Page 31 of 34
Re: Cornishdrummer's Progress Thread - VAGCOM (pg 30)
Posted: Tue Jul 26, 2011 8:25 pm
by cornishdrummer
So do I just plug the lead in and test the port and so on ?
Then is it best just to do a Auto-Scan ?
Is there any thing else worth doing as well ?
Posted: Wed Jul 27, 2011 7:25 am
by Endi_GTI
I usually just check the ABS, Engine and instruments for codes mate. Yeah the lead should be 1 of 4 COM ports i think. Just make sure she is running ok. If there are any codes, write them down, then clear them and take it for another spin and see if they have come back. If they come back you could have an unseen problem.
Posted: Wed Jul 27, 2011 7:46 am
by cornishdrummer
Cheers mate, I will get that done in the next few days.
Posted: Wed Jul 27, 2011 7:20 pm
by cornishdrummer
Getting my windscreen refitted on Monday as it keps steaming up, so they checked it today and want to take it out and refit it for me to see what the problem is.
Re: Cornishdrummer's Progress Thread - Vagcom Faults (pg 31)
Posted: Fri Jul 29, 2011 2:24 pm
by cornishdrummer
Pluged the car in today found two faults
1 Fault Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
1 Fault Found:
ABS Wheel speed sensor rear left (G46)
I knew the abs was playing up as when someone sat back there the light would come on but when they got out and light went out.
Posted: Tue Aug 02, 2011 3:51 pm
by cornishdrummer
Had my windscreen refitted yesterday, they found it was not put in right the 1st time and also some of the trim was not put back right, its looking much better as well now.
Also with the vagcom faults
1 Fault Found:
1 Fault Found:
With the 1st fault is it just a matter of a wrong fuse ?
With the ABS is it best to just clear it then drive it and test it again ?
Re: Cornishdrummer's Progress Thread - UPDATES (pg 31)
Posted: Thu Aug 04, 2011 3:48 pm
by cornishdrummer
Anyone help ?
Posted: Thu Aug 04, 2011 9:16 pm
by benmkiv
Abs sensor are commonly faulty but will only error with a passenger in rear left. Worth clearing and then seeing mate.
Posted: Fri Aug 05, 2011 8:48 am
by cornishdrummer
Cheers for the help, I have noticed its only when I have a passenger in rear left.
Got any clue on the other fault ?
Re: Cornishdrummer's Progress Thread - ANYONE HELP (pg 31)
Posted: Wed Aug 10, 2011 9:32 am
by cornishdrummer
Can anyone help with this ?
1 Fault Found:
Re: Cornishdrummer's Progress Thread -ANYONE HELP (pg 31)
Posted: Sat Aug 13, 2011 8:59 am
by Bepe
sounds like an earth fault or the battery has been disconnected. Check your earths on the battery. Gear box and earth strap. It may have snapped as thats been known before!
Posted: Sat Aug 13, 2011 9:39 am
by cornishdrummer
Battery was disconnected when I done the wiper stalk, thats the only time.
The car is running fine and everything
Posted: Sun Aug 28, 2011 12:19 pm
by cornishdrummer
Nothing new to report
Posted: Sun Aug 28, 2011 2:21 pm
by Godderz23
cornishdrummer wrote:Nothing new to report
Then why even bother writing this...??!
Posted: Sun Aug 28, 2011 5:49 pm
by quiksilveralex
Godderz23 wrote:cornishdrummer wrote:Nothing new to report
Godderz23 speaks the truth!
