numberior´s 2011 Polo 6R GTI DSG
numberior
Drives: Polo GTI 6r
Re: numberior´s 2011 Polo 6R GTI DSG
Post by numberior »
ciclo wrote: Tue Oct 24, 2017 11:58 am The BCM adaptation channels appear to be correct according to VCDS reading.
TESTS:
Current BCM coding
3CB02BBF08A1000008380C916C2B0CD05AC0670F60051040200000030000
Try with these BCM codings
1st
3CB02BBF08A1000008380C916C2B0CD05AC0470F60051040200000030000
check for faults
2nd
3CB02BBF08A1000008380C916C2B0CD0DAC0470F60051040200000030000
check for faults
3rd
3CB02BBF08A1000008380C916C2B0CD0D2C0470F60051040200000030000
check for faults
By the way, all of the above is by assuming your high beams are working correctly despite the faults. According to your electrical installation the BCM does not have a diagnostic control over the highbeam lamps, it only controls the switching (lowbeam/highbeam) to activate the shutters (T73a/62).
What is the donor car of your 7E0 BCM? Where did you buy this 7E0 BCM? Do you have its PR-codes?
Hi Ciclo,
I bought it on ebay: http://www.ebay.com.sg/itm/Polo-Caravel ... 2749.l2649
These are from my BCM Max. Will it help?
It was listed as new, looks new and factory state was enabled.
I'm going to try out the BCM codes in a while.
Will report back soon. :)
numberior
Drives: Polo GTI 6r
Post by numberior »
Hi Ciclo,
I've tested the codes.
For each of them:
I cleared all DTCs.
Entered BCM coding.
Performed autoscan.
Activated high beam.
1st
Tuesday,24,October,2017,22:44:13:27502
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ6RZBY312116   License Plate: 15TH SCAN-1ST TEST
Mileage: 100380km-62373mi   Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 55 56 0B
VIN: WVWZZZ6RZBY312116   Mileage: 100380km-62373miles
56-Radio -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAVE)       Labels:. 03C-907-309-V1.clb
   Part No SW: 03C 906 027 AR    HW: 03C 906 027 AR
   Component: 1.4l R4 TSI   H15 9971
   Revision: L2H15---    Serial number: 00000000000000
   Coding: 00250012002400000000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_ECM14TSI01103C906027AR 001014
   ROD: EV_ECM14TSI01103C906027AR.rod
   VCID: 71E99E02A0C274CE75-8024
Readiness: 0000 0101
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 230248E3416E02B4C42612E382D740811700
   Shop #: WSC 00788 648 00255
   VCID: 071DD0DAB2465A7ECB-8052
   Part No SW: 6R0 907 044 E    HW: 6R0 907 044 E
   Component: Climatronic   H09 0609
   Revision: V0000000
   VCID: 35616A129C2A18EE69-8060
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 321160318
   Coding: 3CB02BBF08A1000008380C916C2B0CD05AC0470F60051040200000030000
   VCID: 2A5B496E45944716F4-807E
   Subsystem 1 - Part No SW: 6R0 959 802 AB    HW: 6R0 959 802 AB  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  007 1611
   Serial number: KU0KU024031100012688
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 801 AD    HW: 6R0 959 801 AD  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  007 1611
   Serial number: KU0KU016031100015781
   Coding: 08BC30
   Subsystem 3 - Part No SW: 6R0 959 591 A    HW: 7P0 959 591
   Component: J245 PS72.015  H05 0006
   Serial number:     WOO1165901/
   Coding: 081001
   Subsystem 4 - Part No SW: 5K0 959 542     HW: 5K0 959 542
   Component: E221__MFL-TAS  H05 0010
   Serial number: 0050759
   Coding: 830000
   Subsystem 5 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  007 1611
   Serial number: KU0KU011041100017315
   Coding: 08BC32
   Subsystem 6 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  007 1611
   Serial number: KU0KU011041100013053
   Coding: 08BC32
   Part No SW: 6R0 959 655 M    HW: 6R0 959 655 M
   Component: VW10Airbag01E H09 0020
   Revision: --------    Serial number: 003GZ000HCNK
   Coding: 003145
   VCID: 4C972FF6E7A0792626-8018
   Serial number: 3575HRB40550HJHG9ON%
   Serial number: 3585HRB40590HJHG919A
   Serial number: 3515RRB405B0I4AG6OGL
   Serial number: 3525RRB404R0H4DUHPLR
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 6R0 920 870     HW: 6R0 920 870
   Component: KOMBI         H21 0320
   Coding: 140A00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
   VCID: 72EB910EA5C44FD68C-8026
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 002300
   VCID: 68DFF3669B18B50622-803C
1 Fault Found:
01304 - Radio
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 10
                    Mileage: 100245 km
                    Time Indication: 0
                    Date: 2012.03.13
                    Time: 23:57:39
   Component: IMMO          H21 0320
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6ADB896E8D14871634-803E
   Part No: 6R0 423 156 B
   Coding: 11221
   Shop #: WSC 31414
   VCID: 2F6D587AEA76223E23-807A
   Revision: --------    Serial number: --------------
   Coding: 0114000001000000
   VCID: 77FDA01ACEA62AFEBB-8022
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 03:02)--------------------------
2nd
Tuesday,24,October,2017,22:50:31:27502
www.Ross-Tech.com
Cannot be reached
   Revision: --------
   Revision: V0000000
   Coding: 3CB02BBF08A1000008380C916C2B0CD0DAC0470F60051040200000030000
   Coding: 18BC30
   Coding: 08BC30
   Coding: 081001
   Coding: 830000
   Coding: 08BC32
   Coding: 08BC32
   Coding: 003145
   Coding: 140A00
   Revision: B9081001
   Coding: 002300
1 Fault Found:
01304 - Radio
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 10
                    Mileage: 100245 km
                    Time Indication: 0
                    Date: 2012.03.13
                    Time: 23:57:39
   Serial number:
   Coding: 11221
   Shop #: WSC 31414
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:59)--------------------------
3rd
Tuesday,24,October,2017,22:56:50:27502
www.Ross-Tech.com
VIN: WVWZZZ6RZBY312116   License Plate: 17TH SCAN-3RD TEST
Cannot be reached
   Revision: --------
   Revision: V0000000
   Coding: 3CB02BBF08A1000008380C916C2B0CD0D2C0470F60051040200000030000
   Coding: 18BC30
   Coding: 08BC30
   Coding: 081001
   Coding: 830000
   Coding: 08BC32
   Coding: 08BC32
   Coding: 003145
   Coding: 140A00
   Revision: B9081001
   Coding: 002300
1 Fault Found:
01304 - Radio
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 10
                    Mileage: 100245 km
                    Time Indication: 0
                    Date: 2012.03.13
                    Time: 23:57:39
   Serial number:
   Coding: 11221
   Shop #: WSC 31414
Address 56: Radio
Cannot be reached
All of your 3 test codes seem to have solved the high beam bulb error.
Then I reverted to the original coding: 3CB02BBF08A1000008380C916C2B0CD05AC0670F60051040200000030000
Error came back instantly.
Currently I'm on the 1st test code.
Thank you for your help!
VIN: WVWZZZ6RZBY312116 License Plate: 17TH SCAN-3RD TEST ................. :lol: :lol: :lol:
Excellent! a new discovery in the fantastic world of BCM PQ25. (with 7H0 BCMs this would not have happened)
The 1st it's perfect. :wink:
Now,
New BCM coding:
3CB02BBF08A1000008380C916C6B0CD05AC0470F60053040200000030000
Check the Coming Home function through bixenon (without RLS).
- ignition off (key removed)
- pull from high beam stalk (one touch/flash)
- open the driver's door.
- the lights turn ON.
numberior
Drives: Polo GTI 6r
Post by numberior »
Hi Ciclo,
Will put in the code tomorrow :mrgreen:
Thanks for making my bi-xenon (and BCM Max upgrade) retrofit a success!
I'm glad to be able to contribute a little, even by accident :lol:
I think I want to do the headlight washers next.
Would you be able to help me with this Ciclo? I don't really trust the Kufatec's retrofit kit and rather do the harness(es) myself.
numberior
Drives: Polo GTI 6r
Post by numberior »
Hi Ciclo,
Is it possible for DRL to dim and not totally turn off on the side that blinks?
https://www.youtube.com/watch?v=G_ZkCvlS2Gw
numberior wrote: Wed Oct 25, 2017 5:11 pm I think I want to do the headlight washers next.
The wiring diagram image for this retrofit is somewhere in the forum, several users did it. Search...
The kufatec kit is perfect for your car. (Model Year A, B, C)
numberior wrote: Wed Oct 25, 2017 5:34 pm Is it possible for DRL to dim and not totally turn off on the side that blinks?
Ok, that's a 6C.
For the 6R and electronically speaking it is not possible, there is always some point or legality* in which it fails.
* for those who use the Scandinavian mode (parking/side lights ON witn terminal 15 ON ---> so, light switch in "0" position).
IMHO it's better with the DRLs totally OFF when blinking, ... what is trying to achieve with this function is that others see clearly your blinkers to know what intentions you have when you want to maneuver.
numberior
Drives: Polo GTI 6r
Post by numberior »
Glad to hear that.
Ok, that's a 6C.
Thanks for explaining Ciclo.
numberior
Drives: Polo GTI 6r
Post by numberior »
Hi Ciclo,
Before my bi-xenon retrofit, I had a shop replace engine mounts for me.
They screwed up somehow, damaged my ECU and had to replace it for me.
It was only recently I discovered my cruise control is no longer working.
I have set the engine byte and BCM byte as needed:
www.Ross-Tech.com
Cannot be reached
   Revision: --------
   Revision: V0000000
   Coding: 18BC30
   Coding: 08BC30
   Coding: 081001
   Coding: 830000
   Coding: 08BC32
   Coding: 08BC32
   Coding: 003145
   Coding: 140A00
   Revision: B9081001
   Coding: 002300
1 Fault Found:
01304 - Radio
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 10
                    Mileage: 100245 km
                    Time Indication: 0
                    Date: 2012.03.13
                    Time: 23:57:39
   Serial number:
   Coding: 11221
   Shop #: WSC 31414
Address 56: Radio
Cannot be reached
However, when I try to enter the activation code via engine-> login, the button is grey out.
I guess I need the security access before I can login?
I would rather sort this out myself than going back to the garage. Downtime is one day they say.
Maybe go your BCM, select advanced measurement values, type cruise in the search box and test all the buttons.
numberior
Drives: Polo GTI 6r
Post by numberior »
iichel wrote: Thu Oct 26, 2017 4:36 pm Maybe go your BCM, select advanced measurement values, type cruise in the search box and test all the buttons.
Thanks iiche for showing this useful featurel!
Tested all buttons working.
Do I need to re-activate it?
numberior wrote: Thu Oct 26, 2017 3:18 pm However, when I try to enter the activation code via engine-> login, the button is grey out.
To code the engine unit (Coding-07) the engine must be OFF.
According to your last autoscan the cruise control is already activated in both units. (BCM and engine)
Something odd is happening here. :lol:
numberior
Drives: Polo GTI 6r
Post by numberior »
ciclo wrote: Fri Oct 27, 2017 5:12 am
Odd indeed.
It only happened after the ECU change.
I tried to do the cruise control activation.
https://www.youtube.com/watch?v=3RrdtjXe660
But for me Engine module-> Login-11 is grey out.
Do you know the security access for engine module, and the activation code for cruise control?
numberior wrote: Fri Oct 27, 2017 3:11 pm
Odd indeed.
:lol:
Now,
Byte5 Bit5 (ACC ON, engine OFF)
Disable and enable a couple of times.
numberior
Drives: Polo GTI 6r
Post by numberior »
Thanks Ciclo,
I'll try it out first thing tomorrow :)
numberior
Drives: Polo GTI 6r
Post by numberior »
Now,
Hi Ciclo,
I've tried it.
With ACC on and engine not running,
Clear bit 5->Exit->Do it, Set bit 5->Exit->Do it.
3 cycles I repeated.
Started engine.
On cruise control on stalk, still no cruise control activation indication.
What can I do next?
