TheFrog's Blue GT 6C
Re: TheFrog's Blue GT 6C
has doing the boot and under rear seats made alot of difference? i find most noise seems to be wind noise from the doors. Must be a 3dr thing
- Mart!n-GTI-DK
- Drives: '14 Polo BlueGT
It is incredibly easy to both remove and reinstall the doorcards. I took mine off when I got it rust protected to get best possible coverage.
(I then used the oppertunity to put in the cards from the R WRC interior I had bought now they were off anyways.
98octaneblood
- Drives: Blue GT MY15
Nice car TheFrog
TheFrog
- Drives: 2015 Blue GT
Cheers98octaneblood wrote:Nice car TheFrog
@Martin: can you describe how you removed the door cards? Screws, plastic clips...? Do you have a photo of what the door looks like once the card is removed?
TheFrog
TBH, not really. The BGT is already very quiet and refined, but as I said, I have access to cheap Dynamat, so I did it anyway. I may put the Helix sub in the wheel well one day, so that's why I Dynamatted that area. I would like to do the doors, as I like the 'whump' sound Dynamatted doors make when you close them.Mayhem wrote:has doing the boot and under rear seats made alot of difference? i find most noise seems to be wind noise from the doors. Must be a 3dr thing
TheFrog
Lol, Mr Polo Encyclopaedia to the rescue again. Thanks
For good people, good help.
TheFrog
Muy amableciclo wrote:For good people, good help.
- Mart!n-GTI-DK
Ciclo beat me too it.
But i can still show you what the door on a 2 door Polo looks like.
TheFrog
Very useful, thanks. Isn't there any sort of polythene sheet covering the door once you take the card off? Also, is that big black area a hole or a cover? Can you access the outer skin of the door (which is where I would want to Dynamat)?
- Mart!n-GTI-DK
Yes the big black piece is just a plastic cover you can pop out to get to the inner part of the door.TheFrog wrote:Very useful, thanks. Isn't there any sort of polythene sheet covering the door once you take the card off? Also, is that big black area a hole or a cover? Can you access the outer skin of the door (which is where I would want to Dynamat)?
But the ones I have seen with sound absorbant material on the doors have put it just behind the doorcard. it should work very well.
And other than a few square pieces of foam on the back of the card there is covering. They only use the polythene sheets when there is direct access to the window mechanisme behind the door card. Bot here its still closed off when the doorcard is off.
(I'm tired of writting 'door card' now.
TheFrog
OK, thanks. How fragile are the retaining clips on the door card? I have found on other cars that they are often very easy to deform or break.
JB1891 wrote:Hi guys, new to the forum so this is my first post. Nice looking car TheFrog, I'm currently waiting for my 3dr white GT to arrive for a March deliveryJust had an email today to say that it's moved to step five and on it's way, quick question, how long does it usually take to arrive at the dealers?
Also, do you have a part no for the chrome exhaust trims, they look great and just finish the car off![]()
Thanks...
- Mart!n-GTI-DK
they are very strong.TheFrog wrote:OK, thanks. How fragile are the retaining clips on the door card? I have found on other cars that they are often very easy to deform or break.
