Re: iichels Polo 6R 1.2TDI Bluemotion --> OEM++ R-Line conversion
dominis23 wrote: Thu Feb 11, 2021 9:38 am Hi, I have a question if only the amplifier with the numbers 5C6035456C fits or you can put on another amplifier
There are other amplifiers for the Dynaudio system that will also work, yes. I took the 10-channel version with 4 bass, 4 treble and 2 subwoofer speakers.
There is also a 8-channel Dynaudio system with no subwoofer or a Helix soundsystem.
In case of a Dynaudio system, just make sure it will fit the Golf mk6 generation cars and not the newer mk7 based cars. The Helix plug-and-play system will fit all generation cars.
dominis23
Drives: POLO 6R
Post by dominis23 »
iichel wrote: Thu Feb 11, 2021 11:02 am
Did you take the wiring diagram from the Scirocco or Golf VI? In Discover Media where to connect to the amplifier ??
I took it from scirocco 1k8
1K8 PDC module retrofitted for automatic PDC activation and perhaps later also RTA
Thursday,25,February,2021,12:18:07:11868
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 20.12.0.0 (x64)  HEX-V2 CB: 0.4529.4
Data version: 20201124 DS322.0
www.Ross-Tech.com
Dealer/Shop Name: iichel retrofitting
Workshop Code: 470 31889 031889
VIN: WVWZZZ6RZBYiichel   License Plate:
Mileage:    Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 05 08 09 10 15 17 19 20 25 2B 2E 37 3C 44 47 55 56
          57 61 65 69 6C 77
VIN: WVWZZZ6RZBYiichel  Mileage
05-Acc/Start Auth. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
47-Sound System -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
Address 01: Engine (J000-CFWA)       Labels:. 03P-906-021-CFW.clb
   Part No SW: 03P 906 021 B    HW: 03P 907 425
   Component: R3 1.2l TDI   H06 9980
   Revision: 12005001    Serial number:
   Coding: 00114036033401080000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_ECM12TDI03103P906021B 001043
   ROD: EV_ECM12TDI03103P906021AA.rod
   VCID: 270B06DDAF6FF1F3129-8072
Readiness: 0 0 0 0 X
   Part No SW: 6R0 907 379 AS    HW: 6R0 907 379 AS
   Component: ESP9.0i front H02 0002
   Serial number: --------------
   Coding: 21DD2885432500C5841A146EC25500521505
   Shop #: WSC 31889 470 31889
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
   VCID: 0F7B4E7D27DF89B3FA9-805A
Address 05: Acc/Start Auth. (J518)       Labels:| 5K0-959-434.clb
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0346244897
   Coding: 030C0C
   ASAM Dataset: EV_KESSYPQ35G A02717
   ROD: EV_KESSY_PQ35GP.rod
   VCID: 372BD69D7FCF6173829-8062
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H12 0812
   Revision: V0000000
   VCID: 3829D5A172516E0B8B3-806C
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 173171327
   Coding: 3EB02FBF68EB2400B33807E0FFEB9FF0F08060EF608D78D071E400030800
   Shop #: WSC 00046 000 00000
   VCID: 2B03FAEDB307D593F61-807E
   Component: RLHS 220816 0  42  0106
   Coding: 0214DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8611
   Serial number: KU0KU011111300010103
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8611
   Serial number: KU0KU007111300016463
   Coding: 1000AB
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU027011200011418
   Coding: 58BC32
   Subsystem 9 - Part No SW: 6R0 959 812 B    HW: 6R0 959 812 B
   Component: J389__TSG_HR  002 0803
   Serial number: KU0-KU004.06.0913330
   Coding: 08BC32
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39391528804191
   Coding: 0031191141
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: EV_EPHVA18VW364GP00_VW32.rod
1 Fault Found:
12718592 - Databus
          U1121 00 [009] - Missing Message
          [Steuerger‰t f¸r Lenks‰ulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 206
                    Mileage: km
                    Date: 2021.02.25
                    Time: 12:08:13
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX0142TCE
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   VCID: 4ACD9F691C3DEC9BED7-801E
   Serial number: 3575HRB40650BI7U48C8
   Serial number: 3585HRB405J09RECEOUJ
   Serial number: 3515RRB405T0BTBEF9G7
   Serial number: 3525RRB405R0BTBEKPFQ
   Part No SW: 6R0 920 870 A    HW: 6R0 920 870 A
   Component: KOMBI         H04 0709
   Coding: 140F01
   VCID: 3333E28D6BB78D53BE1-8066
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 042204
   VCID: 688945E162713E8BDB3-803C
   Revision: AA001001
   Coding: 0404000000000000010000
   VCID: 2E05F3F98095A0BBD1F-807A
   Component: IMMO          H04 0709
   Coding: 000007
   VCID: 6A8D3FE97CFD0C9BCD7-803E
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
   Component: ELV-PQ35      H20 0240
   Revision: 00000000    Serial number: 11000256123005
   Coding: 4100000000000000
   ASAM Dataset: EV_ELVMarquMPVW36X A01001
   ROD: N/A
   VCID: 2F3BEEFD879FA9B3DA9-807A
No ASAM data for: "EV_ELVMarquMPVW36X" (VW25)
   Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
   Component: SG EXT.PLAYER H19 0770
   Revision: A1001003    Serial number: 7666620365
   Coding: 010100
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 1T0 035 686 E    HW: 1T0 035 686 H
   Component: RNS-MID       H26 6276
   Revision: AB001001    Serial number: VWZ6Z7P1950254
   Coding: 00070002010000A10001
   VCID: 3635DB997845987B99F-8062
   Subsystem 1 - Part No: 1T0 051 859 AS
   Component: EU West V17  8557
Address 3C: Lane Change        Labels: Redir Fail!
   Part No SW: 7E0 907 566 B    HW: 4L0 907 566 A
   Component: J0769 SWA MasterH13 0120
   Revision: 00H13000    Serial number: 6PZ 009 014-07
   Coding: 0010161
   Shop #: WSC 02756 790 00000
   VCID: 2F3BEEFD8B1FA9B3DA9-807A
   Subsystem 1 - Part No: 7E0 907 568 B
   Component: J0770 SWA Slave H09 0110
   Subsystem 2 - Serial number: 6PZ 009 014-27
   Subsystem 3 - Serial number: 5F31.03.1100H090003CH21982ˇ
   Subsystem 4 - Serial number: H21982ˇ
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6R1 909 144 AD    HW: 6R1 909 144 E
   Component: EPS_TRW_ALow  312 3124
   Serial number: CF3F0205
   Coding: 000300
   ASAM Dataset: EV_SteerAssisUDSTRW 014026
   ROD: EV_SteerAssisUDSTRW_014.rod
   VCID: 79AF10A5095BB70334D-802C
Address 47: Sound System (R12)       Labels: 5K0-035-456.clb
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H08 6831
   Revision: --------    Serial number: EAA098C0000052
   ASAM Dataset: EV_AudioVerst10KanalSTT4 001001
   ROD: N/A
   VCID: 280905E1A271FE8B1B3-807C
No ASAM data for: "EV_AudioVerst10KanalSTT4" (VW25)
   Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
   Component: AFS-ECU       005 0050
   Revision: --------    Serial number: --------------
   Coding: 0D4A000001000000
   ROD: EV_HeadlRegulVWLWRCC.rod
   VCID: 3A2DCFA94CDD7C1B7D7-806E
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
Address 57: TV Tuner        Labels: None
   Part No SW: 3C0 919 148 B    HW: 3C0 919 148
   Component: R78 DTV-JP          0250
   Revision: R0H14000    Serial number: 80100800042102
   Coding: 0000816
   Shop #: WSC 01324 020 00200
   VCID: 280905E1AEF1FE8B1B3-807C
   Subsystem 1 - Part No: 4F0 919 805
   Component: R204 TVKLeser       0010
   Part No SW: 7E0 907 534     HW: 7E0 937 090 C
   Component: Batt.regelung H82 0752
   Coding: 030F1A5A
   Shop #: WSC 31889 123 05683
   Subsystem 1 - Part No SW: 6C0 915 181     HW: 6C0 915 181
   Component: J367-BDM  H08 0223
   Serial number: 61083A44504351928092
   Serial number: 40000000058319
   ROD: EV_RDKBERU30_005.rod
4 Faults Found:
8397058 - Front Left TPMS Sensor
          C1050 31 [009] - No Signal
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 152
                    Mileage: km
                    Date: 2020.12.17
                    Time: 13:29:33
                    Vehicle speed: 54 km/h
                    Outside temperature: 9.0 ∞C
                    Reception level antenna 1: 580 mV
                    Offset level antenna 1: 270 mV
8397314 - Front Right TPMS Sensor
          C1051 31 [009] - No Signal
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 152
                    Mileage: km
                    Date: 2020.12.17
                    Time: 13:29:33
                    Reception level antenna 1: 590 mV
8397570 - Rear Left TPMS Sensor
          C1052 31 [009] - No Signal
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 152
                    Mileage: km
                    Date: 2020.12.17
                    Time: 13:29:33
8397826 - Rear Right TPMS Sensor
          C1053 31 [009] - No Signal
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 152
                    Mileage: km
                    Date: 2020.12.17
                    Time: 13:29:33
                    Reception level antenna 1: 600 mV
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H07 0080
   Revision: 3A002002    Serial number: 00000116932377
   Coding: 0100000100000000
   VCID: 2F3BEEFD871FA9B3DA9-807A
Address 6C: Back-up Cam.        Labels: 5N0-907-441.clb
   Part No SW: 7E0 907 441     HW: 7E0 907 441
   Component: J772__Rearview      0040
   Revision: 00H08000    Serial number: 525PA8-J060533
   Coding: 0030115
   VCID: 65974CD5996323E3E05-8030
Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 E    HW: 3C8 035 730 E
   Component: Telefon       025 0983
   Revision: --------    Serial number: 35502105254406
   Coding: 020100000100010000000101
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi.rod
   VCID: 25170CD5D563E3E3205-8070
End----(Elapsed Time: 02:31, VBatt start/end: 11.8V/11.7V. VIgn 11.6V)-----
It's now looking for a module 16 (steering wheel controls) but a PQ25 car doesn't have one.
patil
Post by patil »
iichel wrote: Thu Feb 25, 2021 11:27 am 1K8 PDC module retrofitted for automatic PDC activation and perhaps later also RTA
Congratulations iichel.. it's worth the upgrade.👍
Did you notice any change in sensitivity of sensors after installing 1K8 module?
I found the sensors being more sensitive in detecting obstacles and also sporadic false positive triggers.
patil wrote: Fri Feb 26, 2021 6:22 pm
Can't say, haven't driven the car yet :mrgreen:
Do you also have the j527 error?
patil
Post by patil »
iichel wrote: Fri Feb 26, 2021 7:04 pm
Yes iichel, exactly same error is also hanging in my address 10. I've reported about it.viewtopic.php?p=576546#p576546
Error is not affecting the functionality and fault priority 6, so I've just ignored it.
patil wrote: Sun Feb 28, 2021 5:51 pm
excellent, thank you patil!
ciclo, do you perhaps know any way to update the cluster software from 07xx to 08xx or 1xxx?
I see you and the doctor Patil are running 08xx, you probably had this version from factory in the new 6RD cluster?
Yes, my 6RD GTI IC already had the 08xx installed when I bought it.
I suppose that with ODIS you can try to update the SW, but before doing it, I repeat, "before doing it" ask Slavik 💎 or spacewalker 💎 for advice, I think they both know very well this SW 08xx or higher for our ICs.
Now I remember that I tried to update my BlueGT IC to 08xx with ODIS and I was not able to update this SW ... but some time has passed since that attempt...
As you know my BlueGT IC was only able to update it from 06xx to 07xx. ... the rest of what happened with this IC I prefer not to tell ... 🤣
So don't try it before you ask them, no one wants you to have a brick instead of an updated IC.👍
Thank you for the advice, appreciate it.
I was at Slavik's yesterday, to do some experiments for the 1.6 TDI ECU (immo off). He did not know how to do so and doesn't have the files.
I sent the spacewalker an email, let's hope he replies. I heard that updating to 1xxx SW is very difficult due to different EEPROM layout.
Yes, when we were doing all kinds of experiments with the SW 08xx we came to the same conclusion, the hardware has to be very different at some point ...
I guess spacewalker will get us out of doubt because I think he was the one who updated the Xhorse iscancar mm-007 for this SW 08xx.
I got a disturbing phone call today from CNK6R, his wheels were missing. Very sad news.
In other news... Got some new OEM 6C Mirabeau wheels!
RonaldSl
Drives: 6R 1.2 TSI
Post by RonaldSl »
Nice wheels :D
It looks really nice with those OEM 6C Mirabeau! 8)
Lately there are many acts of theft and vandalism, a big rat scratched the hood of my 6R (not my 6R, the 6R of the world) from side to side, fortunately I have it recorded on video and I am not going to make a claim to the "authorities" or supposed justice. The guy who did it is in his 70s, unthinkable. If at the age of 70 someone scratches cars, his life has not made any sense.
I promise to be an exemplary citizen, no one (even the most criminals) has a reason to damage my properties, I'm just interested in knowing if he had any reason for doing it, I will continue to monitor the actions of this mental retard.🤭
People are very upset with the stories of the pandemic.
By the way, now I remember CNK did something with his IC SW 08xx, but I don't remember exactly what he did.
