UK-POLOS.NET - THE VW Polo Forum • Favi's Polo 6R 1.2TSI Red Flash "strawberry" :) - Page 4
Page 4 of 12
Re: Favi's Polo 6R 1.2TSI Red Flash "strawberry" :)
Posted: Wed Aug 14, 2019 11:00 am
by iichel
Keep in mind that the AFS ECU for bi-xenon headlights won't work with the LED headlights. You'll need a C unit with parameterization for LED headlights, i.e. from Russia or India (original) or flash the correct parameters with ODIS or VCP --> https://www.drive2.ru/l/519838378447864355/
Posted: Wed Aug 14, 2019 7:17 pm
by ciclo
iichel wrote: Wed Aug 14, 2019 11:00 am Keep in mind that the AFS ECU for bi-xenon headlights won't work with the LED headlights. You'll need a C unit with parameterization for LED headlights, i.e. from Russia or India (original) or flash the correct parameters with ODIS or VCP --> https://www.drive2.ru/l/519838378447864355/
+1
6R0 907 357C Z09 in his case.
favi, I have the parameters for VCP if you need them. (by email)
Posted: Fri Aug 16, 2019 6:41 pm
by favi
I had 6R0 907 357
So need to buy 6R0 907 357C
This will be okay?
https://allegro.pl/oferta/modul-sterown ... 8396395581
I have this module:
30.06.11
6R0 907 357
0070 H02
010 178-20 AC
0004 0659 HLR-0W5
after disconnection - no ESP and TPMS errors, cornering works.
After connecting the module - errors return.
Posted: Fri Sep 13, 2019 11:00 pm
by favi
Ok i bought 6R0 907 357C Z09 and.. the same problem ;D and doesn't work left cornering fog ;D
Aff... i need check all wires :( once again !
Image Image
Posted: Wed Sep 18, 2019 5:03 am
by ciclo
Have you parameterized the new AFS unit 'C' ?
:arrow: https://www.drive2.ru/l/519838378447864355/
Posted: Wed Sep 18, 2019 10:33 am
by favi
I can't open channel 55 at all - headlight range. Control not responded
I will check today ground point, and fuse box one again
Posted: Mon Sep 23, 2019 9:38 pm
by favi
Everything works fine. I have 2 errors on both AFS modules. Below are photos. I can't encode any of them.
6R0 907 357C Z09
Image Image
6R0 907 357
The problem was ... in the cube T26, which I bought in one of the popular vag modification shop. Someone inversely CAN HI / CAN LOW plucked into T26. I thought that the instruction that is attached to the harness does not require verification of the pins in the cube, and only wires to connect to other cubes. I stripped my T26, swapped pin 23 and 24 with T / 26 and it works. I solved the power and mass problem according to the idea of @firegrafik. Two wires for the right reflector cube T10 / 1 and T10 / 3. Everything works :)
Now the struggle with coding the lights again remains. When I have Auto and the DRL are on, flash high beam does not work. ON indicator, lights are not working. In AUTO mode - night, works OK.
Posted: Thu Jan 02, 2020 10:38 pm
by favi
I did all from this link https://www.drive2.ru/l/519838378447864355/
I cant change the encoding of the AFS module. I can't upload a file from TinyQ . Communication error. What's the problem? I can't change the encoding in VCDS either :(
Anyone have an idea?
Posted: Fri Jan 03, 2020 2:35 am
by ciclo
Maybe the parameterization from TinyQ is not correct for 6R (EU) and is correct for Polo Sedan (RUS), it is something I don't know.
If I were you, I would contact Szymon (CNK), who successfully installed LED headlights on his 6R with the right tools (original VCDS and VCP).
I would meet him and invite him to a couple of beers or whatever are necessary, ... or the refreshing drink he likes best, coffee, tea, RED BULL, etc... (or one of those Russian/Poland drinks that awakens the dead :lol:).
Subsequently, we would investigate the problems of your 6R by temporarily exchanging between cars the units involved in the installation of LED headlights.
You may not come to any conclusions about the problems your 6R experiences with the installation of LED headlights but it is a great opportunity to have a nice day. :)
Posted: Fri Jan 03, 2020 6:34 am
by ag69
:lol:
Posted: Fri Jan 03, 2020 8:21 pm
by favi
ciclo wrote: Fri Jan 03, 2020 2:35 am Maybe the parameterization from TinyQ is not correct for 6R (EU) and is correct for Polo Sedan (RUS), it is something I don't know.
If you cannot solve the problem remotely, I will plan a trip to Szymon :)
In the suitcase, of course, a good Polish drink - Bimber (strong vodka) xD
Posted: Sat Jan 04, 2020 4:31 am
by ciclo
Unfortunately or not, I don't have teamviewer or whatsapp to make instant remote connections, I'll be one of the last hominids to have those 'free' applications.
... surely the pygmies of Congo already have whatsapp and I don't. :lol:
As you are going to meet with Szymon, tell him to update and parameterize your BCM too. (in case you haven't done it)
Re: Favi's Polo 6R 1.2TSI Red Flash "strawberry" [emoji3]
Posted: Sat Jan 04, 2020 4:42 am
by benzinkopf
i wish i can do roadtrip there to szymon as well. he just got so many interesting stuffs inside his garage[emoji12]
Posted: Sat Jan 04, 2020 11:24 am
by ag69
+ 1 2 3 4 5
Posted: Fri Aug 21, 2020 10:47 pm
by favi
Hey every one ;)
I have little problem.
1. Swapped headlining on the car. I mounted the black from the POLO GTI.
I disconnected the plug from the RLS (T3 RLS) for a moment and after reconnecting the "Auto light" function stopped working - it detects the night non-stop. CH / LH function does not work when unlocking the car.
VCDS sees RLS in long coding. No errors with RLS
2. The second problem, after starting the engine, the air conditioning does not start. The button doesn't seem to work. Only after driving about 20 meters, the air conditioning starts. What's the problem?
This happens after the BCM is changed to 7E0.
