DJ's Polo 6R
Re: DJ's Polo 6R
I think the most valuable thing you'll get from ciclo is the support with the installation and the coding.
claudio-dj
- Drives: Polo 6R - 1,6 TDI - Highline
Re: DJ's Polo 6R
obvious! It's to understand what I'm missing from buying again ...
Inviato dal mio SM-G950F utilizzando Tapatalk
Re: DJ's Polo 6R
So the wiring I manufacture is of low quality or mediocre, right?iichel wrote: Wed Apr 11, 2018 4:44 pm I think the most valuable thing you'll get from ciclo is the support with the installation and the coding.
Apprentice, I wonder if you're a troll or retarded.
Do you stop a moment to think before writing? You need to do it.
I'm not insulting you and it's not my intention, I'm just asking with the best of my intentions.
NOBODY IN THIS GALAXY MANUFACTURES BETTER WIRING FOR THE 6R
100% SUCCESS
(I have even had to solve the problems of your customers in 'several' occasions, in multiple occasions from the Kufatec customers, ... and from others sellers, bla,bla,bla...)
Not related:
How long are we going to have to be seeing your ____ avatar?
By the way, you forgot to thank me the help to solve your LED headlight problems.
Re: DJ's Polo 6R
not a troll, not retarded. it is simply my opinion that your wirings are valuable but your support is even more valuable
if it were my opinion (not the case) that your wirings are not valuable, i would have used 'only' instead of 'most'.
i'll be sure to thank you, but after we confirmed it's the solution.
so far firegrafik is experiencing the same issues as before, unfortunately. my polo is running the same configuration (byte 18 to HEX 60 and byte 29 bit 5 ON) without any issues.
Re: DJ's Polo 6R
Now you dedicate yourself to the Politics?
I refer to the politics exercised nowadays
, not the literal meaning of this beautiful word.
Do the favor of getting involved in your affairs (for example, explain your latest achievements or help people who make your 'mods') we don't need your opinion precisely in the moment when someone is asking me about my wiring ..(you do this regularly), you must respect me (we are in the same ship, ...if you remember).
Re: DJ's Polo 6R
claudio-dj wrote: Wed Apr 11, 2018 12:22 pm so basically you only provide me with the right 2 point?
Yes, 'only' the point 2. The only one that will make the rest of the things you intend to install work correctly in your 6R 2010.
I don't provide wires to install (retrofit):
- bixenon headlights ...(T10-T14 harness)
- fog lights ...(maybe I'll give you a gift here)
- DRLs ...(in your case in Bixenon T10-T14 harness included)
- a jet engine
- 22 "wheels
- boot lid with automatic opening.
- etc...
I think it's clear what I mean.
claudio-dj
Re: DJ's Polo 6R
ahahahaha very clear !!! [emoji23]
Re: DJ's Polo 6R
Perfect!
My explanations are due to the fact that many people don't understand that the electrical installation of a WRC 38000€ is not the same as that of a 6R 10000€.
By installing the point 2, it facilitates that your electrical installation will be the same or better than that of a WRC.
claudio-dj
Re: DJ's Polo 6R
quite right! Great Ciclo!
claudio-dj
Re: DJ's Polo 6R
I have this wiring ... is it good?
Re: DJ's Polo 6R
I mentioned it to you earlier (point 3)
viewtopic.php?f=56&t=71076&start=30#p532801
The part with the T10-T14 connectors is correct, or rather, perfect.
The gray part of that wiring is poorly conceptualized (it's a real disaster) and in no case should these cables be installed. IN NO CASE.
By installing those gray wires many diagnostics are lost, the protection of the electrical system is deficient, etc...
Some time ago I had to buy these cables for a good friend (to get the T10-T14 part).
I took the oportunity to check the gray part of them... to the trash.
Re: DJ's Polo 6R
Check your inbox.
I replied to your private message.
Re: DJ's Polo 6R
Point 4
viewtopic.php?f=56&t=71076&start=45#p532836
_________________________
Fusebox
viewtopic.php?f=56&t=71076&start=15#p532050
In this way you avoid/save having to buy this wiring for foglights:
https://www.ebay.de/itm/VW-Polo-6R-Kabe ... 2eb91b124a
Fusebox
Re: DJ's Polo 6R
Point 2 "only"
I still have to do the installation guide.
When it is finished I will contact you by email.
Re: DJ's Polo 6R
How to install a 7E0 BCM Max in 2010 Polo 6R non Bluemotion (claudio-dj)
Preview.
View or download here
TiO2
Preview.
TiO2
