Cornishdrummer's Progress Thread -Im back(pg 34)
- cornishdrummer
Re: Cornishdrummer's Progress Thread - VAGCOM (pg 30)
So do I just plug the lead in and test the port and so on ?
Then is it best just to do a Auto-Scan ?
Is there any thing else worth doing as well ?
- Endi_GTI
I usually just check the ABS, Engine and instruments for codes mate. Yeah the lead should be 1 of 4 COM ports i think. Just make sure she is running ok. If there are any codes, write them down, then clear them and take it for another spin and see if they have come back. If they come back you could have an unseen problem.
- cornishdrummer
Cheers mate, I will get that done in the next few days.
- cornishdrummer
Getting my windscreen refitted on Monday as it keps steaming up, so they checked it today and want to take it out and refit it for me to see what the problem is.
- cornishdrummer
Re: Cornishdrummer's Progress Thread - Vagcom Faults (pg 31)
Pluged the car in today found two faults
1 Fault Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
1 Fault Found:
ABS Wheel speed sensor rear left (G46)
I knew the abs was playing up as when someone sat back there the light would come on but when they got out and light went out.
1 Fault Found:
1 Fault Found:
- cornishdrummer
Had my windscreen refitted yesterday, they found it was not put in right the 1st time and also some of the trim was not put back right, its looking much better as well now.
Also with the vagcom faults
1 Fault Found:
1 Fault Found:
With the 1st fault is it just a matter of a wrong fuse ?
With the ABS is it best to just clear it then drive it and test it again ?
1 Fault Found:
1 Fault Found:
- cornishdrummer
Re: Cornishdrummer's Progress Thread - UPDATES (pg 31)
Anyone help ?
Abs sensor are commonly faulty but will only error with a passenger in rear left. Worth clearing and then seeing mate.
- cornishdrummer
Cheers for the help, I have noticed its only when I have a passenger in rear left.
Got any clue on the other fault ?
- cornishdrummer
Re: Cornishdrummer's Progress Thread - ANYONE HELP (pg 31)
Can anyone help with this ?
1 Fault Found:
1 Fault Found:
Re: Cornishdrummer's Progress Thread -ANYONE HELP (pg 31)
sounds like an earth fault or the battery has been disconnected. Check your earths on the battery. Gear box and earth strap. It may have snapped as thats been known before!
- cornishdrummer
Battery was disconnected when I done the wiper stalk, thats the only time.
The car is running fine and everything
- cornishdrummer
Nothing new to report
Then why even bother writing this...??!cornishdrummer wrote:Nothing new to report
quiksilveralex
Godderz23 speaks the truth!Godderz23 wrote:Then why even bother writing this...??!cornishdrummer wrote:Nothing new to report
