Auxiliary light right (Kl.58r)
B 7 1.0 gr / bl Plus connection (58) panel wiring, parking and driving light position light switch T17/16 (only with stop-start system)
B 8 - - -
B 9 1.5 wh / ye Output signal lamp for fog lamp left
B 9 1.0 wh / ye Output signal lamp for cornering left for vehicles with gas discharge headlights, Kl.ABL_L
B 10 1.5 wh / ye Output signal lamp for fog lamp right
B 10 1.0 vi Output signal lamp for cornering right for vehicles with gas discharge headlights, Kl.ABL_R
B 11 1.0 sw / gn Input supply (30), fog lamps for
B 12 0.35 bl / bl Output signal reversing lights (cars with automatic or automatic light retrofit)
B 13 1.5 rd / ye Input supply (30), flashing light and brake light
B 14 1.5 black / white Output signal flashing left (class L)
B 15 1.5 sw / gn Output signal flashing light right (Kl.R)
B 16 1.0 ws Output signal brake lights
B 17 0.35 vi / ws LIN bus, door control unit in the steering wheel and shift lever
B 18 0.35 or / br CAN low drive
B 19 0.35 or / sw CAN high, drive
B 20 0.35 or / gn CAN high, comfort
B 21 0.35 or / br CAN low, comfort
B 22 0.35 or / br CAN low diagnostic
B 23 0.35 or / sw CAN high, diagnosis
B 24 0.35 vi / ws LIN bus control unit for sliding adjustment, rain and light sensor for detection, sensor for indoor surveillance
B 25 - - Input contact closed door left
B 26 - - Input contact closed sliding door right
B 27 0.5 wh / gn Wiper input signal, position 1
B 28 0.5 bl / ye Central input signal, passenger door
B 29 0.5 gr / vi Input, "0" position light switch
B 30 0.35 vi Input signal switch for deactivation of the interior monitoring
B 31 0.35 wh / rd Input signal switch for heated rear window
B 32 0.5 gn / bk Limit switch input signal for windshield wipers
B 33 - - -
B 34 0.5 gr / bl Output signal lighting - Switches and instruments (58d)
B 35 - - -
B 36 0.5 vi / ws LIN bus, alarm horn
B 37 0.5 gr / ws Signal (K) Diagnosis
B 38 1.5 br Input to ground (31), for electronic
B 39 0.5 red / white Input signal supply (30) for electronic
B 40 - - -
B 41 - - -
B 42 0.35 sw / gn Brake contact switch input signal
B 43 0.35 gr / sw Input signal switch for rear fog light (Kl.NSL)
B 44 0.35 bl / ye Input Signal "set" speed control system
B 45 0.35 ws Input signal "on / off" cruise control
B 46 0.5 bl / vi Input signal "reset" cruise control
B 47 0.35 bl / wh Input Signal "Cancel" cruise control
B 48 0.5 bl / bl Input signal switch for reversing light
B 49 0.5 bl (L) signal generator
B 50 0.5 red / black Input signal Starterrelais1)
B 51 0.5 black / red Input supply (75a) for Ignition
B 52 0.5 ws Input signal power washer pump / switch for driving lights (Kl.FL)
B 53 0.5 green / yellow Wiper input signal, position 2
B 54 - - -
B 55 0.5 vi / sw Starter interlock signal (only for vehicles with automatic transmission and without start-stop system)
B 56 - - Input clamping unit for tailgate
B 57 - - -
B 58 0.35 sw / gn Input signal switch heated mirrors
B 59 0.5 rd / ye Input signal for the reference voltage (30)
B 60 0.5 br Input signal for mass - reference voltage (31)
B 61 0.5 gn / rd Output motor for washer pump and motor for rear window wiper
B 62 0.35 br / gn Input signal intermittent wiper circuit
B 63 2.5 ws Output heated rear window
B 64 - - -
B 65 - - -
B 66 - - -
B 67 2.5 rd / ye Input supply (30), heated rear window
B 68 1.5 red / white Input supply (30), headlight right1)
B 69 - - -
B 70 - - -
B 71 - - -
B 72 - - -
B 73 - - -
joelburbidge
Re: autolights
if i was to wire the front foglight into the bcm would that help?
Mart!n-GTI-DK
Re: autolights
What if you change the High beam to 58 in vagcom?
joelburbidge
Re: autolights
It was already on and I switched off to see if that would work and nothing
Re: autolights
Confirm that you have bcm encoded exactly as in the last page of this document.
https://docs.google.com/file/d/0B2nv91Y ... szY00/edit
With the data pins of the connectors A and B you posted should fix the problem.
Check relays and connectors again.
Send a message to Kufatec if they have information we do not know.
joelburbidge
Re: autolights
well i did exactly what the kufatec kit says to do, i sent them an email today and i'm waiting on a reply from them
Watcher
autolights
Post by Watcher »
Im guessing that something isnt connected correctly in the bcm.
If you want i can try and look at your coding via teamviewer to see if everything is correct there... But im gussing its a fault in the wiring.. It can be kinda hard to see what is printed on the wires and even harder to see the correct pin number at the connectors in the bcm because of the lack of room up there
joelburbidge
Re: autolights
well i did not fit the wires into the bcm i paid out for an auto electrician to do it who has past experience fitting these sorts of kits but he had never done a polo 6r, i original coded the car and then they checked it over, they installed it exactly as the instructions stated at the same time they installed the front fog lights taking the wire to the fuse box and then to the switch itself i don't know whether the wiring for the front fog light is meant to go into the bcm but the kufatec kit for it looked like that how it is meant to be i doubt that is how they do it in the factory so that may be contributing to the problem with the rear fogs, but i don't understand why the auto function wont work
Re: autolights
I say the same thing Watcher, I guess the wire installation is not correct.
Check to Auto:
Remove the 10-pin connector Auto light switch, removed the connector A to the BCM, with a multimeter check continuity between pin 2 10-pin connector and pin 37 of connector A of the BCM. If it beeps, well installation. If it's not, it's wrong.
Image Image
For front and rear fog lights on this link to the french forum have the solution for both. (Required Registration) Page 8,9,10.
http://www.polo6r.fr/t7363p140-info-nou ... ur-la-polo
Kufatec propose two solutions in a message received by a forum user.
You'll have to translate the German and French. (Easy with google translator)
joelburbidge
Re: autolights
The bcm itself or the plug?
Re: autolights
The plug.
