BCM High to BCM Max, AFS, LED Headlights and HBA
Re: BCM High to BCM Max, AFS, LED Headlights and HBA
WL4
T73b/4 - T6/3 New Dimmer
T73b/7 - exT17/16 (original) plate lights
T73b/29 - T17/3 (isolate original T17/3)
TT73b/43 - T17/9
T73a/6 - exT17/9 (original)
T73a/45 -T17/16 (isolate original T73a/45)
WL5
T73b/12 - T6/5 reverse Tail light
federicodrdpro
Drives: White Polo 6R TDI
Post by federicodrdpro »
T73b/7 was already in WL4 wiring :oops: Thanks Ciclo! :mrgreen:
I need to install the cluster or update the EEPROM first?
explorer232
Drives: Seat
Post by explorer232 »
federicodrdpro wrote: Mon Jan 22, 2018 9:49 pm T73b/7 was already in WL4 wiring :oops: Thanks Ciclo! :mrgreen:
You need read immo block from old cluster via OBD, then remove eeprom from new cluster, update eeprom with corrupted immo block then reassembly eeprom to new cluster establish security access write immo block from old cluster and plug new cluster to car. Pease store your abs coding before laboring with new cluster.
federicodrdpro
Can I do this with VCP?
explorer232
Drives: Seat
No, immo block is encrypted by uController private key. This key is different for all clusters. You need special tools for reading and writting immo block.
No.
federicodrdpro
explorer232 wrote: Tue Jan 23, 2018 7:40 pm No, immo block is encrypted by uController private key. This key is different for all clusters. You need special tools for reading and writting immo block.
Which is the name of the tool?
I am thinking to go in a VW dealer for change the cluster. (Cheaper than tool?)
explorer232
Drives: Seat
federicodrdpro wrote: Tue Jan 23, 2018 11:57 pm
Yes cheaper as tool. But dealer can pair only new cluster, not used. If you have used one, you need specialised software as avdi, fvdi, carprog, smoke xcan but min. price is about 1K for tool or send me PM I can help you.
federicodrdpro
I plugged new wirings, new BCM, new dimmer and LED headlights. I can't communicate with Instrument Cluster. :?
Monday,29,January,2018,15:07:31:00001
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ6RZCY020628   License Plate:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 15 17 19 25 44 55 0B
55-Headlight Range -- Status: Malfunction 0010
Address 01: Engine (J0000-CFWA)       Labels:. 03P-906-021-CFW.clb
   Part No SW: 03P 906 021     HW: 03P 907 425 A
   Component: R3 1.2 DCM3.7 H06 8410
   Revision: 11002001    Serial number:
   Coding: 00114014002400080000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_ECM12TDI03103P906021 001010
   ROD: EV_ECM12TDI03103P906021.rod
   VCID: 65C089086461C76E19-8030
4 Faults Found:
14007 - No Communication with Instrument Cluster
          U0155 00 [063] - -
          Confirmed - Not Tested Since Memory Clear
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 4
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Engine speed: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 15 °C
                    Intake air temperature: 21 °C
                    Ambient air pressure: 1010 mbar
                    Voltage terminal 30: 12.039 V
                    Unlearning counter according OBD: 0
                    OBD Driver demand indicated torque: 0 %
                    Communication status of data bus 1: CAN Bus ON
                    Cruise Control System (CCS): status: 00000000
                    Terminal 15 status: On
                    Gear Ratio: 0
                    Sensor for engine block temperature: raw value: 15 °C
15648 - Please Check Fault Codes in Instrument Cluster
          U1024 00 [063] - -
                    Fault Priority: 6
                    Fault Frequency: 4
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Voltage terminal 30: 12.031 V
                    Exh.gas temp.sen 1: 12 °C
                    Exh.gas temp.sen 3: 12 °C
                    Exh.gas temp.sen 4: 12 °C
13973 - No Communication with Instrument Cluster
          U0155 00 [063] - -
                    Fault Priority: 2
                    Fault Frequency: 4
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Voltage terminal 30: 12.046 V
                    Gear Ratio: 0
13974 - No Communication with Instrument Cluster
          U0155 00 [063] - -
                    Fault Priority: 2
                    Fault Frequency: 4
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Gear Ratio: 0
Readiness: 1110 1000
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3416F00B2842B14E482D900421700
   Shop #: WSC 00788 648 00255
   VCID: 071CA380B22D357ECB-8052
3 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent
                    Fault Status: 00100101
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 40
                    Mileage: 0 km
                    Time Indication: 0
                    Hex Value: 0x0002
                    Hex Value: 0x0000
                    Hex Value: 0x1219
                    Hex Value: 0x1498
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7FF9
01317 - Control Module in Instrument Cluster (J285)
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 0
                    Fault Frequency: 5
                    Reset counter: 0
                    Mileage: 0 km
                    Time Indication: 0
                    Hex Value: 0x0002
                    Hex Value: 0x0000
                    Hex Value: 0x1211
                    Hex Value: 0x2598
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7FF9
00474 - Control Module for Immobilizer
                    Fault Priority: 0
                    Fault Frequency: 5
                    Reset counter: 0
                    Mileage: 0 km
                    Time Indication: 0
                    Hex Value: 0x0002
                    Hex Value: 0x0000
                    Hex Value: 0x1232
                    Hex Value: 0x1498
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7FF9
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 6R0 820 045 G    HW: 6R0 820 045 G
   Component: Man AC         02 0101
   Revision: 0002S 02
   VCID: 326A22546D2F60D64C-8066
1 Fault Found:
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 0
                    Mileage: 0 km
                    Time Indication: 0
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 128171814
   Coding: 3CB02BBF08E32600923808006D2F8CD00088672F60860000200000000000
   Shop #: WSC 18752 008 00032
   VCID: 2B543F304A05311E0F-807E
   Subsystem 1 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU030051100011446
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU025051100015419
   Coding: 08BC30
   Subsystem 3 - Part No: 1K8 951 171 A
   Subsystem 4 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H03 1301
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: K8 951 171 A    HW: K89 511 71A
   Serial number: ÿK8951171A  °103
   Subsystem 7 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU027051100012627
   Coding: 08BC32
   Subsystem 8 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU027051100013292
   Coding: 08BC32
   Component: VW10Airbag022 H09 0020
   Revision: --------    Serial number: 003GX00NWXFQ
   Coding: 003232
   VCID: 4A9A5AB4EDBF081614-801E
   Serial number: 3575HRB40550INGS999T
   Serial number: 3585HRB40570INGSBHPF
   Serial number: 3515RRB40510JNPM7P50
   Serial number: 3525RRB404P0K4DOA8O1
2 Faults Found:
12670208 - No Communication with Instrument Cluster
          U0155 00 [009] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
12674816 - Immobilizer Control Module
          U0167 00 [009] - No Communications
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
Address 17: Instruments
Cannot be reached
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 002200
   VCID: 68DE803C9B73DA0622-803C
3 Faults Found:
            000 -  -  - Intermittent
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
01336 - Company Data Bus for Comfort System
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 40
                    Time Indication: 0
00381 - Databus Instrument Cluster
                    Fault Priority: 2
                    Fault Frequency: 6
                    Reset counter: 0
                    Time Indication: 0
Address 25: Immobilizer
Cannot be reached
   Part No: 6R0 423 156 B
   Coding: 11210
   Shop #: WSC 00788
   VCID: 2F6C2B20EA1D4D3E23-807A
1 Fault Found:
            49-00 - No Communications
   Revision: --------    Serial number: --------------
   Coding: 0202000001000000
   Shop #: WSC 02757 790 50316
   VCID: 77FCD340CECD45FEBB-8022
3 Faults Found:
5256213 - Front Vehicle Height/Level Sensor
          C114D 15 [137] - Open or Short to Plus
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 0
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
5256725 - Rear Vehicle Height/Level Sensor
          C114E 15 [137] - Open or Short to Plus
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 0
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
13705477 - Databus
          U1121 00 [009] - Missing Message
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
End-------------------------(Elapsed Time: 03:04)--------------------------
Light dimmer don't work. Low Beam, High Beam and turn signal lights works fine but LED position don't work. (Coding?)
I have to register the keys yet.
EDIT: I can't register the Keyfob:
New wires:
1 0.5mm2 wire from T73b/4 BCM to dimmer T6aa/3
1 0.5mm2 wire from T73b/54 BCM to tacho T32/28
1 0.5mm2 wire from T73b/57 BCM to tacho T32/29
federicodrdpro
Thanks iichel but I already plugged this wires. :?
Hm, maybe re-check the wires to the IC. Fitting these two new wires should solve the issue with the cluster communication. Are you sure the wires are in correctly etc.?
For the button illumination (terminal 58 output to dimmer), you'll need to enable byte 27 bit 1. Maybe ciclo can help you to check the rest of the coding. He is very skilled at this.
3CB02BBF08E32600923808006D2F8CD00088672F60860000200000020000
federicodrdpro
Yes, I already checked this wires.
The tacho now:
EDIT:
iichel wrote: Mon Jan 29, 2018 3:23 pm For the button illumination (terminal 58 output to dimmer), you'll need to enable byte 27 bit 1. Maybe ciclo can help you to check the rest of the coding. He is very skilled at this.
Ok, the dimmer work now.
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
Could you please clarify, when you added new wires:
What you did with wires, which was in T32/28 and T32/29? Have you extracted them and isolated, or you connect new wires to them?
federicodrdpro
I extracted and isolated old T32/28 and T32/29 wires then I plugged new T32/28-T73b/54 and T32/29-T73b/57.
