Page 4 of 19
Re: ☼ POLO 6R. WIRING LOOMS. Automatic lights. BCM Max. Light Assist. ☼
Posted: Fri Mar 16, 2018 12:07 am
by R Line
Hi Fernando, im Victor from Barcelona,
I am interested in a kit, I send a message to private mail.
I have a 6R (Jun 2013) just like yours R Line, Bixenon and RLS factory.
Thanks!
Posted: Fri Mar 16, 2018 8:01 am
by ciclo
Hola, bon dia, check your email inbox.
Posted: Wed Mar 21, 2018 10:43 am
by R Line
Thanks Ciclo! Kit received, super fast delivery in spectacular packaging! Now wait for the rest of the components to upgrade
Posted: Wed Mar 21, 2018 11:16 am
by ciclo
The goods must always be protected in the best possible way.
Thanks for your comment.
Now you only need to polish the rough diamond I sent you... following the installation guide.
Posted: Mon Mar 26, 2018 8:59 pm
by airknight
Hi Ciclo,
I'm interested in buying a CH/LH auto-light cable (A) from you.
I have a 1.2 tdi bluemotion with a 88D BCM and retrofitted OEM Xenon. the xenon is installed with only straight adapters for now, but I plan to re-install them the proper way over the BCM.
Is this cable suitable for me in current /new situation regarding the Xenon headlights?
Thanks in advance for your answer.
Posted: Mon Mar 26, 2018 9:26 pm
by ciclo
Hello airknight
Yes, it's suitable.
I send you a private message with my email. Look at your inbox.
You have to send me a
recent autoscan to my email. Thanks.
Posted: Wed Mar 28, 2018 6:37 pm
by vento2013
Hi, Fernando,
I am from India, I have 6R 2013 Polo sedan(Vento). I want to upgrade my car H4 single beam headlights with OE Bi xenon, and RLS with auto dimming IRVM, now I would like to buy wiring 'B' BCM max adaption, Auto lights with CH/LH.
I have sourced all parts, and I read graaja and smg_shardul's thread, and understood all the work involved.
Now shall I post scan report and other pictures here in this thread?
Thank you very much Fernando, for giving such kind support for upgrading our ride..
Posted: Wed Mar 28, 2018 7:11 pm
by ciclo
Hello vento2013 welcome
Thanks for your kind words.
I'll make your Wiring loom 'B' (BCM adaptation + Automatic lights). You have to open a new topic in the forum and post the requested information, here
6R / 6C section, so that it can provide you with
the best technical support during all the installation processes (as many others received it).
Example:
Graaja's personal topic
Once the resquested information is posted I will make your Wiring loom, then we get in touch by email to explain you the payment and shipping processes.
Requested information
Pictures from:
Relay carrier
Light Switch connector
Dimmer connector
Fuse box
New BCM.
VCDS Autoscan. Recent.
Posted: Wed Apr 18, 2018 9:59 am
by R Line
Hello Fer, after almost 4 weeks of testing with the new CH / LH lights installed on my R line -thanks to you- I can not be happier and more grateful. It is without a doubt the best car update.
I recommend 100% change, definitely worth it!
[youtube]
https://youtu.be/5qrgnV1mIFA[/youtube]
[youtube]
https://youtu.be/ra_VXAg6N2o[/youtube]
[youtube]
https://youtu.be/eVsNHvMVtGI[/youtube]
Posted: Thu Apr 19, 2018 4:18 am
by ciclo
Thank you very much Vic, you are very kind with your feedback.
Automatic lights for the entire useful life of your 6R R-line, otherwise, contact me and we solve it
fastly.
Posted: Mon May 28, 2018 10:17 pm
by danikd
Hello ciclo,
can you pls send me PM, I am newbie here and cant send PM for the present. need one special set from you ... thx a lot for great work ... Daniel
Posted: Tue May 29, 2018 4:13 am
by ciclo
Hello Daniel, welcome.
Thanks for your interest in my wiring looms
and your comments.
Please tell me what you need here and I will tell you with
exquisite precision what you have to do.
It is not complicated for me to understand what your Polo 6R will need.
Post a VCDS autoscan here, everything will be easier from the moment you do it.
Greetings
Fernando
Info-Note:
You need at least 10 post in the forum to be able to use the forum's private messaging.
It is a very easy rule to fulfill.
Posted: Tue May 29, 2018 9:10 am
by danikd
Hello,
thx for goodwill. my car is Citigo, not Polo, but share same type of BCM, pinout and after BCM swap ( for max version because of MFSW ) there are 3 errors on VCDS.
Dash was repined to 54/57 BCM, all works OK. But only this 3 errors ... is same as in polos...
And I have retrofitted RLS nad want to add original auto light switch, as your harness working ...
Will be your harness working? Schemes are same as on Polo ...And which variant is for this solution? A, B, B0 ? Or is harnes same and difference is only coding and your support?
It can be very interesting for you, because many Citigo/Up! owners want autolight retrofit ...
Dont know why I cant attach txt file, so at least errors and BCM type ....
Pls, let me know. Nice day!
Daniel
Address 09: Cent. Elect. (J519) Labels: 1S0-937-08x-09.clb
Part No SW: 1S0 937 090 F HW: 1S0 937 090
Component: BCM PQ25 1MX4 H81 0744
Revision: BW081001 Serial number: 0978 133170077
Coding: 6CB82B0000010000000800042C28A6C000C0400C60020000200000400000
Shop #: WSC 12345 123 12345
VCID: 365372AD67C3C0DB25-8062
Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 111115 03 37 0059
Coding: 0080DD
Subsystem 2 - Part No SW: 5E0 919 719 L HW: 5E0 919 719 L
Component: E221__MFL-PR6 H02 0160
Serial number: 000000000B0452131116
Coding: 820000
3 Faults Found:
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 1
Mileage: 60787 km
Time Indication: 0
Date: 2017.09.10
Time: 04:19:02
03432 - Activation of Right Parking Light
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 1
Mileage: 60787 km
Time Indication: 0
Date: 2017.09.10
Time: 04:19:02
01516 - Terminal 30; Left
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 1
Mileage: 60787 km
Time Indication: 0
Date: 2017.09.10
Time: 04:19:02
Posted: Tue May 29, 2018 9:38 pm
by ciclo
VIN, tenth digit.
https://uk-polos.net/viewtopic.php?f=62&t=69223#p516196
Full VCDS autoscan, please. Copy and paste here.
You must open a new topic in the 6R section of the forum. For example,
BCM Max PQ25, adaptation. Automatic lights. Skoda Citigo
It will be an interesting topic.
You have to provide a lot of information, I need pictures of your Citigo to know the factory equipment.
Read B, resquested information. (
for example)
You need the wiring looms B. Wiring for BCM adaptation and wiring for automatic lights.
I will study the Citigo wiring diagrams when you provide me with the Model Year of your Citigo. (VIN, tenth digit).
Even within the same vehicle model there are differences in the original wiring depending on the year of manufacture.
Posted: Wed May 30, 2018 7:25 am
by danikd
Thx for info.
its possible to install only autolights harness, without max BCM adaptation? Original autolight is primary reason to do it ... because china non-original autoheadlight works "strange" ...
BCM max retrofited ( only the 3 errors ), from factory there was 086B BCM ...
Thx for info and have a nice day! Daniel
