Benzinkopf's 2012 VW POLO 6R MK5 1.2TSI 105HP DSG
benzinkopf
- Drives: 1.2TSI 105HP DSG7
Re: Benzinkopf's 2012 VW POLO 6R MK5 1.2TSI 105HP DSG
thanks guys. Maybe i now got another reason to go for HBA. so the Climatronic get a new friend with RLHS. [emoji2960]
benzinkopf
Help needed!
hello everybody, need some helps here with one error and coding/adaptation channel for 08-auto hvac
a) recently i scanned the car and found out there's error in my 09-Bcm, which is
00975 - Heated Rear Window (Z1)
011 - Open Circuit - Intermittent
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 8
Reset counter: 50
Mileage: 284803 km
Time Indication: 0
Date: 2024.14.01
Time: 00:02:50
i've check the wiring connection at the rear hatch, but everything looks fine. I tested switching on the heater and it seems to function correctly. any idea where i should start looking at?
b) i retrofitted climatronic to my 6R using parts from locally produced vento.turned out the vento is not using G263 Evaporator Temperature Sensor.Therefore, my externally regulated A/C compressor with N280 never stop compressing till my LowPressure pipe and evaporator freezed up and block the air flow. So i checked again the measuring block and its clear there's no reading from G263 and it never report any fault. So i installed the G263 but still there's no reading. Luckily, i changed adaptation channel 9 from 0 to 1, and it is now getting the reading from G263 and shut-off the compressor when temperature drops around -2/-3 degree celcius. so now, i would like to know whether my adaptation channels setting are correct for my car and it would be good if someone with climatronic can share the value for adaptation channel 0 to 9. As far as i understand, there are channels to set either the car equipt with start/stop, hard-wired radiator fan or not, externally regulated compressor or not etc. but since there's no label in vcds, i've no idea.
c) anyone knows the security access code for 08-Auto hvac?
Thursday,26,December,2019,23:15:10:15298
VCDS Version: 19.6.2.0 (x64)
Data version: 20190930 DS308.0
www.Ross-Tech.com
Workshop Code: 123 12345 012345
VIN: WVWZZZ6RZCUBENZIN License Plate:
Mileage: 284810km-176972mi Repair Order: 191226
Chassis Type: 6R-VW25 (01 - BENZIN)
Scan: 01 02 03 04 08 09 10 15 17 19 25 2E 37 3C 44 55 56 65 6C 77
VIN: WVWZZZ6RZCUBENZIN Mileage: 284810km-176972miles
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 HF HW: 03F 907 309 J
Component: SIMOS10.22H03 2698
Revision: --H03--- Serial number:
Coding: 002500F6202400080000
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_ECM12TFS02103F906070HF 004004
ROD: EV_ECM12TFS02103F906070FP.rod
VCID: 6DDBC694BCAA3C277C-8038
Readiness: 0010 0001
Part No SW: 0AM 300 060 G HW: 0AM 927 769 D
Component: GSG DSG AG7 431 5270
Revision: 00043014 Serial number: CU501411296648
Coding: 0000020
Shop #: WSC 25802 001 1048576
VCID: 2E590198BA2C873F05-50C8
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 230228E3416E00B4C42C14E382D800801700
VCID: 0717943CB216F677E6-8052
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 41834A24D8B20847E8-8014
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 259161638
Coding: 3CB02BFF48A10C0013FF0F917EEB9FD9DAC0672F602D30D0200400130800
VCID: 2A510D8845C4EB1FD9-807E
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 180812 05 54 0403
Coding: 07302D
Subsystem 2 - Part No SW: 6R0 959 802 BH HW: 6R0 959 802 BH Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 8612
Serial number: KU0KU028041441182089
Coding: 1400A3
Subsystem 3 - Part No SW: 6R0 959 801 BC HW: 6R0 959 801 BC Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 8612
Serial number: KU0KU008051441286886
Coding: 0400A3
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 6 - Part No SW: 5K0 959 542 B HW: 5K0 959 542 B
Component: E221__MFL-TAS H30 0032
Serial number: 0122863
Coding: 830000
Subsystem 7 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU030061100015373
Coding: 08BC32
Subsystem 8 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU001071100015810
Coding: 08BC32
1 Fault Found:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 50
Mileage: 284803 km
Time Indication: 0
Date: 2024.14.01
Time: 00:02:50
Address 10: Park/Steer Assist (J446) Labels:* None
Part No SW: 18D 919 475 HW: 56D 919 475
Component: PARKHILFE 8K H02 0005
Revision: -------- Serial number: 20221617004119
Coding: 308001
ASAM Dataset: EV_EPHVA18VW3218CS0 001001
ROD: EV_VW75XParkAssis8K_VW31.rod
VCID: 70E5DFE0AB98D1CF57-8024
Component: VW10Airbag027 H09 0020
Revision: -------- Serial number: 003GX00RY8XP
Coding: 003237
Shop #: WSC 31414 790 31414
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A916D08ED84CB1F39-801E
Serial number: 3575HRB405H0IRE2COP8
Serial number: 3585HRB405J0ISD6C8T3
Serial number: 3515RRB405J0LMIQ6PBL
Serial number: 3525RRB405H0LMIQCGRX
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H05 0805
Coding: 141C01
VCID: 4797543CFE96367726-8012
1 Fault Found:
12658432 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 36
Reset counter: 50
Mileage: 284803 km
Date: 2019.12.26
Time: 00:02:10
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 702305
VCID: 68D5B7809B48190F0F-803C
Component: IMMO H05 0805
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6AD1CD888D442B1F19-803E
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7660415697
Coding: 010000
VCID: 2953F28440C2E007D0-807C
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 1T0 035 680 D
Component: RNS-MID H70 5274
Revision: AB001001 Serial number: VWZ6Z7M2235046
Coding: 04000402040000A00001
VCID: 377724FC867646F756-8062
Subsystem 1 - Part No: 7L6 919 859 J
Component: SIMA V4 7769
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 7E0 907 566 C HW: 4H0 907 566 F
Component: SWA Master H06 0030
Serial number: 0372892839
Coding: 030312
ASAM Dataset: EV_LaneChangAssis 001028
ROD: EV_LaneChangAssis_VN75.rod
VCID: 30651FE06B1891CF17-8064
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 7E0 907 568 C HW: 4H0 907 568 F
Component: SWA Slave H08 0030
Serial number: 0432634593
Coding: 030312
3 Faults Found:
267776 - Data Set Implausible
B2012 00 [009] - -
Fault Priority: 3
Fault Frequency: 4
Reset counter: 10
Mileage: 284803 km
Date: 2019.12.26
Time: 00:06:59
729349 - Control Module for Lane Change Assistance
C1114 54 [009] - Missing Calibration / Basic Setting
Fault Priority: 3
Fault Frequency: 1
Reset counter: 8
Mileage: 284803 km
Date: 2019.12.26
Time: 00:01:44
729605 - Control Module 2 for Lane Change Assistance
C1115 54 [009] - Missing Calibration / Basic Setting
Fault Priority: 3
Fault Frequency: 1
Reset counter: 8
Mileage: 284803 km
Date: 2019.12.26
Time: 00:01:44
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 31414
VCID: 2F671C9CEA268E370E-807A
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0316000001000000
VCID: 77F7E4FCCEF686F796-8022
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 30000000023712
ROD: EV_RDKBERU30_005.rod
VCID: 377724FC8E7646F756-8062
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3AE 907 441 HW: 3AE 907 441
Component: J772__Rearview 0020
Revision: 00H13000 Serial number: 525PA8-J41D320
Coding: 0020006
VCID: 72E1D5E86D94E3DFA1-8026
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007663752927
Coding: 0A10000000010110
Shop #: WSC 43038 123 12345
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3A713DC8BD645B9FA9-806E
End-------------------------(Elapsed Time: 04:30)--------------------------
Fault Priority: 3
Fault Frequency: 8
Reset counter: 50
Mileage: 284803 km
Time Indication: 0
Date: 2024.14.01
Time: 00:02:50
Adaptation channels, made in the stone age.
Thursday,24,December,2015, Climatronic H11 0711
SA... 20103?
BCM
090C adapt
SW:6R0-907-044-H HW:6R0-907-044-H --- Auto HVAC
Component:Climatronic H11 0711, Coding:
Thursday,24,December,2015,08:32:17:05031
VCDS Version: Release 15.7.1 (x64) Data version: 20150904
VCID: 3878B0CF8B402CFEA5-806C
Channel,,Field 1,Field 2,Field 3,Field 4,
01,0,N/A,N/A,N/A,N/A,
02,0,N/A,N/A,N/A,N/A,
03,1,N/A,N/A,N/A,N/A,
04,,ERROR:,Channel 04,Not,Available,
05,0,N/A,N/A,N/A,N/A,
06,0,N/A,N/A,N/A,N/A,
07,0,N/A,N/A,N/A,N/A,
08,,ERROR:,Channel 08,Not,Available,
09,,ERROR:,Channel 09,Not,Available,
10,,ERROR:,Channel 10,Not,Available,
etc...
255,,ERROR:,Channel 10,Not,Available,
BCM
SW:7E0-937-090-E HW:7E0-937-090-E --- Cent. Elect.
Component:BCM PQ25 Max4 H84 0772, Coding:3CB02FBF48E12400B3380F317CEB9FD05AC0670F600D39D0220400030800
Thursday,17,October,2019,15:49:58:32438
VCDS Version: Release 19.6.2 (x64) Data version: 20190930 DS308.0
VCID: 2D07F4C8BD16D50F521-8078
02,,ERROR:,Channel 02,Not,Available,
04,1,N/A,N/A,N/A,N/A,
08,1,N/A,N/A,N/A,N/A,
09,0,N/A,N/A,N/A,N/A,
10,0,N/A,N/A,N/A,N/A,
benzinkopf
Thanks ciclo. now i can see that only channel 3 is 1 in your climatronic while there’s no adaptation channel 9.
So far, i follow the same. It seems to work. just that after long drive (30-45mins) still get the freezing coil. will monitor further. perhaps my expansion valve or regulator valve n280 is not doing well.
btw. as far as I found
adaptation channel
1: car with start/stop function
2: moisture sensor installed
3: radiator fan hardwired
4: N/A
5: unknown. something to do with auto mode system.
6: unknown.
7: enabled Air Recirculation always On even in Auto Mode.
8: unknown. something to do with auto mode system (**iichel’s value is 10)
9: enabled evaporator temperature sensor
and 20103 is not accepted for SA.
adaptation channel
4: N/A
6: unknown.
Good luck with your inquiries.
I think I remembered that I changed some value in the adaptation channels shown previously, but I don't remember if a SA code was necessary, unfortunately I didn't do a new reading of the channels from this unit since those dates.
I will do it when possible, which will be complicated during these dates. (party time
benzinkopf
totally understood ciclo. just not the right time. but its ok. when i searched about climatronics. i do find it is less discussed in details. anyway, you re right. adaptation channel still can be changed without SA. i’m just asking since the labelled in Odis showed channel 4 is for externally regulated compressor while the channel is not available. Even inside odis, there’s nothing can be done with channel 4.
benzinkopf
new year gift[emoji3061][emoji2957].
Tuesday,31,December,2019ciclo wrote: Sat Dec 28, 2019 7:56 am Good luck with your inquiries.
I will do it when possible, which will be complicated during these dates. (party time)
Tuesday,31,December,2019,11:54:01:32438
VCID: 3829D59C425460A7317-806C
02,1,N/A,N/A,N/A,N/A,
11,,ERROR:,Channel 11,Not,Available,
etc...
benzinkopf
thank you my friend. Really appreciate the adpmap. So its clear that its adapted to RLHS with channel 2 and the channel 3 is clear for the hardwired fan system. So I followed the channel 3 with value 1. Later on, once i upgrade to RLHS and HBA, i know i need to enable channel 2. [emoji1362]
Everything seems to be working great so far with my climatronic. Just that based on measuring value, i find out that the pressure regulation by N280 is not that great, at high speed, it’s still pumping the refrigerant to a level that its easy to freeze. I’m waiting for the part now (N280 valve) to replace. Hopefully all good. If not, its gonna be a new compressor[emoji23]
benzinkopf
Hello everybody!
I need another help again. lol. Hopefully our experts here can help me with 2 issues i have now. (especially ciclo, iichel, cnk, madwarlock, gowind, and all others)
1) AFS Module flashing & parameterization using ODIS E.
today i did stupid things. doing something i dont ve any knowledge. A friend of mine asked for help to flash one door module in his golf using his odis E 9.0.4. I’ve no idea really. so i will need to try and test and learn. So i decided why not and try flashing my AFS module using odis e flash function. I got the file from Erwin (thanks to Gowind) and i did the flashing and all seems good. But little i know that i need to write the dataset and parameterization for the module before i can code it normally using vcds. now im stuck and dont know what and how. My AFS is giving error and flashing the warning light. lol. [emoji2361]. is there any way i can correct this or i really need to look for a new module?
2) RLHS upgrade
So today i received my new RLHS sensor, as this from China, i always immediately test plug in the new sensor to check its condition.
here’s my new VCDS scan
so the installation pretty easy as i just want to check. after install, i change the coding of the RLHS to 0728DD and enabled channel 2 in adaptation climatronic. everything seems to be working except i got error in BCM saying it’s not coded correctly. is there any other byte/bit i need to enable in bcm?
2) RLHS upgrade
Wednesday,15,January,2020,17:40:54:15298
www.Ross-Tech.com
VIN: WVWZZZ6RZCUBENZIN License Plate: BENZIN
Mileage: 286280km-177886mi Repair Order: 200115
VIN: WVWZZZ6RZCUBENZIN Mileage: 286280km-177886miles
Readiness: 0000 0000
Coding: 0000020
Revision: --------
Revision: V0000000
Coding: 3CB02BFF48A10C0013380F917EEB9FD9DAC0672F602D30D0200400130800
Component: RLHS 231117 0 47 0106
Coding: 0728DD
Coding: 1400A3
Coding: 0400A3
Coding: 830000
Coding: 08BC32
Coding: 08BC32
1 Fault Found:
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 286284 km
Time Indication: 0
Date: 2024.14.21
Time: 17:30:56
Coding: 308001
Coding: 003237
Coding: 141C01
1 Fault Found:
U1111 00 [008] - -
Fault Priority: 6
Fault Frequency: 20
Reset counter: 114
Mileage: 286248 km
Date: 2020.01.15
Time: 13:23:36
Revision: B9081001
Coding: 002305
Coding: 010000
Coding: 030312
Coding: 030312
3 Faults Found:
B2012 00 [009] - -
Fault Priority: 3
Fault Frequency: 5
Reset counter: 74
Mileage: 286248 km
Date: 2020.01.15
Time: 14:34:07
Fault Priority: 3
Fault Frequency: 1
Reset counter: 73
Mileage: 286248 km
Date: 2020.01.15
Time: 13:21:36
Fault Priority: 3
Fault Frequency: 1
Reset counter: 73
Mileage: 286248 km
Date: 2020.01.15
Time: 13:21:36
Coding: 11230
Shop #: WSC 31414
Coding: 0000000000000000
3 Faults Found:
10490624 - No End-of-Line Programming
B2013 00 [137] - -
Fault Priority: 1
Fault Frequency: 1
Reset counter: 73
Mileage: 286248 km
Date: 2020.01.15
Time: 13:21:37
13636352 - Control module not coded
U1013 00 [137] - -
Fault Priority: 1
Fault Frequency: 1
Reset counter: 73
Mileage: 286248 km
Date: 2020.01.15
Time: 13:21:37
5275220 - Headlight
C107E 54 [137] - Missing Calibration / Basic Setting
Fault Priority: 1
Fault Frequency: 1
Reset counter: 73
Mileage: 286248 km
Date: 2020.01.15
Time: 13:21:37
Coding: 0020006
benzinkopf
**Update
So i just found out another error recorded in my Climatronic (presumably due to channel 2 activation, climatronic now waiting for Humidity input from BCM???)
Revision: V0000000
1 Fault Found:
00457 - Central Electronics Control Module / BCM (J519)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 74
Mileage: 286284 km
Time Indication: 0
Date: 2024.14.21
Time: 17:41:35
Is this means the humidity sensor is still not “coded” in the bcm or it’s just a bad sensor?[emoji848]
byte8bit5? hurm
Revision: V0000000
1 Fault Found:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 74
Mileage: 286284 km
Time Indication: 0
Date: 2024.14.21
Time: 17:41:35
byte8bit5? hurm
climatronic error 00457 - Control Module for Network (J519) is solved by setting adaptation channel 1 of the HVAC to value 1
climatronic error 00706 - Relay for Coolant Fan; Stage 2 (J513) is solved by setting adaptation channel 2 of the HVAC to value 1
climatronic error 00705 - Relay for Coolant Fan; Stage 1 (J279) is solved by setting adaptation channel 2 of the HVAC to value 1
benzinkopf
ok. i re-googled ciclo’s thread (not sure for how many times. lol). i found out his post for the RLHS need to activate byte8bit5. So i did that. Error gone so far on both bcm n climatronic. [emoji1360]
btw thanks iichel! i didn’t know that channel 2 is for the fan control! i really thot its the humidity sensor. so i havent enable channel 1 inside climatronic yet. will see and update soon.
benzinkopf
temporary bracket for testing. [emoji1787]
