Benzinkopf's 2012 VW POLO 6R MK5 1.2TSI 105HP DSG
Re: Benzinkopf's 2012 VW POLO 6R MK5 1.2TSI 105HP DSG
iichel wrote:i must say, i'm not a big fan of the screw terminals in cars. i would recommend to use a crimp terminal or a soldering connection.
The crimp is more effective than the welds in automotive wires, the welds must be avoided as far as possible.
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
By welds you means? Soldering?
Yep, soldering with lead and tin.
benzinkopf
Hi guys. Anyone know what's the locking bit setting in IC for?
I tried to change to "unlock" but it requires security access which i dont know.
Another option is
Just wanna know what are these for. Tq.
Hmm...Try with 25327 security access. :?:
benzinkopf
Thx ciclo. But unfortunately it doesnt accept the code.
Btw, after a bit googling, i found out that "display depiction" is all about changing the color mfd to carbon fibre design which is unrelated to polo i guess.
CNK
Drives: 6R
Post by CNK »
benzinkopf wrote:Btw, after a bit googling, i found out that "display depiction" is all about changing the color mfd to carbon fibre design
True, it's possible in Golf MK7:
Thanks for the info.
benzinkopf
CNK wrote: True, it's possible in Golf MK7:
Tq cnk. But pls dont show any mfd+++ unit to me right now[emoji24]
Btw, just sharing, there're 4 versions of seatbelt warning in the adaptation channel for IC, but i can only enable and test 2 of them. Version 1 and 4.
CNK
Drives: 6R
Post by CNK »
benzinkopf wrote:
CNK wrote: Tq cnk. But pls dont show any mfd+++ unit to me right now[emoji24]
Look here:
:arrow: https://www.drive2.ru/l/10569387/
:arrow: https://www.drive2.ru/l/458361109926128858/
:twisted: :twisted: :twisted:
benzinkopf
Yes. I tried to look at the compatibility of 6C-IC and 6R-IC in term of the outside casing/cover. But it seems that its not possible if we just want to swap the top/front cover. For the mod, you really need to dismantle both IC, take our ur 6R components and put in the 6C casing, means you need to cut out the connector area, buzzer area as well as some ventilation area. Quite a mess.
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
benzinkopf wrote:Hi guys. Anyone know what's the locking bit setting in IC for?
Another option is
Because of this bit locked, you cannot change many settings on you IC. But if you could unlock it you could change everything you want, even odometer
As I know since 2009 to 2011 cluster has common security access code. After that IC got various access codes which depending the VIN.
Code 25327 on some IC opens the immobilizer rewriting procedure .
IC on cars after 2015 gets very difficult protection, and I suppose it impossible unlock this bit since it have been locked once.
benzinkopf
Happy holiday guys!
Finally completed the installation for bcm max from firegrafik with help from our best man on earth ciclo who know best!
Together with the bcm, i installed auto light switch, CH(manual)/LH (auto),LED light for rear plate and wiper washer fluid level sensor as well as the wiring ready for HBA and ambient lighting(i believe).
However, i found out the followings;
1) as i'm still with 6R0 stalk w/o the return spring, the high beam activation will remain on even after i pull back the stalk. I need to flash the HB again to switch it off. I know the wiring is ready for HBA which make sense, but is there any coding so i can use the flash stalk normally?
2) With vcds autoscan, i always get that my control module for auto trans(02-dsg) is not reachable. but if i open the controller module individually, it seems found it and no issue.
3) is there anyway to make the CH auto?
4) rain closing can be activated by the coding. But with no luck, its not functioning. Perhaps it depends on door control module?
Here's the latest autoscan:
Sunday,25,December,2016,11:53:28:15298
VCDS Version: 16.8.4.2 (x64)
Data version: 20161129 DS267.0
www.Ross-Tech.com
Workshop Code: 123 12345 012345
Chassis Type: 6R (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 2E 44 56 77 0B
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB) Labels: 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 HF HW: 03F 907 309 J
Component: SIMOS10.22H03 2698
Revision: --H03--- Serial number:
Coding: 002500F6202400080000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM12TFS02103F906070HF 004004
ROD: EV_ECM12TFS02103F906070FP.rod
VCID: 6DDBC694BCAA3C2A12-8038
Readiness: 0000 0000
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 230228E3416E00B4C42C14E382D800801700
Shop #: WSC 31414 790 31414
VCID: 0717943CB216F67A88-8052
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 326115E86D14A3D20F-8066
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 HW: 7E0 937 090
Component: BCM PQ25 Max4 H80 0733
Revision: B9080001 Serial number: 0771 139150190
Coding: 3CB02BFF48A10E0013380EB07CAB9ED91BC0612F608C2000200000030800
Shop #: WSC 12345 123 12345
VCID: 68D5B7809B48190261-803C
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 180812 05 54 0403
Coding: 06302D
Subsystem 2 - Part No SW: 6R0 959 802 AB HW: 6R0 959 802 AB Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU030061100013270
Coding: 18BC30
Subsystem 3 - Part No SW: 6R0 959 801 AD HW: 6R0 959 801 AD Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU001071100011802
Coding: 08BC30
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 6 - Part No SW: 5K0 959 542 B HW: 5K0 959 542 B
Component: E221__MFL-TAS H30 0032
Serial number: 0122863
Coding: 830000
Subsystem 7 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU030061100015373
Coding: 08BC32
Subsystem 8 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU001071100015810
Coding: 08BC32
Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
Part No SW: 6R0 919 475 B HW: 7E0 919 475
Component: PARKHILFE 4K H11 0012
Revision: -------- Serial number: 47301119600512
Coding: 108101
ROD: EV_VW250ParkiAssis2.rod
VCID: 3D7B36D4AC4A6CAAE2-8068
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Component: VW10Airbag027 H09 0020
Revision: -------- Serial number: 003GX00RY8XP
Coding: 003237
VCID: 4A916D08ED84CB1257-801E
Serial number: 3575HRB405H0IRE2COP8
Serial number: 3585HRB405J0ISD6C8T3
Serial number: 3515RRB405J0LMIQ6PBL
Serial number: 3525RRB405H0LMIQCGRX
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 860 H HW: 6R0 920 860 H
Component: KOMBI H03 0505
Coding: 140C01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
VCID: 397322C4B862508ACE-806C
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H80 0733
Revision: B9080001
Coding: 002300
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H03 0505
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6AD1CD888D442B1277-803E
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7660415697
Coding: 010000
VCID: 2953F28440C2E00ABE-807C
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 31414
VCID: 2F671C9CEA268E3A60-807A
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 B HW: 5K0 035 190 B
Component: Radio RCD510 005 0236
Revision: 00000001 Serial number: VWZ1Z3N1941321
Coding: 09000401020001
Shop #: WSC 43038 123 12345
VCID: 244DE3B027E03D628D-8070
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007663752927
Coding: 0110000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3A713DC8BD645B92C7-806E
End-------------------------(Elapsed Time: 03:25)--------------------------
Anyway, its a fantastic experience with the installation and superb support from ciclo!
benzinkopf
Latest fusebox
Latest Relay carrier
You did the whole installation yesterday and nothing is perfect until it is solved properly.
Have patience, it's Christmas or Holidays for many people. :?
