Locked
Aszfaltbetyar
Post by Aszfaltbetyar »
If I upgrade my headlamp to factory xenon, i have to change my current BCM too?
Boom!! ... haha ... What is your current BCM?
You have two options:
A) OEM. You need to change many things besides BCM
B) No OEM. Xenon headlights OEM and adapter harness (from carsystem for example). No need to change BCM.
More info:
http://www.uk-polos.net/view ... 60#p481928
Image The following message to the message link is yours, you asked by the convenience menu too. :)
jobbercete
Drives: Polo 6R 1.2 TSI 90cv Sport
Post by jobbercete »
Wow wow wow wow wow.....one moment Ciclo...It's possible to install the OEM Xenon headlights on a halogen 6R adding only an adapter? Although 900€ for the pair of headlights hurts a bit too much I think :lol: :lol: Adding the adapter + shipping it's a pretty expensive mod :lol:
If only there was a "replica" headlights that doesn't look so cheap as the ones I've seen online... :roll:
Aszfaltbetyar
jobbercete wrote:Wow wow wow wow wow.....one moment Ciclo...It's possible to install the OEM Xenon headlights on a halogen 6R adding only an adapter? Although 900€ for the pair of headlights hurts a bit too much I think :lol: :lol: Adding the adapter + shipping it's a pretty expensive mod :lol:
I think it depend which BCM have you got.
But it seems highly recommended to buy the oem xenon, otherwise you can see that:
https://www.youtube*.com/watch?v=gjVZAKjKX7Y
These are BCM more used for factory xenon in 6R:
7H0 937 089 D
7H0 937 089 F
7H0 937 090
7H0 937 090 B
... the last update ...
Also those that are utilized by Polo BlueMotion, but only in Polo BlueMotion.
085,086,087. No.
OEM xenon headlights can be installed in any 6R with any BCM and with adapter harness of carsystem.
Also for example: http://www.xenonz.co.uk/polo-6r-gti-drl-headlights.html
But it's better than xenon lamps be among 4300-5000k. Better lighting.
Read the descriptions of the links on the following link to legal matters in your country.
Image :lol: :lol: :lol:
I take this opportunity to say that is possible install automatic lights OEM in 6R with halogen headlights without start stop system.
Required before:
- Light sensor
- BCM. 089, 090.
- Eliminate the relay J331
- Modify the installation of the low beam, rear fog light and of interior light switch (regulator of intensity) next to the light switch.
The work area is between BCM, fuse box and light switch connectors.
Installation guide: http://www.uk-polos.net/view ... 97#p483697
After, for example, my wiring for automatic lights. :)
http://www.uk-polos.net/view ... 09#p478298
Update of my project for the winter
http://www.uk-polos.net/view ... 40#p483540
Aszfaltbetyar
THX the infos ciclo!
In my country (Hungary) the xenon without auto-leveling system and headlamp washer are illegal. (because blinded the oncoming traffic)
I have BCM with this version 6R0 937 087K (thats comfortline with halogen headlamp, headlamp washer and manual high position)
Is the OEM xenon include the cornering light?
I have to buy the following to change xenon:
- VW Auto Leveling + 2x Sensor - Retrofit KIT (i can't find for 6R, but i think the golf 6 is similar) 359 €
- new BCM ~ 200 €
- OEM Xenon headlamp 900 €
- VCDS programing + work
About 1500 € :D
I think i stay halogen lamp! :)
jobbercete
I think that I need to check my BCM number...just to check if I can do the trick for the OEM automatic lights (pleaseeeeee, the chinese kit is driving me madddd).
jobbercete wrote:I think that I need to check my BCM number...just to check if I can do the trick for the OEM automatic lights (pleaseeeeee, the chinese kit is driving me madddd).
https://drive.google.com/file/d/0B2nv91 ... dEYW8/view
Last update of my project for the winter
On the last page, important information about the heated wiper ejectors ...
Keep in mind that the thermal resistance of heated wiper ejectors just heat the ejectors and not the whole pipe system. :wink:
Finally this was done:
http://www.uk-polos.net/view ... 92#p483992
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Post by Mart!n-GTI-DK »
ciclo wrote:Last update of my project for the winter
I allready have those stock on mine. :)
You have the winter package.Image
Mart!n-GTI-DK
ciclo wrote:You have the winter package.Image
It's part of a package the danish Importer has put together for the Danish Climate.
Can't imagine you have much use for it in Spain. :)
It has the same meaning as harden the shock absorbers in countries where it rains permanent, only few days throughout the year in which to enjoy it.
Spain has a wide climatic range, apart from the Mediterranean climate Image, most of the territory is mountainous with two large plateaus (not Siberia Image :lol: ) where it is quite cold.
The second most mountainous country in Europe after Switzerland.
The climatic variety of Spain is the best thing of Spain. Just perfect. :wink:
vc-10
Post by vc-10 »
Unlike England, where it just rains solidly 365 days per year... or at least, it does here in Manchester!
Locked
