Polo Blue GT
Re: Polo Blue GT
Not sure, none in UK but normally stuff arrives in 3 days from Germany
Re: Polo Blue GT
Parts turned up today, done a trial fit of the cover and looks great, when I get a break in the weather I'll fix the bracket, just need to line things up to double check where its fixes to, will take some piccies
3 day turnaround from order
- Mart!n-GTI-DK
- Drives: '14 Polo BlueGT
Re: Polo Blue GT
Sounds good.wigit wrote:Parts turned up today, done a trial fit of the cover and looks great, when I get a break in the weather I'll fix the bracket, just need to line things up to double check where its fixes to, will take some piccies
I ordered the other day too... So looking forward to see it on myself.
Norbreck21a
Re: Polo Blue GT
Looking forward to the pics guys.
Taking this a stage further, I noticed that there is no under bonnet insulation on the Blue GT, as there is on other models such as the SEL and Bluemotion versions. I noticed this first after a run when I put my hand on the bonnet and it was very hot. Any ideas if the under bonnet insulation from another Polo model will fit as well ?
Re: Polo Blue GT
I think some bluegt have bonnet insulation. Mine don't have it but I'm planing to install it.Norbreck21a wrote:Looking forward to the pics guys.
Re: Polo Blue GT
Ok. Thanks, I will order also VW one.wigit wrote:All parts are coming up on dealer system so have placed an order for the cover, bracket and screw which comes in at £51.28 inc VAT
You can always tell when an Audi cover has been smoothed, filled and painted, I have a TTS cover on my Ed35 and you can sometimes see it
I'll post some pics when it arrives
- Mart!n-GTI-DK
Re: Polo Blue GT
The Bonnet is identical on all the Polo's. So that shouldn't be a problem.Norbreck21a wrote:I noticed that there is no under bonnet insulation on the Blue GT, as there is on other models such as the SEL and Bluemotion versions. I noticed this first after a run when I put my hand on the bonnet and it was very hot. Any ideas if the under bonnet insulation from another Polo model will fit as well ?
BUT... I just had a look through ETKA. And there are three different choices of insulation for it. Not sure if this is just because there is three different suppliers or there are any other difference...
The numbers are:
6R0 863 831 B
6R0 863 831 C
6R0 863 831 D
Also ten of these clips are needed:
1H5 863 849 A 01C
Re: Polo Blue GT
B...diesel-turbo diesel-carburetor, C... top sports-aluminum, D... i do not know.
For example: http://www.aliexpress.com/store/product ... 59068.html
- Mart!n-GTI-DK
Re: Polo Blue GT
Found a page that says that B is; up to 03-03-2010 and C is; from 31.05.2010.
The aluminium heatshield on the one from aliexpress is useless on a BlueGT because it has the exhaust and off cause the turbo aswell fitted on the back of the engine towards the cabin. So I think the C should do fine since the turbo is fitted so far down that a heatshield is not needed to protect the insulation.
Link to Polo6rFreunde.de
Re: Polo Blue GT
Letters at the end of the p/n are revised parts. B is an improvement of A etc.
Re: Polo Blue GT
Ok.
Thanks for the link Mart!n.
- Mart!n-GTI-DK
Re: Polo Blue GT
further more... That insulation is actually made to absorb sound... So maybe people who have a problem with the way the BlueGT engine sounds should consider it...
Re: Polo Blue GT
Thanks. Anyone has insulation os his bluegt? Does it has come from factory?
Re: Polo Blue GT
What bluetooth kit are you using?
I'm planning VW 7P6 035 730 K since it's for an iPhone and don't have rsap (don't know if the Premium add something more).
- Mart!n-GTI-DK
Re: Polo Blue GT
No BlueGT's came with sound insulation from the factory.gtblue wrote:Thanks. Anyone has insulation os his bluegt? Does it has come from factory?
