Polo 1.2 6R CGP Engine rebuild
Re: Polo 1.2 6R CGP Engine rebuild
Honestly, I don't have the slightest idea. One side of the gear should have a slightly raised shoulder/collar that must face inward toward the engine block to act as a spacer, the completely flat side faces outward toward the crank pulley. If it's flipped, the chain will be pushed out of alignment by a couple of millimeters.
Usually, if the gear has any factory part numbers or markings stamped on it, they face outward so a mechanic can read them.
Check the PDF manual that I have given you/you have downloaded, maybe you can find some clue for that sprocket orientation.🤷‍♂️
UKWaffles
Drives: Polo 1.2 6R 2009
Post by UKWaffles »
Yea, I'll inspect it tomorrow,
New head bolts arrive on Firday so off with the head to see how it moved as much as it did, and get it on those dowels. Assume there is some wiggle room on the dowels as it seemed to sit down fairly fine.
Might take out the old bolts and see how much it shifts around and go from there
That's a very smart way to test it. Loosening the old bolts and seeing how much the head can actually wiggle will tell you instantly if it was just sitting wrong or if the dowel pins are loose.
There is usually a tiny fraction of a millimeter of play on those dowels to allow for thermal expansion, but it should never be enough to let the head shift so far forward that the timing components rub against the cover.
It's a solid plan for tomorrow/the weekend, take your time, get it locked onto those pins... please keep us posted on what you find under there.👍
UKWaffles
Post by UKWaffles »
Cracked on with the tear down and rebuild
Decided to totally remove the head and got new bolts so off it came and back down once more.
All looked fine inside, so coolant leaking into the combustion chamber so was only leaking externally between the head and the block.
Read over the manual for fixing these engines as was provided and it never made any mention of oiling / lubing the head bolts
Eitherway I was able to get the head back on with all the bolts to the correct specs, this time with a solid wrench as it asks for, so breaker bar didn't indroduce any flex / miss torquing.
Oil filter housing as way more space now so seems the head is on correctly this time and I made sure the play was minimal and it all feels far better than last time.
Timing gear / kit all back on and made sure the oil filter gear was on the right way around too as it wouldn't fit any other way around as it would contact the timing chain.
Waiting for all the sealent to try before new oil and filter goes in.
WhatsApp Image 2026-11-08 at 17.45.04.jpeg (419.54 KiB) Viewed 2069 times
😎Awesome news! That's a massive win. 😎
The fact that the oil filter housing has plenty of clearance now proves that the head was definitely sitting proud the first time, and, using a solid wrench instead of a flexing breaker bar made all the difference to get that exact clamping force.
It's also great that you verified the internal passages and the oil pump gear orientation while you were in there, "now you have 100% peace of mind".
The engine looks super clean in the photo.💎
Let that sealant cure completely, fresh oil and filter in, and you're ready for the big moment. Fingers crossed for the MOT!🤞
You've basically mastered this engine now!
UKWaffles
Post by UKWaffles »
Yea, I can tear this engine down super fast now.
All the sealent should be dry come Monday, then I can take off the sump clean it all down and get rid of all the old oil.
New clean stuff in with a new filter, and can attempt again at getting it running. This time hopefully without a leak between the head and the block. Think last time I had too much movement in the breaker bar and I oiled the head bolts a lot so doubt I ever got the correct clamping pressure on.
Went together better this time around so once its all back together will see about the MOT.
Got to fix some eletrical issues and some tie rod ends and hope it passes.
