New conditions
I'm waiting to receive the Gateway for the test bench.
2nd ECU, and BlueGT IC returns
Working on it. Level of difficulty 10/10 (without the appropriate tools).
- Abrites can't read the immo data from my GTI IC. 6RD920870A H04 0805 sw.
- Original VCP can't flash my GTI IC to downgrade to 0709 sw and get the immo data.
- I don't have the immo data from my 6R, well, I have them from my Original IC and BlueGT IC, but they are not correct or they are manipulated.
I still have an ace under the sleeve, maybe it works.🤷‍♂️
... I'm going to test these new lamps in my 6R Bixenon headlights ...
I have some envy of the headlights/lamps (6500K) that I installed in my wife's Golf. :lol:
viewtopic.php?f=56&t=70398&p=554361#p554101
Still working on the 2nd ECU and the BlueGT IC returns, now in the right direction 🙂... super funny experience (we are learning things that have not yet been written due to the level of difficulty to solve some bugs 😄). I can't provide relevant information, sorry.
In anycase my 6R works like a charm with my GTI IC and BRP repro, as ever.
Some irrelevant info:
To highlight, these buttons work correctly in my test bench with the software 0709 of my BlueGT IC, it's possible to access all the menus, but they do not work with the software 0805 of my GTI IC.
Speculation: maybe VW / VDO has made corrections in the IC software 0805 to avoid the known bugs when you install new stalks with trip computer buttons and you also have them in the MFSW at the same time.
In some of the trial and error phases to make the BlueGT IC work correctly things like this happen. Black screen.🤣
No problem.
Other corrections in eeprom file are needed.
More information when possible.
Time... to try it in the car.
Mods in GTI IC EEPROM
CH341A programmer
Testing what happens when installing blue needles with red leds. (s**t :lol:)
Cruise Control Display available in adaptation channels
02D9 ... from 01 to 81 enable bit7
Needles glow after Ignition OFF
02F2 ... from 0E to 4E enable bit6
Brake wear indicator (necessary to install the cables up to the brake pads and 17-Instruments coding, Byte1 Bit0)
02D3 ... from 46 to 47 enable bit0
Profile :?: :lol:
02E8 ... from 5C to DC enable bit7
BlueGT IC
I'm still struggling with the encrypted immobilizer data, many unsuccessful tests. :lol:
I'm going to test this type of 55W ballast ... which will really be 40W in its best condition ... together with the xenon OSRAM CBI 35W lamps.
The original ballasts are 35W, the original xenon lamps are 35W.
I'll let you know if my 6R comes out burning ... if I have time to escape ... :lol:
I still have to make an appointment with my VW dealer to regulate the headlights and other important things ... it will take some time. (I guess for the first week of June)
Making progress ...
Update
OK
My GTI IC
Perfect!
You can also enjoy watching this wonderful project :arrow: https://www.drive2.ru/l/531400018091835697/ 8) 8) 8)
Looking for a new menu ...
Convenience and/or Lights and Vision (CH/LH)
Example
Another example :arrow: https://uk-mkivs.net/topic/20240-highli ... ntry761427
According to the information I have available, by activating the adaptation channel "Car menu source" and configuring it to "Version 1", the mentioned menus are activated in MFD.
This happens in the instrument clusters for PQ25 that are sold in South America, ... Gol, Fox, Suran, etc ...
The source from which this information comes is from the BCM or a unit that I think is called VW i-system for PQ25. (depends on the date of manufacture)
I have dumped the eeprom data, by blocks / sectors, from a 5Z0 920 865 A H07 0010 instrument cluster (which has the mentioned menus activated and whose data structure is similar) in the eeprom of my BlueGT IC (except IMMO data, logically).
In each block/sector I have been checking with VCDS if this adaptation channel changed to available, ...without success.
Not available.🙈
With the IC in my test bench (without BCM, with Gateway) nothing appears, logically. :lol:
When the power was turned off a new information menu appeared suddenly in the MFD.
The tip to step on the clutch to start is between 0x000 and 0x13F
It disappears from my BlueGT IC when I paste in the eeprom this sector of Bytes from 5Z0 920 865 A eeprom.
2nd ECU updated in my Test bench viewtopic.php?f=56&t=58703&start=4695#p553672
- From sw 4039 to sw 5466.
- ODIS-E 9.0.4, VAS 5054, via Bluetooth. ... Perfect! 8)
Friday,31,May,2019,06:21:10:32438
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4505.4
Data version: 20190114 DS296.0
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: MKE data set loaded. gAtEwAy 🤭
Mileage: 40540km-25190mi   Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 65 77
VIN: WVWZZZ6RZDY0CICLO   Mileage: 40540km-25190miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 5466
   Revision: --H10---    Serial number: 00000000000000
   Coding: 001100D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
   ROD: EV_ECM12TFS02103F906070FP.rod
   VCID: 6A8D3FD44CF80237209-803E
Readiness: 0110 0101
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D300401700
   Shop #: WSC 40308 002 104857
   VCID: 025D77745448FA77889-8056
   Serial number: 08021613470174
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5038420709E97EC1-802A
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 3829D59C425460A766D-806C
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 122170091
   Coding: 3CB02FBF48E12400B3380F317CEB9FD05AC0670F600D30D0200000030800
   Shop #: WSC 00046 648 00255
   VCID: 2B03FAD08302DB3F1BF-807E
   Component: RLHS 220816 0  42  0106
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU003041440937042
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU006031440656541
   Coding: 1000A3
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 7 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H03 0103
   Serial number: 27140003142720054516
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU003051200017821
   Coding: 18BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU010051200012315
   Coding: 18BC32
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28231708304294
   Coding: 308001
   Shop #: WSC 02739 790 50316
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   VCID: 71BF28B8612EF1EF613-8024
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01JKVVP
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACD9F542C38E237009-801E
   Serial number: 3575HRB405N1C4LI7929
   Serial number: 3585HRB405B1D5MS8GS2
   Serial number: 3515RRB405B17ABS901.
   Serial number: 3525RRB405B181TUDPKC
   Part No SW: 6RD 920 870 A    HW: 6RD 920 870 A
   Component: KOMBI         H04 0805
   Coding: 140E01
   Shop #: WSC 00233 572 00255
   VCID: 47CBA6603F2A1F5F1F7-8012
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 002204
   VCID: 688945DC5274302736D-803C
   Revision: AA001001
   Coding: 0404000000000000000000
   Shop #: WSC 03607 002 104857
   VCID: 2E05F3C4B090AE173C1-807A
   Component: IMMO          H04 0805
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09.rod
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 010100
   VCID: 2A0DFFD48CF8C237E09-807E
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 C
   Component: RNS-MID       H06 5274
   Revision: AB001001    Serial number: VWZ6Z7L7654213
   Coding: 04000442040000A10001
   Shop #: WSC 12345 123 12345
   VCID: 372BD6A04F4A6FDF6F7-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V15  8515
   Part No: 6R0 423 156 B
   Coding: 11221
   Shop #: WSC 00788
   VCID: 2F3BEEC0BE5AA71F377-807A
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   VCID: 77AB16A00F4AAFDFAF7-8022
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
   Serial number: 40000000050821
   ROD: EV_RDKBERU30_005.rod
   VCID: 372BD6A04FCA6FDF6F7-8062
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664158506
   Coding: 0501000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3B23CA9073E24BBF8BF-806E
End----------(Elapsed Time: 01:58, VBatt start/end: 13.9V/13.9V)-----------
Locked
