ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP. 🧙‍♂️
Locked
Re: ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP
The aerodynamic improvement is real, but at a high environmental price ...
The weight of the parts added for this aerodynamic improvement is minimal and correct, they are plastics, and this is where the problem of the equation lies, CO2 emissions / etc ... saved in fuel VS CO2 emissions and other chemicals in production and RECYCLING of said plastics.
It is clear that vehicles must be designed differently. and the change must be NOW!
For everyone, please take your time to watch this video, then you decide.
https://www.youtube.com/watch?v=Gb6wQtNjblk
Golf 7.5 LED's Tail Lights (8SK),(8SP),(8SQ)
I post the following composition of diagrams to facilitate the work to those who need it.
Download it to see it enlarged.
It is not my intention to retrofit the 8SK tail lights on my wife's Golf, just to share the information.
Some images of the 8SQ taillights:
Inner right taillight connector before adding the wire to have the rear fog light on both taillights.
viewtopic.php?p=555624#p555624
I contacted an Aliexpress seller to ask about some small details, he kindly told me that the original 8SK taillights for the Chinese Golf 7.5 (5GG instead of 5G0) have color differences compared to the European ones, so they cannot be mixed. https://es.aliexpress.com/item/32846184 ... AasJa&mp=1
Blue connectors https://es.aliexpress.com/item/40001609 ... AasJa&mp=1
danikd
Drives: Citigo
Post by danikd »
Hi, do you have PN od EU 8SK lights?
danikd
Drives: Citigo
Post by danikd »
Many thx ...
Some preparations before installing the new 5L washer fluid reservoir with G33 level sensor.
V5 Washer pump.
More information on the previous two pages.
If nothing prevents me, I will try to install it this weekend.
Good weekend to everyone!
Golf 7.5 New 5L washer fluid reservoir installed. G33 Level sender activated.
Installation
3L reservoir. Original.
“A weed is no more than a flower in disguise.” ― James Russell Lowell.
VCDS Autoscan.
Saturday,26,June,2021,17:09:05:32438
VCDS Version: 21.3.0.0 (x64)  HEX-V2 CB: 0.4543.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: NEW 5L WASHER FLUID RESERVOIR INSTALLED. G33 LEVEL SENDER ACTIVATED.
Mileage: 37179km-23101mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 29 39 3C 42 44 4B 52 5F 65 A5 A9
          D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 37179km-23101miles
29-Left Light -- Status: OK 0000
39-Right Light -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DKRF)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 025 L    HW: 04C 907 309 BB
   Component: R3 1.0l TFS   H20 6198
   Revision: D7H20000
   Coding: 01190032234415082000
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_ECM10TFS01104C906025L 002003
   ROD: EV_ECM10TFS01104C906025L_002.rod
   VCID: 290F00D8897EC923F8D-807C
Readiness: 0110 0001
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 DD    HW: 5Q0 614 517 AC
   Component: ESC           H25 0424
   Revision: 00000000    Serial number: 51998000000173
   Coding: 01FA6AA114202170477B060560CA2580562884E26006A4733420F00A40AA430B00000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 76B51BA40840D6DBA5F-8022
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Component: Climatronic   H04 1801
   Revision: 00001K08
   Coding: 00020003200110011105004000101022
   Shop #: WSC 00028 028 00068
   ASAM Dataset: EV_ACClimaBHBVW37X 006145
   ROD: EV_ACClimaBHBVW37X_006_VW37.rod
   VCID: 6D8734C87D161503545-8038
   Fresh air blower control module (front):
   A/C pressure/coolant temperature sensor:
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 DH    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H40 0312
   Serial number: 72007150025702
   Coding: 000000000000000000000000000000000000000000000000000000000000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020_VW37.rod
   VCID: 015F7878518EE16380D-8054
   Wiper motor control module:
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS    180621  043  0551
   Serial number:         180705074106
   Coding: 0E4DDD
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  052  0107
   Serial number: S5Y20M05D14H05M53S24
   Coding: 06A8DD
   Anti-theft alarm system sensor:
   Subsystem 3 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005  0316
   Serial number: 000000000ZY191251XZQ
   Alarm horn:
   Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Component: Sirene, DWA  005  0313
   Serial number: 00002854456462182207
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 507     HW: 5Q1 953 549
   Component: J527 SMLS MQB  004  0060
   Serial number: 00000002081804401346
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000308417318277
   Coding: 0271167841
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 51FF8838C16ED1E350D-8004
Address 13: Auto Dist. Reg (J428)       Labels:| 3Q0-907-572.clb
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0682
   Coding: 2B0067C119FFC728949C810560400600000000000000000004
   ASAM Dataset: EV_ACCBOSCHVW416 002008
   ROD: EV_ACCBOSCHVW416_002_VW37.rod
   VCID: 44D1B16C0E1C344BEBB-8010
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    006 0339
   Serial number: 003VWR4F1CUQ
   Coding: 98CCC000000000005C0000CF000800000065
   Shop #: WSC 00028 028 00064
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
   ROD: EV_AirbaVW20SMEVW37X_VW37.rod
   VCID: 094F605869BEA923D8D-805C
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 5G0 980 945 B    HW: 5G0 980 945 B
   Component: BeltPretRevFL  H37 0350
   Serial number: 34169667E30071820325
   Coding: 333135
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 5G0 980 946 B    HW: 5G0 980 946 B
   Component: BeltPretRevFR  H37 0350
   Serial number: 34169668E31071830145
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 307 18
   Component: SideSensor_Df  001 0887
   Serial number: 35700000000F8745C23S
   Coding: 2D2D2D
   Subsystem 4 - Part No SW: -----------    HW: 480 002 807 18
   Component: SideSensor_Pf  001 0887
   Serial number: 358000000000EC18233G
   Coding: 2D2D2D
   Subsystem 5 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001A729FD154210-
   Coding: 2D2D2D
   Subsystem 6 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001A929FD1515577
   Coding: 2D2D2D
   Subsystem 7 - Part No SW: -----------    HW: 480 402 306 18
   Component: FrontSensor_D  003 6149
   Serial number: 3550001A326704A3C63.
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5G1 920 791 B    HW: 5G1 920 791 B
   Component: KOMBI         404 4191
   Coding: 07A52A806E8C000801887A0F1401000000000000
   Shop #: WSC 00200 935 01530
   ASAM Dataset: EV_DashBoardVDDMQBAB 009058
   ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
   VCID: 2B03FAD08382DB330A1-807E
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 09012020001767
   Coding: 030100047F085700DB0002FE080F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF_VW37.rod
   VCID: 70B92DBC6A24F8EB7F3-8024
   Generator:
   Component: 4-01-02-01-04
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H18 0052
   Serial number: 39190002063230049307
   Coding: 2CFFFF
   Subsystem 3 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Component: J367-BDMHella  H10 9070
   Serial number: 9353818504
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   ASAM Dataset: EV_LCMLeftHELLAAU736 001012
   ROD: EV_LCMLeftHELLAAU736_VW37.rod
   VCID: 47CBA6603F2A1F530E9-8012
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   ASAM Dataset: EV_LCMRightHELLAAU736 001012
Address 3C: Lane Change (J1086)       Labels:| 5Q0-907-686.clb
   Component: HRE_Master    H12 0081
   Serial number: 0519386082
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D27C4886DF64583A45-8068
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 5Q0 907 685 C    HW: 5Q0 907 685 C
   Component: HRE_Slave  H12 0081
   Serial number: 0519601132
   Coding: 020111
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 F    HW: 5Q4 959 593 F
   Component: TSG FS        006 0246
   Serial number: 0000305474246
   Coding: 00150220D000048000001000
   Shop #: WSC 00020 999 12345
   ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
   ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
   VCID: 48C9A55C3234102B073-801C
   Rear Driver Side Door Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000009798407
   Coding: 010000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1081
   Coding: 931F0000
   Shop #: WSC 12345 102 209715
   ASAM Dataset: EV_SteerAssisMQB 015157
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73B322B01B32C3F3821-8026
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 01081930001280
   Coding: 00000005090016C200205F03020000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 003003
   ROD: EV_MultiModulContiVW48X_003_VW27.rod
   VCID: 372BD6A04FCA6FD37E9-8062
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 F    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0246
   Serial number: 0000336638884
   Coding: 00150220DE00048000001000
   ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
   ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
   Rear Passenger Door Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000009846262
   Coding: 090000
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    853 0891
   Serial number:
   Coding: 02731001FF0000005111000100880A001F0500F401200000CF
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_MUStd4CDELP 001001
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 323DE7B4A4A88AFB497-8066
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZHV2691212
   Data carrier:
   Subsystem 2 - Part No SW: 5NA 919 866 AR    HW: -----------
   Component: ECE AS 20/21  --- 1430
   Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0009
   Serial number: 30000000250801
   ASAM Dataset: EV_RDKBERU30 006001
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 3431E1AC5EBC84CB5BB-8060
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H10 0610
   Serial number: 28011912K23389
   Coding: 000307000000040100221354C146A90094000E33004000
   ASAM Dataset: EV_MFKBoschMQBB 002041
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40D9BD7C1A04286BCF3-8014
Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb
   Part No SW: 5F0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 Z001
   Serial number: 181027201414
   ASAM Dataset: EV_SoundActuaGen2AU64X 003010
   ROD: EV_SoundActuaGen2AU64X.rod
   VCID: 6A8D3FD44CF8023B317-803E
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-572.clb
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 392FD09879DE79A388D-806C
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-572.clb
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----------(Elapsed Time: 01:40, VBatt start/end: 14.4V/14.4V)-----------
Golf 7.5 How to install G33 level sender 7M0 919 376 in Original 3L washer fluid reservoir.
💎Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/pG7Rn7XDf ... autoplay=1
:lol:
... rear door panels.
With Swiss Knife.
Sketch.
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
ciclo, your wife's golf mk7.5 is on its way to be one of great modified vehicles like ciclo Polo. R Line !!!
Good morning ag69, thank you, ... maybe you are right.
Currently it is a real pleasure to drive my wife's golf.
I'm now struggling/having fun with one of the retrofits, there are some inconsistencies that I hope to resolve this week, ... also waiting for some parts and tools to arrive to continue the summer 2021 project.
I will keep you informed of the process. :wink:
Human being (Homo sapiens)
Human beings (Homo sapiens) are anatomically similar and related to the great apes but are distinguished by a more highly developed brain and a resultant capacity for articulate speech and abstract reasoning. 😶... 😁
I like the little ground loop.
Well, the loop is from the wiring for the warning/exit light, the picture is a bit misleading ..., the reason is to facilitate the installation/removal of the door panel.
If someone uses the same way to connect the ground wire, must make sure that there is continuity (multimeter), if there is no continuity, the paint should be lightly scraped down to the metal.
Locked
