Page 326 of 333
Posted: Mon Feb 17, 2025 9:13 pm
by ciclo
Well, I've bought a new screen for my DM because the new one I installed doesn't quite convince me, the colours are not very bright and there are other small deficiencies typical of copies (90⬠for the copy vs XXX⬠for the supposedly original
'TRULY'). I didn't even know I had to pay attention to these little details...
The 90β¬ screen can work perfectly if you're on a tight budget, but it's not ideal.
Now it's time to wait for the
'TRULY' to arrive to install it.
https://www.youtube.com/watch?v=qG2Naq27enE
Posted: Sat Feb 22, 2025 6:10 am
by ciclo
POLO 6R. New remote controls. Additional/Complementary information.
Previously -->
viewtopic.php?p=607474#p607474
The transponder is generated by placing it into one of the two small bowls/holes on the VVDI mini key tool... also later once associated/attached/glued to the PCB/Remote.
Good tools to remove/install the blade 'without damaging it' (hammer, punch, inappropriate pliers), although there is no good tool if you do not know how to use it properly, it is advisable to experiment before final use. I recommend purchasing additional tips for both tools (0,.. 1u).
Super Model/Remote.
https://www.youtube.com/watch?v=29f4tNUP7aI
It is advisable to remove and reinsert the key from the ignition switch for the 8 data captures, which are isofacto.
The online calculation takes about a minute, I guess it depends on the type of connection.
VCDS Autoscan.
Friday,21,February,2025,12:24:08:32438
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240919 DS356.3
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO License Plate: FIVE REMOTES OK!
Mileage: 88960km-55277mi Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 3C 44 55 56 65 77
VIN: WVWZZZ6RZDY0VENOM Mileage: 88960km-55277miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 GD HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 5466
Revision: --H10--- Serial number: 00000000000000 CVN: 9A6217E3
Coding: 001100D6202400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
ROD: EV_ECM12TFS02103F906070FD_004.rod
VCID: 6A8D3FD44CF8023AE1F-803E
VINID: 9E69EAAAA1A2A94A400030C808A8E303EA
Readiness: 0110 0101
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3216D00B5842814EA84D300401700
Shop #: WSC 40308 002 104857
VCID: 025D77745448FA7A49F-8056
Serial number: 08021613470174
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5038420709E9A2D7-802A
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0812
Revision: V0000000
VCID: 3829D59C425460AAA7B-806C
Part No SW: 7E0 937 090 E HW: 7E0 937 090 E
Revision: B9084001 Serial number: 2502 179190157
Coding: 3CB02FBF48E12400B3380F317CEB9FD05AC8670F600D39D0200400030800
Shop #: WSC 00046 123 12345
VCID: 2D07F4C8BD16D502C4D-8078
Component: RLHS 220816 0 42 0106
Coding: 0228DD
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8612
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8612
Coding: 1000A3
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Subsystem 8 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU003051200017821
Coding: 18BC32
Subsystem 9 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU010051200012315
Coding: 18BC32
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 AA HW: 7N0 919 475
Component: PARKHILFE 8K H06 0212
Revision: -------- Serial number: 28231708304294
Coding: 30A001
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_VW75XParkAssis8K 001012
VCID: 71BF28B8612EF1E2A05-8024
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX01JKVVP Dataset Number: v00305696R0 0001
Coding: 00314D
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4ACD9F542C38E23AC1F-801E
Serial number: 3575HRB405N1C4LI7929
Serial number: 3585HRB405B1D5MS8GS2
Serial number: 3515RRB405B17ABS901.
Serial number: 3525RRB405B181TUDPKC
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H04 0805
Coding: 140E01
Shop #: WSC 00233 572 00255
VCID: 47CBA6603F2A1F52DE1-8012
Part No SW: 7E0 909 901 HW: 7E0 937 090 E
Revision: B9084001
Coding: 002204
VCID: 688945DC5274302AF7B-803C
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 0404000000000000000000
Shop #: WSC 03607 002 104857
ROD: EV_HighBeamAssisAU316_VW32.rod
VCID: 2E05F3C4B090AE1AFD7-807A
Component: IMMO H04 0805
Shop #: WSC 12345 123 12345
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7662584630
Coding: 010100
VCID: 2A0DFFD48CF8C23A21F-807E
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 686 F HW: 1T0 035 686 f
Component: RNS-MID H27 6276
Revision: AB001001 Serial number: VWZ6Z7T1727264
Coding: 04000440040000A10001
Shop #: WSC 33361 790 00118
VCID: 372BD6A04F4A6FD2AE1-8062
Subsystem 1 - Part No: 1T0 051 859 AS
Component: EU West V17 8557
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Serial number: 0519386082 Dataset Number: V03935258DF 0001
Coding: 03011102
ROD: EV_HREntryHella_VW37.rod
VCID: 3D27C4886DF6458274D-8068
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0081
Serial number: 0519601132
Coding: 030111
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
VCID: 2F3BEEC0BE5AA712F61-807A
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: -------------- Dataset Number: 6R0036v____ 0005
Coding: 0112000001000000
VCID: 77AB16A00F4AAFD26E1-8022
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 40000000050821
ROD: EV_RDKBERU30_005.rod
VCID: 372BD6A04FCA6FD2AE1-8062
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 L HW: 7P6 035 730 L
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664158506 Dataset Number: 7P6035730L 0001
Coding: 0501000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3B23CA9073E24BB24A9-806E
End----------(Elapsed Time: 02:08, VBatt start/end: 14.0V/14.0V)-----------
VVDI mini key tool is popular. Recommended for both home users and small additional businesses/services. Easy to use. Fast and efficient.
The cost of this entire process (tools, remotes, etc.) was the same as ordering a single remote key from an official dealer (200*).
I never intended to make any money out of this, so I'll be making free copies of the 9 remaining remote controls to family, friends or ....trusted people.
https://www.youtube.com/watch?v=tBu-ewMRhkA&t=82s π
Posted: Wed Feb 26, 2025 6:27 am
by ciclo
POLO 6R. Discover Media project. Second screen replacement.
Previous information:
viewtopic.php?p=607565#p607565
viewtopic.php?p=607566#p607566
Received 'ORIGINAL' screen, NOT COPY.
Some images of the replacement process.
https://www.youtube.com/embed/-89olFvY2 ... autoplay=1)
Now everything looks and feels like the original factory screen, sharp, bright colors and excellent touch response, equal or maybe better than the original factory screen.
Copy 90 vs Original 145 (with coupon and coin discounts, those things I never did before
both purchased on Aliexpress.
I have been telling myself over and over again for a long time that I should not buy cheap, but since this project is at the limit of what is reasonable, I let myself be fooled into looking for a 'bargain', and also because I did not inform myself adequately beforehand to buy the right screen.
Everyone should be a millionaire for free and permanently so that there would be no imitations/copies that waste our time.
https://www.youtube.com/watch?v=-7XX0cf0EOo
Posted: Sat Mar 01, 2025 3:57 am
by ciclo
Re: ciclo's Polo. R-line 1.2 TSI 90hp 119gr.🤝
Posted: Wed Apr 16, 2025 6:57 pm
by ciclo
POLO 6R. 90,000Km. Oil service and Inspection.
According to erWin.
https://drive.google.com/drive/folders/ ... drive_link
Filters/oil info:
https://uk-polos.net/viewtopic.php?p=589357#p589357 (idem)
Reset.
VCDS AutoScan.
Thursday,10,April,2025,08:57:40:32438
VCDS Version: 25.3.0.4 (x64) HEX-V2 CB: 0.4660.4
Data version: 20250311 DS365.0
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO License Plate: SERVICE & INSPECTION / ENGINE_OIL/AIR FILTERS / CABIN INT/EXT FILTERS. OK!
Mileage: 90000km-55923mi Repair Order:
VIN: WVWZZZ6RZDY0CICLO Mileage: 90000km-55923miles
VCID: 6A8D3FD44CF8023A313-803E
Revision: --------
VCID: 025D77745448FA7A993-8056
Coding: 01
VCID: 7EA5038420709E9AFDB-802A
Revision: V0000000
VCID: 3829D59C425460AA777-806C
VCID: 2D07F4C8BD16D502141-8078
Coding: 0228DD
Coding: 0200A3
Coding: 1000A3
Coding: 18BC32
Coding: 18BC32
Coding: 30A001
VCID: 71BF28B8612EF1E2709-8024
Coding: 00314D
VCID: 4ACD9F542C38E23A113-801E
Crash sensor for side airbag: passenger side:
Coding: 140E01
VCID: 47CBA6603F2A1F520ED-8012
Revision: B9084001
Coding: 002204
VCID: 688945DC5274302A277-803C
Revision: AA001001
VCID: 2E05F3C4B090AE1A2DB-807A
Coding: 010100
VCID: 2A0DFFD48CF8C23AF13-807E
VCID: 372BD6A04F4A6FD27ED-8062
Coding: 03011102
VCID: 3D27C4886DF64582A41-8068
Coding: 030111
Coding: 11250
Shop #: WSC 00788
VCID: 2F3BEEC0BE5AA71226D-807A
VCID: 77AB16A00F4AAFD2BED-8022
VCID: 372BD6A04FCA6FD27ED-8062
ROD: EV_UHVNA_002_VW25.rod
VCID: 3B23CA9073E24BB29A5-806E
End----------(Elapsed Time: 02:10, VBatt start/end: 13.9V/14.0V)-----------
---------------------------No fault code found.----------------------------
Everything works as it should, to last and last and last...
πππ
External cabin/AC filter.
Essential. It will keep your A/C system components clean.
Double filtration. It "really works" even with harmful particles emitted by other vehicles.
https://uk-polos.net/viewtopic.php?p=540413#p540413
Hmm... about the oil drain plug:
CBZC EA_111
I hope to start the Discover Media project soon, I've been a bit busy having fun with our Golf.
Posted: Fri Apr 18, 2025 7:32 pm
by ciclo
Posted: Tue May 20, 2025 8:51 pm
by ciclo
POLO 6R. Discover Media project. PQ to MQB wiring Adapter. MEDIA-IN_AUX. USB HUB. USB1. Micro.
Concepts:
- I'm going to keep the factory Media Player module (J650) located in the glove compartment as an external audio source (AUX). From factory has a Standard USB cable for audio sources or phone charging.
- In the center console, by replacing the current AUX socket, I'm going to install the USB1 HSD (High-Speed ββData Transfer -LVDS protocol-) via USB HUB for full communications and phone charging.
This way, everything will be efficient, comfortable, easy to install and fit perfectly, as if it were made in the factory of your dreams.
Toughts:
Although I have what's needed to install the USB2 HSD (HSD cable and USB), and it's an very easy taks, I won't be doing it now, maybe in the future, depending on personal/family needs. There are already too many connection sources on the Discover Media PQ: CD player, SD card, USB_Media-IN_AUX1, AUX2, USB1 HSD, Bluetooth, Wi-Fi.
Wiring Adapter.
Ali.
Needs improvements according to requirements.
Schematics/Diagrams.
ETKA: There are two models of 6R Quadlock connectors for RCD/RNS, depending on the manufacturing date:
<--05/2010-->. PQ to MQB wiring adapter is suitable for both models.
Improvements: (images, no comment)
Info:
https://uk-polos.net/viewtopic.php?p=574583#p574583
The RVC KA1 in the next post.
https://www.youtube.com/watch?v=6VyMZ976u4s&t=135s
Posted: Wed May 21, 2025 1:00 pm
by ciclo
POLO 6R. Discover Media project. MQB RVC KA1. RVC wiring. MQB PDC unit.
In this wiring harness of the above image, the ground wire is connected/attached/spliced ββto the adapter for the emblem switch. In older wiring harnesses, the ground wire is a single wire that must be connected to the vehicle body.
Note:
PDF, additional information:
https://drive.google.com/file/d/0B2nv91 ... 4w6rYVFgkQ (Spanglish 2013
I had this MQB RVC KA1 installed in the Golf 7.5.
viewtopic.php?p=581351#p581351
I had this MQB PDC unit installed in the Polo 6R.
viewtopic.php?p=588911#p588911 , ... Uninstalled for testing with the original PQ PDC unit when I installed BSD/RTA - Lane Change Assist -.
More info in this thread and in my wife's Golf thread.
https://www.youtube.com/watch?v=B_Ain-ys6q0
Posted: Thu May 29, 2025 3:20 am
by ciclo
Posted: Fri May 30, 2025 2:32 am
by ciclo
Posted: Sat May 31, 2025 7:04 am
by ciclo
POLO 6R. Discover Media project. RTA testing. 1ST Autoscan.
Two lanes in each direction at the rear.
These 5Q0 rear radars work exactly the same as when I had them installed in the Golf.
At the moment, my 6R doesn't have an audible warning signal when reversing into nearby cross traffic, and of course, it doesn't have automatic braking.
The on-screen signals are
clear and 'very helpful'.
Everything clear and clean.
RTA ON/OFF, video:
https://www.youtube.com/embed/jehC7iSQZ ... autoplay=1
On the other hand, seems that VW uses the same parking place as me to calibrate the MQB RVC KA1 Lowline.
VCDS AutoScan
Thursday,29,May,2025,14:43:21:32438
VCDS Version: 25.3.1.0 (x64) HEX-V2 CB: 0.4671.4
Data version: 20250408 DS365.0
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO License Plate: DISCOVER MEDIA 1ST AUTOSCAN OK!
Mileage: 91290km-56724mi Repair Order:
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 3C 44 55 5F 65
VIN: WVWZZZ6RZDY0CICLO Mileage: 91290km-56724miles
VCID: 6A8D3FD44CF8023A31F-803E
Revision: --------
VCID: 025D77745448FA7A99F-8056
Coding: 01
VCID: 7EA5038420709E9AFD7-802A
Revision: V0000000
VCID: 3829D59C425460AA77B-806C
VCID: 2D07F4C8BD16D50214D-8078
Coding: 0228DD
Coding: 0200A3
Coding: 1000A3
Coding: 18BC32
Coding: 18BC32
Coding: 30A001
VCID: 71BF28B8612EF1E2705-8024
Coding: 00314D
VCID: 4ACD9F542C38E23A11F-801E
Coding: 140E01
VCID: 47CBA6603F2A1F520E1-8012
Revision: B9084001
Coding: 00220F
VCID: 688945DC5274302A27B-803C
Revision: AA001001
VCID: 2E05F3C4B090AE1A2D7-807A
Coding: 020100
VCID: 2A0DFFD48CF8C23AF1F-807E
Coding: 03011102
VCID: 3D27C4886DF64582A4D-8068
Coding: 030111
Coding: 11250
Shop #: WSC 00788
VCID: 2F3BEEC0BE5AA712261-807A
VCID: 77AB16A00F4AAFD2BE1-8022
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5C0 035 680 G HW: 5C0 035 680 G
Component: MU-S-ND-ER H41 0480
Serial number: VWZAZ2W1480534 Dataset Number: V03935270BD 0001
Coding: 02620001FF00000051110101C0880A401F0106D400A001008F
Shop #: WSC 34480 348 34480
ROD: EV_MUStd4CTSAT_VW37.rod
VCID: 25170CE8E566ED42DCD-8070
Data carrier:
Subsystem 1 - Part No SW: 5NA 919 866 ET HW: -----------
Component: ECE AS 24/25 --- 2210
VCID: 372BD6A04FCA6FD27E1-8062
End----------(Elapsed Time: 02:02, VBatt start/end: 13.7V/13.7V)-----------
Please disregard the codings yet, I'm in the testing phase... Thanks!!
https://www.youtube.com/watch?v=bydW0NyYe38
Posted: Tue Jun 03, 2025 1:09 pm
by ciclo
Posted: Tue Jun 03, 2025 8:37 pm
by ciclo
Posted: Fri Jun 06, 2025 5:35 am
by ciclo
Posted: Sat Jun 07, 2025 8:52 am
by ciclo
POLO 6R. Discover Media project. USB-C in the 'glove compartment' for phone charging via J650. USB and AUX Ports.
USB-C.
Video:
https://www.youtube.com/embed/PueQSeLZB ... autoplay=1
Only for charging devices with a USB-C charging port, not for data transmission. Despite the coding/adaptation possibilities it was not possible for me to make J650 MEDIA-IN compatible
'as an AUX socket' with Discover Media and the reason for installing this new cable with USB-C.
For phone charging it is a very good reason to keep the J650 unit in the glove compartment and not throw it away or undo the original installation.
USB1, USB2, AUX.
For data transmission, I have the USB1 HSD in the
'center console' and a possible USB2 HSD in the future, both via USB HUB.
USB1.
For more information see previous posts.
USB2, AUX.
I already have planned where to install the USB2 HSD and a functional AUX socket, but that will be in the hypothetical future.
I expect the DM project will be finished by next week, I still need to receive a grinder I bought to make the hole in the roof to install the new 'OEM' shark fin antenna.
https://www.youtube.com/watch?v=v01q01LbWzI
