seems ciclo, you have known custom procedures toociclo wrote: Mon Jul 15, 2019 7:02 am
You have to send me a photo/image of your PAN Card or Driving license to my email. It's required for package content declaration at the India customs.
Soon I will contact you by private message. Wait please.
Patil's little Polo 6R 1.2 Tsi Dsg7 RHD
- ag69
- Drives: 1.2TSi 77Kw 7DSG
Re: INSTALLING DIRECT TPMS IN POLOGT 6R RHD IND
patil
Thanks a lot Master, I am overwhelmed by your help.ciclo wrote: Mon Jul 15, 2019 7:02 am BCM Max wiring adaptation (specific for patil 6R)
plus
FGTech Galleto V54 0386 (clone) to activate the Gra_High in your ECU 1.2 TSI Simos10.x
Today, I spent most of the time in rechecking the wiring installation of TPMS along with CAN lines(for both TPMS and OPS) thoroughly. It appears, everything is correct and checked the continuity of the lines with multimeter wherever possible, everything seems to be ok.
As you pointed out, the coding for Fatigue detection in Gateway was incorrect. I rectified it, and please verify that its correct Master. Below is VCDS autoscan report:
Monday,15,July,2019,22:01:23:09269
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 19.6.0.2 (x64) HEX-V2 CB: 0.4505.4
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: MEXL15606GT048293 License Plate:
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 56 65
VIN: MEXL15606GT048293 Mileage: 42790km-26588miles
10-Park/Steer Assist -- Status: Cannot be reached 1100
65-Tire Pressure -- Status: Cannot be reached 1100
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 KC HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 6270
Revision: --H10--- Serial number: 00000000000000
Coding: 00250056232400080000
Shop #: WSC 53863 002 1048576
ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
ROD: EV_ECM12TFS02103F906070FP.rod
VCID: 6D84C0CEAD13BD3F117-8038
Readiness: 0110 0101
Part No SW: 0AM 300 065 N HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6502
Revision: 00043014 Serial number: CU501508317273
Coding: 0000020
Shop #: WSC 01260 002 1048576
VCID: 3A2E3B92A05DDA87C45-806E
Part No SW: 6R0 907 379 BN HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0001
Serial number: --------------
Coding: 62DD2463422703C8461624724254C0800908
Shop #: WSC 29230 002 1048576
VCID: 0B40AE56B3C7130FAF3-805E
Serial number: 10051504650275
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA6F782F07536A7B8D-802A
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 41DC4C7EC18B895F85F-8014
Part No SW: 7E0 937 090 D HW: 7E0 937 090 D
Component: BCM PQ25 Max4 H82 0762
Revision: B9082001 Serial number: 8601 222180475
Coding: 3AB02BFF08A10000003800C07C2B9490F0C041FF608C0000200400000000
Shop #: WSC 00046 123 12345
VCID: 2C020DCA56097437469-8078
Subsystem 1 - Part No SW: 6R0 959 802 BH HW: 6R0 959 802 BH Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 8612
Serial number: KU0KU015041441050460
Coding: 1400B3
Subsystem 2 - Part No SW: 6R0 959 801 BC HW: 6R0 959 801 BC Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 8612
Serial number: KU0KU014041441047765
Coding: 0400B3
Subsystem 3 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Component: E221__MFL-TAT H04 0019
Serial number: 1971517275001536AB2B
Coding: 240000
Subsystem 4 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Component: ------------- 006 5550
Serial number: 13102580150623202239
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Serial number: 13202581150812164218
Coding: 020000
4 Faults Found:
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 7
Mileage: 42791 km
Time Indication: 0
Date: 2019.07.15
Time: 00:06:27
03432 - Activation of Right Parking Light
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 7
Mileage: 42791 km
Time Indication: 0
Date: 2019.07.15
Time: 00:06:27
01516 - Terminal 30; Left
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 9
Reset counter: 8
Mileage: 42791 km
Time Indication: 0
Date: 2019.07.15
Time: 00:06:26
00927 - Terminal 30 (Right)
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 9
Reset counter: 8
Mileage: 42791 km
Time Indication: 0
Date: 2019.07.15
Time: 00:06:26
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 J HW: 7N0 919 475
Component: PARKHILFE 8K H06 0105
Revision: -------- Serial number: 28261224902578
Coding: 108101
Shop #: WSC 02756 790 50316
VCID: 392C249EA9DBD19FCDF-806C
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW0118WCJ
Coding: 003036
Shop #: WSC 01234 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 49CC545EF93B411F5DF-801C
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H05 0805
Coding: 140C01
VCID: 47C85266EF2FB76F4BB-8012
Part No SW: 7E0 909 901 HW: 7E0 937 090 D
Component: GW-K-CAN TP20 H82 0762
Revision: B9082001
Coding: 002305
VCID: 688AB1DA82719817621-803C
2 Faults Found:
03075 - Parallel Parking Assistance Control Module (J791)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 7
Mileage: 42791 km
Time Indication: 0
Date: 2019.07.15
Time: 00:06:26
01325 - Control Module for Tire Pressure Monitoring (J502)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 7
Mileage: 42791 km
Time Indication: 0
Date: 2019.07.15
Time: 00:06:26
Component: IMMO H05 0805
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A8ECBD29CFDAA07745-803E
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ROD: EV_SteerAssisNSK_014.rod
VCID: 41DC4C7EC10B895F85F-8014
Part No SW: 6RD 035 187 A HW: 6RD 035 187 A
Component: MIB2-S-R-CN 025 0210
Revision: -----001 Serial number: 01855GD0000318
Coding: 00000440010001
Shop #: WSC 00081 790 00118
VCID: 45D4586ED5A3A57FB97-8010
2 Faults Found:
02873 - Control Module for Back-Up Camera (J772)
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 42759 km
Time Indication: 0
Date: 2019.07.09
Time: 00:34:34
01327 - Control Module for Parking Aid (J446)
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
Mileage: 42759 km
Time Indication: 0
Date: 2019.07.09
Time: 00:34:32
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 40000000058983
ROD: EV_RDKBERU30_005.rod
VCID: 372822A69FCFC7EF3BB-8062
End----------(Elapsed Time: 01:11, VBatt start/end: 13.7V/13.6V)-----------
Hi patil, I regret that you have had to spend most of the day doing these checks and we have not been able to solve it (thanks for doing these checks), but we already know with complete certainty that it is not a fault in the CAN lines wires.
Just out of curiosity, from where have you extracted the power/feed for modules 10 and 65? Is it a +15 or +30 signal?
- For module 65 it must be +30. e.g. viewtopic.php?f=56&t=58703&p=517343#p517336
- For module 10 it must be +15. (usually 16 fuse in the PQ25 6R family, 4K 5Amp, 8K 10Amp) https://drive.google.com/file/d/1cfvI43 ... sp=sharing
In your case, the Gateway coding for fatigue detection activation must be 002304
I hope that when you receive my wiring these problems of the CAN lines can be solved, apart from current 4 faults in the BCM.
I send you my email address by PM, please contact me as soon as possible so I can send you the wires, etc, ...as soon as possible. Thank you.
patil
The power supply for OPS module was already present in my stock harness(T1/T16, Black/Green wire). I just changed the module to 8k, added CAN lines from IC T28/T32(CAN high), T29/T32(CAN low) to T6/T16(High) and T15/T16(low). There was a wire(Black/Blue) in T6/T16 in stock harness(function???), which I removed and isolated to add CAN high wire.ciclo wrote: Tue Jul 16, 2019 4:23 am
Everything was working perfectly untill BCM Max was installed.
The power supply for TPMS, I tapped +30 from SB44 which was unused in my car.
patil
I am little confused on this one.ciclo wrote: Tue Jul 16, 2019 4:23 am
Fatigue detection was activated with Gateway coding 002304 only initially. You pointed out that, some bytes for Fatigue detection are not activated. So I researched a bit, and changed the Gateway coding to 002305 after reading here: https://www.drive2.ru/l/533203766917202038/
And thank you for shipping the package very fast.
edited,patil wrote: Tue Jul 16, 2019 4:40 pmThe power supply for OPS module was already present in my stock harness(T1/T16, Black/Green wire). I just changed the module to 8k, added CAN lines from IC T28/T32(CAN high), T29/T32(CAN low) to T6/T16(High) and T15/T16(low). There was a wire(Black/Blue) in T6/T16 in stock harness(function???), which I removed and isolated to add CAN high wire.[/b]ciclo wrote: Tue Jul 16, 2019 4:23 am
My eyesight gets worse every day.
Your blue/black wire was in T16/6.
Now I remember that there are different Low OPS modules for Russia, India, etc ... from factory.
It is the reverse signal for the 'low' OPS modules (eg, your original 4K, ). The 'high' OPS modules (e.g., your current 8K) receive this signal through the CAN lines.
It is correct to isolate the black/blue T16/6 wire for your upgrade.
Note: there are also 'high' OPS modules 4K (CAN lines).
Sorry. Totally guilty
https://drive.google.com/drive/folders/ ... 0hSiE1mZCP
I have taken the firm decision to uninstall ELSAWIN from my laptop.
From now on I will only use ERWIN.
Why do you think that the publication by Madwarlock in Drive2 is correct and what I published in uk-polos is wrong? ...patil wrote: Tue Jul 16, 2019 5:07 pmI am little confused on this one.ciclo wrote: Tue Jul 16, 2019 4:23 am
By email, in our research process to activate fatigue detection, I was the one who told Madwarlock (Slavik) that the coding in the gateway for Byte2 should be 05 or other HEX values, but later, once I uploaded the data set I discovered that only the HEX 04 value is necessary.
I have added some small things inside the package. Wait to receive it to know what it is.
Previous post edited.
Let's go with the explanations:patil wrote: Tue Jul 16, 2019 5:07 pm I am little confused on this one.![]()
- First you post this autoscan viewtopic.php?f=56&t=73189&start=15#p558198 and the image of driver alert. In this autoscan the coding of your gateway is 002300.
- Then I post this viewtopic.php?f=56&t=73189&start=30#p558238 relative to some things that your autoscan does not include.
In the package I sent you, in a small sealed bag, there are three additional wires that you do not need to install due to your current NO-OEM lights configuration, ... headlights, taillights, mirror without RLS holder/support, + Chinese Kit for automatic lights.
These wires are:
1- Blue/black wire (0.5mm2): this wire is for DRLs signal, to be installed from the T17/3 lights switch connector to T73b/29 BCM MAX white connector.
It would be necessary to do the electrical installation from BCM connectors to the new DRLs.
2- Gray/black wire (0.5 mm2): this wire is for rear foglight signal, to be installed from the T17/9 lights switch connector to T73b/43 BCM MAX white connector. Remove original T17/9 to be spliced later.
3- Black wire (1.5 mm2): this wire is for feeding the rear foglight, to be installed from T73a/6 BCM MAX black connector to the original wire T17/9 (splice with the blue Butt terminal).
These three wires only should be installed in case of installing the 'original' automatic lighting system, RLS with auto dimming mirror, Light Switch AUTO, wiring for automatic lights with two relays, ... or original Bixenon/LED headlights.
Please copy and save this info.
These wires are:
patil
Master, don't be sorry and your Eye sight is perfect, as an Eye Specialist I can say that.ciclo wrote: Tue Jul 16, 2019 4:23 am
edited,
Sorry. Totally guilty![]()
Actually you are the one who suggested to someone sometime back in your thread to isolate the T16/6 wire from the factory harness to add CAN lines to upgrade the OPS module. I too followed the same then, and as expected it was perfect and correct suggestion.
patil
Master, I am really sorry on this one.ciclo wrote: Wed Jul 17, 2019 3:59 amLet's go with the explanations:patil wrote: Tue Jul 16, 2019 5:07 pm I am little confused on this one.![]()
My bad, I posted the VCDS auto scan after installing BCM Max and before activating the Fatigue detection. And then I posted picture of activated Fatigue detection. I confused myself on this.
Now I corrected the Gateway coding, thanks.
Ok Master, thanks a lot.ciclo wrote: Wed Jul 17, 2019 6:34 am In the package I sent you, in a small sealed bag, there are three additional wires that you do not need to install due to your current NO-OEM lights configuration, ... headlights, taillights, mirror without RLS holder/support, + Chinese Kit for automatic lights.
Thank you Doctor, it is clear that you know that a good vision is better than a good eyesight.patil wrote: Wed Jul 17, 2019 5:05 pm
Master, don't be sorry and your Eye sight is perfect, as an Eye Specialist I can say that.![]()
Actually you are the one who suggested to someone sometime back in your thread to isolate the T16/6 wire from the factory harness to add CAN lines to upgrade the OPS module. I too followed the same then, and as expected it was perfect and correct suggestion.![]()
patil
This post is to admit my mistake
During BCM Max upgrade, I had connected the new CAN lines (for BCM Max, CAN extended) to black T3 connector, through which I had(previously) tapped CAN lines for 8k OPS(later TPMS ) and lines for IC, instead of connecting the new CAN lines(CAN extended) directly to IC, T32/28 and T32/29. I over looked the wiring connection at that time.
Realizing my mistake, I reconnected the old isolated CAN lines(CAN powertrain) to OPS CAN lines(and TPMS).
The result, all error codes in addresses 10,19, 56 and 65 disappeared.
Only Central Electrical errors persist.
8K OPS display is working correctly now, and I have disabled the back up camera in address 56 for time being till BCM Max wiring is done.
Master, I am extremely sorry for misleading you(unintentional) with wiring connections and wasting your time unnecessarily.
VCDS autoscan after wiring correction:
Saturday,20,July,2019,19:48:36:09269
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4505.4
www.Ross-Tech.com
VIN: MEXL15606GT048293 Mileage: 42920km-26669miles
56-Radio -- Status: OK 0000
VCID: 6D84C0CEAD13BD3F11F-8038
Coding: 0000020
VCID: 3A2E3B92A05DDA87C4D-806E
VCID: 0B40AE56B3C7130FAFB-805E
Coding: 01
VCID: 7EA6F782F07536A7B85-802A
Revision: V0000000
VCID: 41DC4C7EC18B895F857-8014
VCID: 2C020DCA56097437461-8078
Coding: 1400B3
Coding: 0400B3
Coding: 240000
Coding: 020000
Coding: 020000
4 Faults Found:
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 18
Mileage: 42927 km
Time Indication: 0
Date: 2019.07.20
Time: 01:58:04
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 18
Mileage: 42927 km
Time Indication: 0
Date: 2019.07.20
Time: 01:58:04
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 2
Reset counter: 18
Mileage: 42927 km
Time Indication: 0
Date: 2019.07.20
Time: 01:55:58
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 2
Reset counter: 18
Mileage: 42927 km
Time Indication: 0
Date: 2019.07.20
Time: 01:55:58
Coding: 108101
VCID: 392C249EA9DBD19FCD7-806C
Coding: 003036
VCID: 49CC545EF93B411F5D7-801C
Coding: 140C01
VCID: 47C85266EF2FB76F4B3-8012
Revision: B9082001
Coding: 002304
VCID: 688AB1DA82719817629-803C
VCID: 6A8ECBD29CFDAA0774D-803E
VCID: 41DC4C7EC10B895F857-8014
Coding: 00000400010001
VCID: 45D4586ED5A3A57FB9F-8010
VCID: 372822A69FCFC7EF3B3-8062
End----------(Elapsed Time: 01:46, VBatt start/end: 13.5V/13.7V)-----------
Excellent patil!
you rock!
If we did not make mistakes, we would not be so f*****g smart ... LOL! ...we call it 'experience'...
Thanks for the clarifications. Do not worry about my time, learning from the mistakes of others is a super free experience.
You know that everything I written above is to joke.
Notes:
The badly named 'CAN extended' in PQ25 is officially named 'dash panel insert CAN Bus', to make clear that only the instrument cluster is connected these CAN lines, ... although it is possible to connect some type of radio that was sold in China (OEM) and other experiments ... hahaha
The whole mystery of BCM Max adaptation lies precisely in isolating the instrument cluster from 'powertrain CAN Bus'. It's one of the first images in the multiple installation guides that I made during these years.
Once you did it everything goes smoothly.
Your RVC will work once the BCM Max adaptation wires are installed, as we saw earlier it is due to the way in which the new BCM Max supplies power to the reversing light wire.
The 4 faults in BCM will disappear as well. (or so I think,
, ... chinese kit, etc)
Notes:
