Page 40 of 43
Re: Polo 6R/6C Photo Gallery
Posted: Fri Feb 04, 2022 11:54 am
by iichel
Likely 288 or 312mm with Audi S1 caps
Posted: Sun Feb 06, 2022 8:10 pm
by Lee_Liu_Te
Na 99% są to zaciski z audi s1 8X0615123A, 8X0615124A. Plus tej blaszki jest taki że jest przykręcana i można ją odkręcić i pomalować jak się chce :wink:
Posted: Sun Feb 13, 2022 6:53 am
by Peter N
mosmadsam wrote: Fri Feb 04, 2022 10:24 am
Peter N wrote: Sun Dec 05, 2021 6:03 am The winter look.
Time for a little detailing session today, with a wash and a top up, on paint protection. ✨✨✨
What brakes are you running on the front there Peter, looks like some Audi RS?
Close :-)
Audi S1 brakes and Zimmermann 310 mm sportdiscs
Posted: Wed Feb 16, 2022 12:35 pm
by mannerboy
good works
Posted: Wed Feb 16, 2022 2:43 pm
by mannerboy
funlovincriminal wrote: Fri May 07, 2021 10:28 am My GTI with 18'' BOLA VST
very nice
Posted: Tue Feb 22, 2022 10:40 pm
by stevewb
wheels done gloss black..
Posted: Wed Feb 23, 2022 2:22 pm
by mosmadsam
Peter N wrote: Sun Feb 13, 2022 6:53 am
Close :-)
Thanks Peter, did you have to make any modifications to fit them or are they a bolt-on upgrade? I believe these are the same brake callipers as a GTI right?
Posted: Wed Feb 23, 2022 2:50 pm
by iichel
It's a bolt-on upgrade (only change the carriers) if you have the 288mm setup.
Posted: Fri Apr 01, 2022 6:52 pm
by amer6R
The time has arrived
I'm going to use light wheel set setup to get the maximum possible. Will run hankook k125 in 195/55 stock. We will see how they grip maybe 205/50 upgrade Toyo TR1.
I dont see the turbo running anywhere near 2.3 bar ( no need for map upgrade (stock is i think 2.5 bar/3 bar) :?: )
Tommorow it should go in, I will have access to 2post lift. Fingers crossed everything goes well.
My goal is 180hp and a sleeper. I have no outside modifications (will probably remove the rear tint).
Next:
288 mm brake upg.+ 2kg of rotational mass
Custom dog bone mount ( I have everything drawn out) -Stiffer, weight 750g.
Short shifter modification nothing crazy.
Posted: Tue Apr 12, 2022 9:14 am
by mosmadsam
Here's my Blue GT, I've completed the 6R GTI front end swap including a TRC front splitter. For the lower grill sections, I painted them with black PlastiDip to get rid of the horrible grey finish for a more blended appearance with the bumper! Next up, I've got some Porsche wheels waiting to go on...
Instagram: @polo_blackgt
Posted: Mon Apr 18, 2022 4:44 pm
by 2fast4ya
I purchaced a set of aftermarket alloys that look exactly the same as the original wheels the polo came with, i curved the original alloys so needed to refurb them, the only issue was that the hub logo’s were smaller than the original one on the original alloys, i looked online for some hub logo’s & i saw the golf gti hub logo’s which looked smart but they were being sold from dealers for £75 a set so i wernt paying that so i purchaced a set of caddy hub logo’s secondhand in great condition which have the same details as the smaller ones that came with my polo, purchased some red heat resistant spaypaint & some lacquer & made some golf gti center caps, for a fraction of the price , i use the backs of the caps that came with the aftermarket alloys because the caddy ones wouldnt clip in the alloy as the clip bits were shorter so i spliced & grafted them to fit & hold tight in the alloys, then painted & varnished them , they came up a treat & looked well polished against the new alloys , to this day they are still looking good , the pic of my car was before i done the caps , but thats my polo 2016 gti 1.8 192hp tsi bm all waxed & machine polished .😁
Posted: Mon May 16, 2022 8:57 pm
by Le_Combattant
My little one <3
Posted: Sun Jun 05, 2022 2:31 pm
by amer6R
Posted: Wed Jun 15, 2022 12:17 pm
by iichel
Darkside TDI turbo damper delete?
Posted: Wed Jun 15, 2022 12:20 pm
by amer6R
iichel wrote: Wed Jun 15, 2022 12:17 pm Darkside TDI turbo damper delete?
No, I made it. It can use factory hose lenght.
As I know darkside damper doesnt have this much clearance in all directions
