Page 4 of 4
Re: BCM max, RLS, Bixenon adaptation for my 6R Sedan
Posted: Mon Jul 30, 2018 7:17 pm
by ciclo
smg_shardul wrote: Mon Jul 30, 2018 7:58 am In my case I did wiring myself and I have coded bcm as per your guidance plus wiring is done as per your instructions provided.
I got to know about rear fog light when i read this thread because I never use rear fog lights as it disturbs vehicle behind me.
You never posted an Autoscan with the faults after installing my wiring, I told you to do it (a lot of times :evil: ). Do it in your topic and don't mess up this topic.
I want to remember that my technical support is limited to the BCM Max adaptation and automatic lights.
Be careful with the lies ...
Posted: Mon Jul 30, 2018 8:12 pm
by Nikhil
ciclo wrote: Sun Jul 29, 2018 3:26 am Same electrical installer for vento2013, smg_shardul, seeramkumars (Vento/Sedan) with the same symptoms in their car.
I guess the installer will have to give explanations.
Everything work like a charm in many other Vento with the 'same' wiring looms but diferent installer.
(100% success in all my wiring looms installations)
Notes:
1- Don't invent anything new trying to save on wires, work or time of work. Follow the original diagrams (ELSA).
2- Follow the installation guides faithfully, they are based on original electrical diagrams and the experience.
3- Don't modify the BCM coding without knowledge of what you are doing to find a solution to a poor electrical installation due to point 1.
Ciclo, Do u even know that i didnt did installation in smg_sharduls car? He is facing same issue like sreeramkumar. If you cant help your customers just tell them " i cant help more than this ". Vento2013 car never had rear fog lamp issue. One issue was with relay bridge for which no one blamed you.
In both sreeramkumars and smg_sharduls car i have checked power from headlights switch rear fog out to bcm rear fog in. Bcm is getting signal from headlight switch in both parking and headlight on mode. There is no point in saying wiring installation is wrong. I am sure its coding related issue, and you are expert in coding so he asking help from you. As per you have suggested we have also checked by changing headlight switch but it gives same resposne. Trust me, rear fog lamp not turning on in parking position is not big deal here in india. We just want his car light work perfect as it works in other car. Even if we cant make it work not big deal. No one is gone blame you. People wish you to coordinate with installer if needed and solve the small issues. :roll:
Everyone appriciate you for making such a nice wiring. But when it comes to support you are good at blaming others without checking the facts.
Posted: Sun Aug 05, 2018 8:07 pm
by antardaksh04
I had never tested this "Rear fog light with parking" but after reading this post I checked and confirm its working fine in my car.
I used the same wiring kit as all of you in my Vento TSI.
Regards.
Posted: Wed Feb 27, 2019 3:57 am
by sreeramkumars
sreeramkumars wrote: Wed Jun 27, 2018 6:01 am
ciclo wrote: Tue Jun 26, 2018 4:30 pm How do you want the coding of your new BCM Max + Autolighs, with Bixenon headlights installed or without them?
Without Bixenon please. I've to wait for my next bonus to procure a set of bixenons! :roll:
Hello Ciclo and others in this forum,
I got my bonus and thus a new pair of bixenons for my car from UK. Could you please let me know the coding for enabling Bixenons?
Current coding:
version 1:
New BCM Max + Autolights. (without Bixenon, DRLs and SCLs)
New coding
3A904AB808A10000013806B03CCB96905BC0612E60042001200000020000
version 2: (change for removing the LED license plate error)
3A904AB808A10000013806B03CCB96905BC0612E60042001200000030000
parts:
Bixenons: 6R2 941 039D; 6R2 941 040D.
Wiring adapter(from eusystems.pl) https://www.carsystems.eu/adapter-bi-xe ... d1268.html
Mitsubishi ballasts
Osram D3S night breaker xenarc
Osram H7 night breaker unlimited for SCL.
Posted: Wed Feb 27, 2019 8:17 am
by ciclo
Hello,
3A904AB808A10000013806B17CCB96905AC0672F600530C1200000030000
Posted: Wed Feb 27, 2019 8:30 am
by sreeramkumars
ciclo wrote: Wed Feb 27, 2019 8:17 am Hello,
Thanks a lot Ciclo. Will try and let you know how it goes.
Posted: Wed Feb 27, 2019 8:33 am
by ciclo
Thanks to you. :wink:
Posted: Thu Mar 07, 2019 4:09 am
by sreeramkumars
Hi Ciclo,
The coding worked and all's well. Thanks. 8)
Posted: Thu Mar 07, 2019 4:20 am
by ciclo
Perfect! :D enjoy your bixenon headlights, it's a great improvement.
Thank you very much for reporting. 8)
