Skoda Fabia VRS 2012. Auto lights retrofit OEM
Forum to discuss the Skoda Fabia
Re: Auto lights retrofit
Подольск
While we wait to receive the BCM I will begin to show your wiring. 100% made.
Please pay attention because this electrical installation for the BCM Max adaptation is somewhat different from those made in the 6Rs.
I think it will be very interesting due to trying to operate the Dimmer 1Z0 941 333 correctly and other things...
Basic Information
Warnings
- Insulate removed/replaced original wires with cloth tape , at least two turns of tape. https://drive.google.com/file/d/0B2nv91 ... FmY3M/view
Individually/separately, insulated contact terminals can never be together in case of isolate several wires in the same place.
- Remember that you must use good tools for crimping Butt terminals. https://drive.google.com/file/d/0B2nv91 ... dlUUk/view
- How stripping a wire to insert in the Butt terminal. https://drive.google.com/file/d/0B2nv91 ... I1MFk/view
- How to cut an original wire. https://drive.google.com/file/d/0B2nv91 ... JqWm8/view
- Before you start working with wires = Remove Battery ground.
Please tell me if you understand this basic information.
Tip: you must 'double check' the contact terminal correspondence in the connector slots before inserting, in some occasions removing the terminals can become a very difficult task without the right tools (even with them).
VASILEIOS1972
Drives: Polo 6R 1.2 tsi , Skoda Fabia 5J Vrs 1.4
Post by VASILEIOS1972 »
Great information my friend Fernando
I have some good tools to make the installation
I just need the right guideness from you
Regards
VV
Perfect!
I have taken the wiring images but I still have to edit them, I will upload them here throughout the day.
VASILEIOS1972
ciclo wrote: Thu Aug 01, 2019 10:48 am Perfect!
For me it will be a great help to prepare all that needs to this installation
And believe me with all extra cost
Regards
VV
Use your ElsaWIN
The first thing to do is remove the steering wheel (airbag), steering column covers, stalks/ring, instrument cluster, fuse box, dashboard side cover,and BCM.
This way you will have better access for this installation.
3a
3b
3c
3d
Plate lights. Before and After.
Before (your current installation)
After
-Remove the panels that are necessary to run the wire next/parallel to the original harness.
-Cut the indicated wires near the license plate lights inside the car (trunk/boot).
For example, look for the images of the license plate lights wire installation in this installation guide :arrow: 6R RHD, page 13.
Original wiring diagram for BCM Max. Plate lights X4, X5.
Special wiring for automatic lights. (Skoda Fabia VRS 2012, 'C' Model year)
Follow the instructions on the following link to complete the installation of this wiring. https://drive.google.com/file/d/0B2nv91 ... sp=sharing
Note:
For this wiring installation you do not have to touch anything on the red and black connectors. These steps were done previously.
As indicated here :arrow: viewtopic.php?f=41&t=73355&start=30#p558928
Note:
In the previous link I did not indicate anything (in the process steps) about wiring 1 (CAN lines) because there are old BCM Max (7H0) that do not need these CAN lines.
At that time I did not know what BCM Max you were going to install.
Your new BCM Max 7E0937090C is one of the most updated and needs these CAN lines (from BCM to Instrument cluster).
BCM Replacement :arrow: http://wiki.ross-tech.com/wiki/index.ph ... eplacement
- Make sure all vehicle remotes are present.
- Run and save a complete Auto-Scan and save it prior to module removal.
- Install the replacement control module.
- Code the 19-CAN Gateway module with the Long Coding from the original module found in the Auto-Scan.
- Configure the 19-CAN Gateway module using the [Installation List] function in VCDS per the original Auto-Scan.
- Code the replacement 09-Cent. Elect. (BCM) module with the Long Coding from the original module found in the Auto-Scan.
Channel 099: Factory Mode
Value = 0
Channel 001: Remote Control Matching :arrow: http://wiki.ross-tech.com/wiki/index.ph ... l_Matching
1st Remote Control
Start Matching new/additional Remote Controls by entering 0 for the New Value, then [Test] and [Save] the New Value.
Press and hold the Unlock button for at least one second on the Remote Control you want to add, the Blinkers will light up to confirm the Adaptation Process of each Remote Control.
2nd Remote Control
Clear all fault codes and verify all comfort functions and lighting is working as per design.
Note:
I will provide you the correct BCM coding for this installation/adaptation.
VASILEIOS1972
Fernando have a nice day
I have read with attention everything that you provide me
Tell me please can I make the installation in weekend?
In your opinion can you tell me installation time (how many hours)
Regards
VV
Good morning.
It is possible to install these wiring in one morning if you have experience in wires, it depends on the skills of each one to remove the necessary parts and install the wiring looms.
If you have no experience with wires you should do this installation calmly. You must consider and schedule a couple of days or three in which you will not use the car. Maybe you install them in a single day, but schedule two or three days, setbacks may arise.
The installation is uncomfortable to do, but it is really easy, follow my instructions accurately, don't skip any details, and everything will work perfectly.
Tip: You have to have a mechanic's mentality to remove the parts, being careful not to damage them (study the ElsaWIN if you need), and a watchmaker's mentality to install the wires. You must do it with precision, you cannot damage the contact terminals, it would be catastrophic.
If you are wrong when installing the terminals the car will not work.
Have a nice day too!
VASILEIOS1972
Cc installation, washing lights system, 8ops PDC, rns315, antidazzle mirror, ☔ sensor, all those retrofits have been installed by me.
Is this experience enough to make those installations in one day?
Regards
VV
Yes, sure. :wink:
