Re: ciclo's Polo. R-line 1.2 TSI 90hp 119gr.🤝
POLO 6R. Leather armrest renewal.
After cleaning the car's interior with my new cordless vacuum, etc... Related: :arrow: viewtopic.php?p=608871#p608871
...I noticed that the center armrest had more than fulfilled its purpose and it was time to renew it to give the car's interior a brand-new look.
Renewal of the leather:
Easy.
How beautiful!🤸‍♂️
With ODIS, in the Address 'LA' disable Byte6 Bit5 to avoid CP, SFD, and other STP encryptions... https://www.youtube.com/watch?v=1veWbLpGa78
Prelude
https://www.youtube.com/clip/UgkxwmVofw ... PFpiGBRYTS
Also: WHT003860B, WHT003861B, WHT003862C, WHT003863C, which replace the original/factory ones without index (final letter)... it is difficult to find them at a price for all audiences...🤭
🔎(shaped like a cricket bat instead of a golf club :lol:)
Light comment:
Some are for the original ABS unit and others for ABS units with more functions... :)
For example, the A and B 'in the image' are used on the MQB A0 platform in models with PLA units (7X5) where the wheel rotation direction is coded.
The interesting thing is that physically they all fit into the PQ25/PQ26... but not electronically...
A,B:
1 Fault Found:
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
1 Fault Found:
337904 - Databus
U1123 00 [00001001] - Received Error Message
[mBremse_10::B10_QB_Wegimp_HR - Ersatz_Init_oder_Fehlerwert]
1 Fault Found:
13705987 - Databus
U1123 00 [10001001] - Received Error Message
[Fehlerwert im Signal BR3_Rad_kmh_HR]
"In this case" ETKA doesn't list the PR codes for each "index" but it clearly warns you that they can only be replaced with the original part numbers 'installed on the vehicle'. Really?
In the first quarter of the 21st century we are still in a deep medieval darkness... Damn, it is certainly a profound misfortune to be a contemporary of such despicable beings. I wonder why the hell I wasn't born in 2525 and not now.😁
https://www.youtube.com/clip/UgkxO9egqZ ... sguih3FTCd
POLO 6R. PDC sensors renewal. Preparation.
For over a year, I've been enjoying the 5Q0 radars for the lane change system. In my case, they work like a charm with the Golf VII's parameters/DS.
viewtopic.php?p=605611#p605611
In the near future, I'll be installing the 2Q0 radars (5Q0 evolution), which, as you know, I had ready once I finished installing the 5Q0 radars.
viewtopic.php?p=606266#p606266
viewtopic.php?p=605910#p605910
This involves removing the rear bumper, and it's at this point that I'll renew the PDC sensors.
Initially, it seems that there are infinite compatibilities for the part numbers used by VW for PDC sensors, but based on my experience, I don't think this is the case. PDC sensors do not function the same depending on the PDC unit installed and Dataset used.
Since I don't know the part numbers for the factory-installed rear PDC sensors on my 6R (May 2012), I'm going to replace both the rear and front PDC sensors with the correct and updated part numbers that are fully compatible with the installed PDC unit (plus dataset).
After a very thorough study, the correct part number is 1S0919275C.
Depending on the DS used, 5Q0919275B is also possible, which is mostly used on the MQB platform, and to a lesser extent on the PQ platforms. I will also test them, but that will be later because the sensor supports have to be changed.
Preparation. 1S0919275C:
Sunlight, no tricks. 8)
https://www.youtube.com/clip/UgkxR5NL6T ... T1gCY6uy76
POLO 6R. Protective covers/caps for the door hinge.
I liked them especially for the aesthetic result when I installed them on our Golf 7.5, so I reordered them for our 6R from Ali. Affordable for everyone, 0,...
The functionality... well, it depends more on the weather conditions where the vehicle is located. In many places, they're not necessary.
If you were born in a 'privileged place' and get a new car every 6 months, 1, 2, or 3 years, don't waste your time with this; this is only for enthusiasts...😁
I did this because I was mainly doing some testing for my 'NEW PROJECT', which is actually what I wanted to post.😊
beep beep beep beep
beep ............. beep
beep beep beep beep
https://www.youtube.com/watch?v=xc3FU3cI1QI
I've already completed all the tests (vehicle, test bench), and it seems like it will work perfectly... (no additional diagnostic faults 🤭).
More info and details in the following posts. https://www.youtube.com/watch?v=MW8RKweDoaE&t=1s
POLO 6R. New project. 12K PDC. OPS 360º.
First steps:
-A new 12K PLA PDC unit for PQ platforms is required.
-It must have 1K8919475(X) firmware, or also a 5Q0 MQB converted to a 1K8 PQ, as they share the same hardware (H11 or H12 are suitable).
-If purchased secondhand, as in my case, 5Q0 units are usually cheaper, half the price (the final index, 'K', etc., doesn't matter).
-For Discover Media, the FW indicated is 1K8 ...D, for RNS510, the firmware indicated is 1K8 ...E, according to the PR codes in ETKA.
This is relative since there may be clarifications (it depends on the equipment already installed -Instrument Cluster FW-).
How to convert a 5Q0 MQB to a 1K8 PQ.
-For ODIS:
This trick has already been written in some places, but I show it to you in the following video so you can do it yourself if you wish.
Video: :arrow: :arrow: :arrow: https://www.youtube.com/embed/0GE8D1rab ... autoplay=1
Highlight.
The flashing files and dataset are available online (e.g., mibsolution). Tip: Download them as soon as possible after reading this information.
Or, files already converted for flashing: :arrow: https://www.drive2.ru/b/642176639223998618/
-For VCP:
It just does it without you having to do any tricks.
In any case...
To be continued...
...once we have the correct 12K PDC unit for PQ, with the appropriate Dataset (for a vehicle without EPB), the Coding, and the Adaptations that fit my 6R, I go to the car to test it...
I get the following (images shown in a previous post):
And most interestingly, the diagnosis with the logic faults due to the lack of installation of the 4 side PDC sensors and the PLA button, ...and the same priority 6 fault that we had with the 8K 1K8 PDC unit, which we also assume does not affect (NP/NA) for 12K.
At the moment, no other faults related to the Instrument Cluster, ABS/ESP unit, or Steering Assist unit.
BSD/RTA continue to work just like before (tested). 😎
Installing the four side PDC sensors has an obvious solution; it's the fun part of this new project, which I'll be working on slowly over the next few weeks or months...🤷‍♂️
It's possible to install the PLA button, but on my 6R, this doesn't make sense at the moment, so I'm opting for a simple solution to avoid the diagnostic fault...
Video: :arrow: :arrow: :arrow: https://www.youtube.com/embed/QcojqZQ-X ... autoplay=1
Well, at the moment, only tested on the test bench, however, this 1N4007 diode has some very good characteristics, and everything should work correctly once installed. You can also install the PLA button and hide it somewhere behind the trims in case in the future you upgrade your ABS-ESP pump, and Steering unit.
Related: (THREADS you can participate in)
- ESP8.2i :arrow: viewtopic.php?p=608802#p608802
- G85 (J527?) :arrow: viewtopic.php?p=608897#p608897
POLO 6R. 12K PDC Project. OPS 360º. Wiring Diagram.
https://www.youtube.com/watch?v=cU0Wz1ez3J0&t=1s
POLO 6R. 12K PDC Project. OPS 360º. Side PDC sensors.
Initially, I'm going to keep the 1S0919275C PDC sensors for the eight front and rear PDC sensors, but I might swap them for the 5Q0919275B PDC sensors (I like to test 🤷‍♂️).
The four NEW side PDC sensors will be as follows:
Shown in the image above are the sealed T2 couplings.
I couldn't find rear brackets/supports/holders for rear PDC sensors at a reasonable price, but by using my 3D imagination 😁, I bought four front ones and notched two of them to make them compatible with the rear PDC sensors... swap them from one side to the other, that is, the front left will serve as the rear right.👌
If necessary, I will implement the fixing of the brackets this time with less domestic tools than when I installed PLA 3.0 on our Golf 7.5.
... to do it anywhere.🤭
🤔 ...maybe I can use the hot glue gun for automotive, I'll decide as I go.
Since the installation of the side PDC sensors and brackets is practically the same as the one I did on the Golf 7.5, and it might be helpful to save costs, I recommend taking a look at the links I posted here: :arrow: viewtopic.php?p=575987#p575987
I've looked at a lot of VW models and there's no predefined pattern, so the Golf will serve as a reference... the area/arch where the side PDC sensors are installed is wider on the 6R... 🤸‍♂️ "happy as a clam".😊
https://www.youtube.com/watch?v=09R4LQb71wg
5Q0 PDC sensors ready 2 paint.
The cleaning solvent and primer are waiting in the garage storage room from when I painted the 1S0 PDC sensors.
POLO 6R. 12K PDC Project. OPS 360º. Wiring.
Plug & Play.🧙‍♂️
Old picture from when I installed the front 4 PDC sensors (4K to 8K).
I installed/ran the wiring on/by the correct/right side 😁, easy way for LHD.
Waiting for slightly more favorable weather conditions to paint the 5Q0 PDC sensors...
...with a light breeze of 5 to 10 km/h would be perfect. :lol:
https://www.youtube.com/watch?v=4VXErA63_eg&t=1s 🥱👌😊
POLO 6R. 12K PDC Project. OPS 360º. 5Q0 PDC sensors painted.
It's not perfect, but they look reasonably good.🤷‍♂️
With my exceptional imagination 🦧, I measured the microns each layer needs to be... according to VW's PDFs for painting these parts, ...in other words, I measured each layer just like the best painters on the planet do when they do this work (not factory). I guess I'll have to measure the total layer with some device once they are dry... 😁
I'll let them dry at room temperature for a full day before removing the tape and installing the rubber rings. https://www.youtube.com/watch?v=1_ShY-OM27g&t=1s
:lol:
More images before installing the 4 side PDC sensors.
The weather conditions aren't conducive right now. Working with the lighting of the sun is fantastic, but if it rains, it's not so much... The weather is expected to be more favorable by mid- or late-week, and since I'm not in a hurry with this project, I have more time to think about this installation/project. 😊
Initially, I'd like to be able to install the front side PDC sensors without removing the front bumper, as I'll likely need to do so later to install all the 5Q0 PDC sensors. I'll remove the wheels, wheel housing liners, and the upper front grille from the front bumper. I think this way I'll be able to install the front side PDC sensors and the corresponding wiring. Maybe I'm being too optimistic, or maybe with enough skill, I'll be able to do it.
As for the rear bumper, I have to remove it anyway to replace the 5Q0 radars with the 2Q0 ones for the LCA, so on this side I just have to consider the height where I will install the rear side PDC sensors. It will be between 50 and 55 cm (52.5 cm) from the ground, average height of the PDC sensors already installed in our Golf 7.5 (12K) and 6R (8K).
First, before removing the bumpers, I will partially remove the wheel housing liners to ensure and mark the exact locations for installing the side PDC sensors...and not drill the holes in some catastrophic place where there will be no room for the PDC mounts/holders/supports. 😄
https://www.youtube.com/watch?v=7sxBa1X6FfU&t=1s
While it's raining ... which makes it impossible for me to do anything related to my current project, I'm running other pseudo-related tests, just to expand my knowledge.
WHT003862 vs WHT003862C. Diode TEST. Video.
:arrow: :arrow: :arrow: https://www.youtube.com/embed/LabJhzGuR ... autoplay=1
At this point, I couldn't tell you with absolute certainty (due to other evidence) 'what's what' regarding this type of active ABS speed sensors (HE vs AMR?).
I asked the AI ​​to try to organize my knowledge but the AI ​​​​has a real mental block about it ...depending on the language you ask it in. 😄
It's not the same sensor, not even in your sweetest dreams, blah, blah, blah....
...while I wait for the auspicious day to do the first installation of the 12K PDC project, I've been talking to Santa Claus/Father Christmas and Krampus and I've told them to bring me the gifts I'm entitled to this year 2025, and since I have been a good person and also a sinner 'to/for balance', this is what I have received:
So, the Front lights on my 6R:
- CBI Bixenon headlights + LED DRLs (factory - Perseids style). Automatic + CH/LH + HBA.
- LED Static Cornering Lights. Automatic.
- LED Front Foglights. Off road, without fog sensor 😁, non automatic.
- LED F-TRON lights (by ciclo). Automatic.🧙‍♂️
- LED 'Luxury' Entry lights. Automatic. 2 wonderful pearls 💎💎 (no are puddle or dog droppings lights).
- Bulb Turn signals (factory) + LEDs Dynamic turn signals on the mirrors. Tic-tac operation.😄
ECE approved.
The white light will guide your way.🧙‍♂️
Ready 2 enjoy a 'White' Xmas.
Therefore, to install the auspicious day:
- 12K PDC sensors.
- 2Q0 radars.
- LED lights.
- Etc...
Friendly note:
-You'll never make an electric vehicle that pollutes less than my 6R over its entire life'cycle'. Time and other factors are on my side, YES or YES. There are even still places where electricity is generated with coal 🤭 (caveman days yet!).
BTW, my 6R is close to achieving ABSOLUTE profitability (100,000 km) compared to a 'squid'-TDI vehicle. 🦑💨
🤦‍♂️...I forgot that before Xmas comes "All Hallows' Eve".
Happy Halloween! 🎃💀
Regarding/related to the installation:
:arrow: https://www.youtube.com/watch?v=FqJu58tMBDc
:arrow: viewtopic.php?p=592365#p592365
It worked excellently there, and it should do the same here.
More info about 2QD radars in previous pages/posts/links. viewtopic.php?p=606266#p606266 , viewtopic.php?p=605910#p605910
https://www.youtube.com/watch?v=pSE6hUrkVKE
Locked
