Locked
crosspolo2014
Post by crosspolo2014 »
Hello Aszfaltbetyar,
Many thanxs for your help!
Can u ask your mechanic where to do it?
Greetings!
98octaneblood
Drives: Blue GT MY15
Post by 98octaneblood »
ciclo wrote:"98octaneblood"
Very easy to replace bulb. (user manual)
MTEC H7 Super white 4350K
http://www.hids-direct.co.uk/mtec-12v-5 ... 9005-9006/
Picture here:
http://www.uk-polos.net/view ... 70#p479007
Thanks a lot :wink: I've just ordered the MTECs.
crosspolo2014
thanxs ciclo!!
next week i have time for the car.
i let u no!
98octaneblood
By the way Ciclo, if I'm not wrong, you don't have installed the footrest...is this because taste or technical reasons? I have the OEM Audi A1 pedal covers and footrest.
I've ordered the engine cover (VW and TSI logos) from the Golf GTE. It will give a touch to the engine bay.
Okay crosspolo2014, next week...
98octaneblood I still have not found the proper footrest. :)
http://www.uk-polos.net/view ... 65#p473010
Coming soon installation guide of AUTO heated wiper ejectors with very interesting pictures of the inside of the fuse box. 8)
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Post by Mart!n-GTI-DK »
98octaneblood wrote:By the way Ciclo, if I'm not wrong, you don't have installed the footrest...is this because taste or technical reasons? I have the OEM Audi A1 pedal covers and footrest.
Sorry to jump in and steal your thread Ciclo.
But 98octaneblood Do you have pictures of the Footrest installed?
And is it a straight fit?
98octaneblood
I have them prepared to install pedals and footrest next week, I expect to see the car today and pick it on Friday :P (I guess that you need to drill and glue to fix the part properly)
New Mod: (winter)
AUTO HEATED WASHER JETS (OEM)
Installation guide with many interesting images to other modifications.Image
For best viewing you can download as a PDF file or use the enlargement with magnifier on the link itself.
CLICK HERE: https://drive.google.com/file/d/0B2nv91 ... sp=sharing
Measurements (LHD):
Hi ciclo, as requested an auto-scan from my Polo. It's a 6R from 2011, Bluemotion 1.2TDI.
I ordered a set with light sensor, rain sensor, auto-light switch and dimming rear mirror. It's this one: click
It's already wired up, just have to inform the BCM that there is some extra electronics to play with.
Here is the auto-scan:
Friday,14,November,2014,18:51:19:65217
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WVWZZZ6RZBY123456 License Plate:
Chassis Type: 6R (6R0)
Scan: 01 03 08 09 15 17 19 25 44 56 61 69
VIN: WVWZZZ6RZBY225654
69-Trailer -- Status: OK 0000
Address 01: Engine (J0000-CFWA) Labels: 03P-906-021-CFW.clb
Part No SW: 03P 906 021 B HW: 03P 907 425
Component: R3 1.2 DCM3.7 H06 8510
Revision: 12005001 Serial number:
Coding: 00114014032401080000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ECM12TDI03103P906021B 001026
ROD: EV_ECM12TDI03103P906021B_VW25.rod
VCID: 2757E3DC5E13D526F59-8072
Readiness: 1110 1000
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 210224E3416F00B7842B24E782D500521300
Shop #: WSC 00788 648 00255
VCID: 8717035C32D37526559-80D2
Address 08: Auto HVAC (J301) Labels: 6R0-820-045.clb
Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 326102886DD1A08E527-8067
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 088 D HW: 6R0 937 088
Component: BCM PQ25 Re4 H46 0322
Revision: BU046001 Serial number: 0379 028111968
Coding: 3CB02BB808210000002809B07D2B9CD8DF80611F7E860001A00000000000
VCID: 3F875BBCAE837DE6AD9-806A
Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 007 1611
Coding: 58BC30
Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 007 1611
Coding: 48BC30
Subsystem 3 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
Component: E221__MFL-TAS H09 0013
Coding: 820000
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Component: VW10Airbag022 H09 0020
Revision: -------- Serial number: 003GX00EPNH2
Coding: 003232
ROD: EV_AirbaVW10BPAVW250_VW24.rod
VCID: 4A917A68ED41C84E0A7-801F
Crash sensor for side airbag; driver side:
Serial number: 3575HRB40650BI7U48C8
Crash sensor for side airbag; passenger side:
Serial number: 3585HRB405J09RECEOUJ
Crash sensor for side airbag; rear driver side:
Serial number: 3515RRB405T0BTBEF9G7
Crash sensor for side airbag; rear passenger side:
Serial number: 3525RRB405R0BTBEKPFQ
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 861 F HW: 6R0 920 861 F
Component: KOMBI H05 0304
Coding: 540A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 387530A083AD4ADE6C3-806D
Address 19: CAN Gateway (J533) Labels: 6R0-907-530-V2.clb
Part No SW: 6R0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H38 0025
Revision: H38 Serial number: 040211F1003097
Coding: 2500C2
VCID: 336F078C92CBA986591-8066
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H05 0304
Serial number:
ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
VCID: EAD15AE80D81A84EAA7-80BF
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 00788
VCID: 2F670BFCEAE38D663D9-807A
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 6R0 907 534 HW: 1K0 907 951
Component: Batt.regelung H38 0025
Coding: 030B1A5A
VCID: F4ED449057456EBE00B-80A1
Subsystem 1 - Part No SW: 6R0 915 181 B HW: 6R0 915 181
Component: J367-BDM H07 0150
Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Towbar module H09 0100
Revision: 3A001001 Serial number: ¿¡006789000000
Coding: 0100000100000000
VCID: 3065088063DD929E243-8065
End ---------------------------------------------------------------------
98octaneblood
Hi Ciclo, the dealer told me that the pedals I've provided them (OEM Audi A1) are not suitable to my 6C :cry: They told me that they will not be fixed unless I glue them. I just watched a video that you posted some time ago with this issue. Any tip to fix this? I love the A1 OEM look.
Thes are like mine:
98octaneblood
What do you think about the little net-pocket at the lower passenger side? Useful to leave some stuff:
Mart!n-GTI-DK
98octaneblood wrote:Hi Ciclo, the dealer told me that the pedals I've provided them (OEM Audi A1) are not suitable to my 6C :cry: They told me that they will not be fixed unless I glue them. I just watched a video that you posted some time ago with this issue. Any tip to fix this? I love the A1 OEM look.
The pedals them self should fit. I have them in my Polo. The footrest (as I expressed the other day) I can have som conserns about.
Mart!n-GTI-DK
So does Ciclo here:
If the part number for the pedals is: 8N1 064 200 they are a straight fit. :)
98octaneblood wrote:Hi Ciclo, the dealer told me that the pedals I've provided them (OEM Audi A1) are not suitable to my 6C ...
The dealer is right, brake and clutch aluminun covers are not compatible between 6R and 6C, change the fixing of pedals.
You should buy the aluminum covers of the New GTI, New R-line 6C (your car model). Ask at the dealer if available Kit aluminum covers for 6C.
http://www.km77.com/fotos/Volkswagen/Po ... ackLimit=8
Also you can see them in this video:
https://www.youtube.com/watch?v=XXQgexQRAtU
6C
Accelerator: --- not listed in ETKA. :?
Brake: --- 5Q0721131A
Clutch: --- 5Q0721601A
The net for some stuff on the tunnel side is a good idea, but to be seen whether the installation in our VW Polo is possible.
I take to give you some tips, :mrgreen:
- For your 6C not buy the VCDS 12 cable, you will need to buy a version 14.8 (now Beta) or higher.
These new versions are WIFI and "perhaps" be available in Spanish... :wink:
- If you want to buy good products for cleaning your BlueGT, detailed and others, this is a good website to buy.
http://store.carcareeurope.com/nuevos-productos-cce/
Locked
