Well, I've bought a new screen for my DM because the new one I installed doesn't quite convince me, the colours are not very bright and there are other small deficiencies typical of copies (90€ for the copy vs XXX€ for the supposedly original 'TRULY'). I didn't even know I had to pay attention to these little details...🤦‍♂️
The 90€ screen can work perfectly if you're on a tight budget, but it's not ideal.
Now it's time to wait for the 'TRULY' to arrive to install it.
https://www.youtube.com/watch?v=qG2Naq27enE
POLO 6R. New remote controls. Additional/Complementary information.
Previously --> viewtopic.php?p=607474#p607474
The transponder is generated by placing it into one of the two small bowls/holes on the VVDI mini key tool... also later once associated/attached/glued to the PCB/Remote.
Good tools to remove/install the blade 'without damaging it' (hammer, punch, inappropriate pliers), although there is no good tool if you do not know how to use it properly, it is advisable to experiment before final use. I recommend purchasing additional tips for both tools (0,.. 1u).😁
Super Model/Remote.
:arrow: :arrow: :arrow: https://www.youtube.com/watch?v=29f4tNUP7aI
It is advisable to remove and reinsert the key from the ignition switch for the 8 data captures, which are isofacto.
The online calculation takes about a minute, I guess it depends on the type of connection.
VCDS Autoscan.
Friday,21,February,2025,12:24:08:32438
VCDS Version: 24.7.1.0 (x64)  HEX-V2 CB: 0.4643.4
Data version: 20240919 DS356.3
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: FIVE REMOTES OK!
Mileage: 88960km-55277mi   Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 3C 44 55 56 65 77
VIN: WVWZZZ6RZDY0VENOM   Mileage: 88960km-55277miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 5466
   Revision: --H10---    Serial number: 00000000000000 CVN: 9A6217E3
   Coding: 001100D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
   ROD: EV_ECM12TFS02103F906070FD_004.rod
   VCID: 6A8D3FD44CF8023AE1F-803E
   VINID: 9E69EAAAA1A2A94A400030C808A8E303EA
Readiness: 0110 0101
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D300401700
   Shop #: WSC 40308 002 104857
   VCID: 025D77745448FA7A49F-8056
   Serial number: 08021613470174
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5038420709E9A2D7-802A
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0812
   Revision: V0000000
   VCID: 3829D59C425460AAA7B-806C
   Revision: B9084001    Serial number: 2502 179190157
   Coding: 3CB02FBF48E12400B3380F317CEB9FD05AC8670F600D39D0200400030800
   Shop #: WSC 00046 123 12345
   VCID: 2D07F4C8BD16D502C4D-8078
   Component: RLHS 220816 0  42  0106
   Coding: 0228DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU003041440937042
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU006031440656541
   Coding: 1000A3
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU003051200017821
   Coding: 18BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU010051200012315
   Coding: 18BC32
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28231708304294
   Coding: 30A001
   Shop #: WSC 02739 790 50316
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   VCID: 71BF28B8612EF1E2A05-8024
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01JKVVP Dataset Number: v00305696R0 0001
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACD9F542C38E23AC1F-801E
   Serial number: 3575HRB405N1C4LI7929
   Serial number: 3585HRB405B1D5MS8GS2
   Serial number: 3515RRB405B17ABS901.
   Serial number: 3525RRB405B181TUDPKC
   Part No SW: 6RD 920 870 A    HW: 6RD 920 870 A
   Component: KOMBI         H04 0805
   Coding: 140E01
   Shop #: WSC 00233 572 00255
   VCID: 47CBA6603F2A1F52DE1-8012
   Revision: B9084001
   Coding: 002204
   VCID: 688945DC5274302AF7B-803C
   Revision: AA001001
   Coding: 0404000000000000000000
   Shop #: WSC 03607 002 104857
   ROD: EV_HighBeamAssisAU316_VW32.rod
   VCID: 2E05F3C4B090AE1AFD7-807A
   Component: IMMO          H04 0805
   Shop #: WSC 12345 123 12345
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 010100
   VCID: 2A0DFFD48CF8C23A21F-807E
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 1T0 035 686 F    HW: 1T0 035 686 f
   Component: RNS-MID       H27 6276
   Revision: AB001001    Serial number: VWZ6Z7T1727264
   Coding: 04000440040000A10001
   Shop #: WSC 33361 790 00118
   VCID: 372BD6A04F4A6FD2AE1-8062
   Subsystem 1 - Part No: 1T0 051 859 AS
   Component: EU West V17  8557
Address 3C: Lane Change (J1086)       Labels:| 5Q0-907-686.clb
   Component: HRE_Master    H12 0081
   Serial number: 0519386082 Dataset Number: V03935258DF 0001
   Coding: 03011102
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D27C4886DF6458274D-8068
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 5Q0 907 685 C    HW: 5Q0 907 685 C
   Component: HRE_Slave  H12 0081
   Serial number: 0519601132
   Coding: 030111
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F3BEEC0BE5AA712F61-807A
   Revision: --------    Serial number: -------------- Dataset Number: 6R0036v____ 0005
   Coding: 0112000001000000
   VCID: 77AB16A00F4AAFD26E1-8022
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
   Serial number: 40000000050821
   ROD: EV_RDKBERU30_005.rod
   VCID: 372BD6A04FCA6FD2AE1-8062
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664158506 Dataset Number: 7P6035730L  0001
   Coding: 0501000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3B23CA9073E24BB24A9-806E
End----------(Elapsed Time: 02:08, VBatt start/end: 14.0V/14.0V)-----------
VVDI mini key tool is popular. Recommended for both home users and small additional businesses/services. Easy to use. Fast and efficient.👍
The cost of this entire process (tools, remotes, etc.) was the same as ordering a single remote key from an official dealer (200*).
I never intended to make any money out of this, so I'll be making free copies of the 9 remaining remote controls to family, friends or ....trusted people.😄
https://www.youtube.com/watch?v=tBu-ewMRhkA&t=82s 🖐
POLO 6R. Discover Media project. Second screen replacement.🤭
Previous information:
- viewtopic.php?p=607565#p607565
- viewtopic.php?p=607566#p607566
Received 'ORIGINAL' screen, NOT COPY.
Some images of the replacement process.
(https://www.youtube.com/embed/-89olFvY2 ... autoplay=1)
Now everything looks and feels like the original factory screen, sharp, bright colors and excellent touch response, equal or maybe better than the original factory screen.👌
Copy 90 vs Original 145 (with coupon and coin discounts, those things I never did before 😁), both purchased on Aliexpress.
I have been telling myself over and over again for a long time that I should not buy cheap, but since this project is at the limit of what is reasonable, I let myself be fooled into looking for a 'bargain', and also because I did not inform myself adequately beforehand to buy the right screen.🤦‍♂️
Everyone should be a millionaire for free and permanently so that there would be no imitations/copies that waste our time.
https://www.youtube.com/watch?v=-7XX0cf0EOo
Re: ciclo's Polo. R-line 1.2 TSI 90hp 119gr.🤝
POLO 6R. 90,000Km. Oil service and Inspection.
According to erWin.📋 :arrow: https://drive.google.com/drive/folders/ ... drive_link
Filters/oil info: https://uk-polos.net/viewtopic.php?p=589357#p589357 (idem)
Reset.
VCDS AutoScan.
Thursday,10,April,2025,08:57:40:32438
VCDS Version: 25.3.0.4 (x64)  HEX-V2 CB: 0.4660.4
Data version: 20250311 DS365.0
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: SERVICE & INSPECTION / ENGINE_OIL/AIR FILTERS / CABIN INT/EXT FILTERS. OK!
Mileage: 90000km-55923mi   Repair Order:
VIN: WVWZZZ6RZDY0CICLO   Mileage: 90000km-55923miles
   VCID: 6A8D3FD44CF8023A313-803E
   Revision: --------
   VCID: 025D77745448FA7A993-8056
   Coding: 01
   VCID: 7EA5038420709E9AFDB-802A
   Revision: V0000000
   VCID: 3829D59C425460AA777-806C
   VCID: 2D07F4C8BD16D502141-8078
   Coding: 0228DD
   Coding: 0200A3
   Coding: 1000A3
   Coding: 18BC32
   Coding: 18BC32
   Coding: 30A001
   VCID: 71BF28B8612EF1E2709-8024
   Coding: 00314D
   VCID: 4ACD9F542C38E23A113-801E
   Crash sensor for side airbag: passenger side:
   Coding: 140E01
   VCID: 47CBA6603F2A1F520ED-8012
   Revision: B9084001
   Coding: 002204
   VCID: 688945DC5274302A277-803C
   Revision: AA001001
   VCID: 2E05F3C4B090AE1A2DB-807A
   Coding: 010100
   VCID: 2A0DFFD48CF8C23AF13-807E
   VCID: 372BD6A04F4A6FD27ED-8062
   Coding: 03011102
   VCID: 3D27C4886DF64582A41-8068
   Coding: 030111
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F3BEEC0BE5AA71226D-807A
   VCID: 77AB16A00F4AAFD2BED-8022
   VCID: 372BD6A04FCA6FD27ED-8062
   ROD: EV_UHVNA_002_VW25.rod
   VCID: 3B23CA9073E24BB29A5-806E
End----------(Elapsed Time: 02:10, VBatt start/end: 13.9V/14.0V)-----------
---------------------------No fault code found.----------------------------
Everything works as it should, to last and last and last... 🏎🏎🏎
External cabin/AC filter.
Essential. It will keep your A/C system components clean.
Double filtration. It "really works" even with harmful particles emitted by other vehicles.
https://uk-polos.net/viewtopic.php?p=540413#p540413
Hmm... about the oil drain plug:
CBZC EA_111
I hope to start the Discover Media project soon, I've been a bit busy having fun with our Golf.
POLO 6R. Testing a new steering wheel button frame in glossy black and the red R logo.
Glossy Black Returns...😁
ANCEL BD500
Perfect for quickly diagnosing and clearing DTCs. Ideal for storing in the drawer under the seat. Some functions. Not for coding!
At the end of the road, the flight begins.
I've spoken with the masters of the universe, and starting next week, there will finally be sunshine and good temperatures.🤸‍♂️
Backlight of MQB Multifunction Buttons on PQ25. Dimmer: (to Amir🤗)
Video: :arrow: https://www.youtube.com/embed/595_K_89C ... autoplay=1
https://www.youtube.com/watch?v=KjuXmIDUNGI&t=101s
POLO 6R. Discover Media project. PQ to MQB wiring Adapter. MEDIA-IN_AUX. USB HUB. USB1. Micro.
Concepts:
- I'm going to keep the factory Media Player module (J650) located in the glove compartment as an external audio source (AUX). From factory has a Standard USB cable for audio sources or phone charging.
- In the center console, by replacing the current AUX socket, I'm going to install the USB1 HSD (High-Speed ​​Data Transfer -LVDS protocol-) via USB HUB for full communications and phone charging.💎🧙‍♂️
This way, everything will be efficient, comfortable, easy to install and fit perfectly, as if it were made in the factory of your dreams. 😁
Toughts:
Although I have what's needed to install the USB2 HSD (HSD cable and USB), and it's an very easy taks, I won't be doing it now, maybe in the future, depending on personal/family needs. There are already too many connection sources on the Discover Media PQ: CD player, SD card, USB_Media-IN_AUX1, AUX2, USB1 HSD, Bluetooth, Wi-Fi.
Wiring Adapter.
Ali.
Needs improvements according to requirements.
Schematics/Diagrams.
ETKA: There are two models of 6R Quadlock connectors for RCD/RNS, depending on the manufacturing date: <--05/2010-->. PQ to MQB wiring adapter is suitable for both models.
Improvements: (images, no comment)
Info: https://uk-polos.net/viewtopic.php?p=574583#p574583
The RVC KA1 in the next post.
https://www.youtube.com/watch?v=6VyMZ976u4s&t=135s
POLO 6R. Discover Media project. MQB RVC KA1. RVC wiring. MQB PDC unit.
In this wiring harness of the above image, the ground wire is connected/attached/spliced ​​to the adapter for the emblem switch. In older wiring harnesses, the ground wire is a single wire that must be connected to the vehicle body.
Note:
PDF, additional information:
https://drive.google.com/file/d/0B2nv91 ... 4w6rYVFgkQ (Spanglish 2013🤭)
I had this MQB RVC KA1 installed in the Golf 7.5. :arrow: viewtopic.php?p=581351#p581351
I had this MQB PDC unit installed in the Polo 6R. :arrow: viewtopic.php?p=588911#p588911 , ... Uninstalled for testing with the original PQ PDC unit when I installed BSD/RTA - Lane Change Assist -.
More info in this thread and in my wife's Golf thread.🤗
https://www.youtube.com/watch?v=B_Ain-ys6q0 Image
POLO 6R. Discover Media project. MQB RVC KA1. RVC wiring. Installed.
Previous information in the previous post.
Images with additional information on the rear lid connectors... those images that people later search for for other reasons. 😊🤗
I checked the original wiring inside the corrugated tube. It's in perfect condition. I double-taped it with cloth tape when installing the DAB antenna.
I assume the wires that break in this section of wiring tend to break in colder/harsher weather conditions.🤷‍♂️
My 13-year-old 6R has always slept in the garage.
Fusebox SB. +30. RL.
I already had the wires installed for the +30 signal and Reverse Light signal from the previous PQ RVC KA1, so it was just a matter of cutting and splicing the wires in the left trunk space (C-pillar) and running the video signal parallel to the original wiring to the Discover Media. Easy peasy.😅
I have the Discovery Media project almost finished, much more information coming soon.
https://www.youtube.com/watch?v=hEFL3reHKLA&t=334s
POLO 6R. Discover Media Project. Wiring adapter, USB HUB, and USB1 HSD Installed.
Previous info: https://uk-polos.net/viewtopic.php?p=608229#p608229
To charge the second phone 'easily'...
I also installed a 20A fuse in Fusebox SB45 slot instead of the factory 15A fuse, as otherwise the 15A fuse would blow due to the initial draw of the devices on this power line... and one of the main reasons I increased the thickness of the power/ground in the wiring adapter.
I left the 15A fuse in 'to test' how it would blow... and indeed it did.😄
I've already installed/overlaid the DM, and I'm running functional testing and learning how to use it.
To be continued...
Happy weekend to everyone without exception!
https://www.youtube.com/watch?v=IBhkpkvfaxE
POLO 6R. Discover Media project. RTA testing. 1ST Autoscan.
Two lanes in each direction at the rear.
These 5Q0 rear radars work exactly the same as when I had them installed in the Golf.✅
At the moment, my 6R doesn't have an audible warning signal when reversing into nearby cross traffic, and of course, it doesn't have automatic braking.
The on-screen signals are clear and 'very helpful'.😎
Everything clear and clean.😄
RTA ON/OFF, video: :arrow: :arrow: :arrow: https://www.youtube.com/embed/jehC7iSQZ ... autoplay=1
On the other hand, seems that VW uses the same parking place as me to calibrate the MQB RVC KA1 Lowline.
🤷‍♂️ :lol:
VCDS AutoScan
Thursday,29,May,2025,14:43:21:32438
VCDS Version: 25.3.1.0 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20250408 DS365.0
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: DISCOVER MEDIA 1ST AUTOSCAN OK!
Mileage: 91290km-56724mi   Repair Order:
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 3C 44 55 5F 65
VIN: WVWZZZ6RZDY0CICLO   Mileage: 91290km-56724miles
   VCID: 6A8D3FD44CF8023A31F-803E
   Revision: --------
   VCID: 025D77745448FA7A99F-8056
   Coding: 01
   VCID: 7EA5038420709E9AFD7-802A
   Revision: V0000000
   VCID: 3829D59C425460AA77B-806C
   VCID: 2D07F4C8BD16D50214D-8078
   Coding: 0228DD
   Coding: 0200A3
   Coding: 1000A3
   Coding: 18BC32
   Coding: 18BC32
   Coding: 30A001
   VCID: 71BF28B8612EF1E2705-8024
   Coding: 00314D
   VCID: 4ACD9F542C38E23A11F-801E
   Coding: 140E01
   VCID: 47CBA6603F2A1F520E1-8012
   Revision: B9084001
   Coding: 00220F
   VCID: 688945DC5274302A27B-803C
   Revision: AA001001
   VCID: 2E05F3C4B090AE1A2D7-807A
   Coding: 020100
   VCID: 2A0DFFD48CF8C23AF1F-807E
   Coding: 03011102
   VCID: 3D27C4886DF64582A4D-8068
   Coding: 030111
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F3BEEC0BE5AA712261-807A
   VCID: 77AB16A00F4AAFD2BE1-8022
   Component: MU-S-ND-ER    H41 0480
   Serial number: VWZAZ2W1480534 Dataset Number: V03935270BD 0001
   Coding: 02620001FF00000051110101C0880A401F0106D400A001008F
   Shop #: WSC 34480 348 34480
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 25170CE8E566ED42DCD-8070
   Data carrier:
   Subsystem 1 - Part No SW: 5NA 919 866 ET    HW: -----------
   Component: ECE AS 24/25  --- 2210
   VCID: 372BD6A04FCA6FD27E1-8062
End----------(Elapsed Time: 02:02, VBatt start/end: 13.7V/13.7V)-----------
Please disregard the codings yet, I'm in the testing phase... Thanks!!
https://www.youtube.com/watch?v=bydW0NyYe38
POLO 6R. Discover Media project. NEW shark fin antenna 'AM/FM1' + GPS. First step.
Discover Media doesn't like non-original antennas.🤷‍♂️😄
My wonderful old shark fin antenna AM/FM1 + GPS has worked perfectly all these years for the RNS 510 without a diagnostic error... but since the GPS antenna is non-original, and despite working correctly with the DM, now, the diagnostics detect an Open Circuit fault.
Old shark fin antenna: :arrow: viewtopic.php?p=469083#p469083
I'm going to fix this by building a new fully OEM shark fin antenna (electronically speaking) for both 'AM/FM1' and GPS 'more updated'.
Images (no comments):
Image that could be very useful here: https://uk-polos.net/viewtopic.php?p=588890#p588890
This requires making a new hole in the roof for a new model of shark fin antenna.🤭
To be continued in the next post...
https://www.youtube.com/watch?v=YqeW9_5kURI
POLO 6R. Discover Media project. NEW shark fin antenna. Roof Hole Template. Measurements.
Idea/How to... YouTube video:
💎💎💎 https://www.youtube.com/watch?v=VdcgYNKIEV4 👍
Measurements and template:
+/- 0.02
Template made with clear plastic from a Tupperware container.
I marked the "left side" with four dots to transfer the measurements to the roof and not make a big mistake.
Don't do this if you lack the necessary skills or tools, return the new beautiful and update antenna to sender and buy the horrible 6R Original Swordfish Fin Antenna with stealable rod.😁
https://www.youtube.com/watch?v=W0DM5lcj6mw
POLO 6R Discover Media project. Hole-cutting test for the new shark fin antenna. Appearance of the new MQB RVC KA1.
It's not a perfect job, it's a test to make sure the/my template is correct.✅
Just as I was finishing it, my little grinder/cutter stopped working, it was too hot. 🔥🔥🔥 ...this steel plate for this test is at least three times stronger than car sheet metal, it's what I used to build the structural supports for the BSD radars.
I have to look for cordless grinders, or those with 135W power, the inverter only delivers a maximum of 150W.
Since I washed the car to make the hole in the roof, I took some photos of what the MQB RVC KA1 looks like.
8)
Both VW emblems now have a gloss black background (6C/Golf7) on my 6R R-line.
Related (2015): viewtopic.php?p=493578#p493578
https://www.youtube.com/watch?v=jRTJ9HoR9qo
POLO 6R. Discover Media project. USB-C in the 'glove compartment' for phone charging via J650. USB and AUX Ports.
USB-C.
Video: :arrow: :arrow: :arrow: https://www.youtube.com/embed/PueQSeLZB ... autoplay=1 🤭
Only for charging devices with a USB-C charging port, not for data transmission. Despite the coding/adaptation possibilities it was not possible for me to make J650 MEDIA-IN compatible 'as an AUX socket' with Discover Media and the reason for installing this new cable with USB-C.
For phone charging it is a very good reason to keep the J650 unit in the glove compartment and not throw it away or undo the original installation.🤷‍♂️
USB1, USB2, AUX.
For data transmission, I have the USB1 HSD in the 'center console' and a possible USB2 HSD in the future, both via USB HUB.
USB1.
For more information see previous posts.
USB2, AUX.
I already have planned where to install the USB2 HSD and a functional AUX socket, but that will be in the hypothetical future.
I expect the DM project will be finished by next week, I still need to receive a grinder I bought to make the hole in the roof to install the new 'OEM' shark fin antenna.
https://www.youtube.com/watch?v=v01q01LbWzI
Locked
