UK-POLOS.NET - THE VW Polo Forum • 9n3 Gti bhp output - Page 5
Page 5 of 7
Re: 9n3 Gti bhp output
Posted: Fri Aug 21, 2009 11:20 pm
by whitegtipolo
LeMeph wrote:got my tip fitted, only made 202bhp....well dissapointed. Oh well life goes on i guess. Hoping the low output was due to the extrememly hot weather and the car needing its service..
what you had done?? what map??
Posted: Sat Aug 22, 2009 2:26 pm
by Turbomier
Turbomier wrote:Full stock
161hp - 250nM
now i have airfilter and exhaust,
22nd august i will go again on Dyno, i'll let you know what it did.
Today i went back!
result was a bit disapointing...
167.7Hp and 254.9nM (140.3WHp)
Before i had 161Hp and 250nM(133WHp)
so i gained 6Hp and 4nM from milltek and airfilter.
i think the true gains will show when it's chiptuned.
my A/F mixture was verry good also :P
anyhow i don't care that much for figures, the car goes well, healthy and strong, thats what important for me :mrgreen:
Posted: Sat Aug 22, 2009 8:25 pm
by Gillen
Is that just a cat-back Milltek mate or turbo-back?
Posted: Sun Aug 23, 2009 8:54 am
by RoSonic
Turbomier wrote: Today i went back!
A comparison between the two dyno charts (if you can post them) would be interesting to see how the power curve was affected by the new exhaust on the entire rev range, not only the max power output.
Posted: Sun Aug 23, 2009 8:56 pm
by Turbomier
i have a Full milltek system on it, turbo back, with sports-cat.
i also have a dynochart with the full stock output and the recent output on it, so it's easy to compare.
i will try and post it tomorow :wink:
Posted: Tue Aug 25, 2009 5:04 pm
by LeMeph
ive got a pipercross panel filter
miltek turbo back exhaust with sports cat
AMD stage 1 remap
forge 007p DV
and the forge turbo intake pipe
does service light beeping count for anything :roll:
theyve offered me a free re-run on the dyno when the weather conditions are a bit more settled as it was piping hot on the day it was roaded so im just waiting to get the service done before i get RR'd again. I didnt realise my car hasnt been serviced since it had its first one done at like 8000 miles i think? im now on 26!!!!! Fell like a right pillock keep forgetting to get it done, should be done this week hopefully mind.
Posted: Tue Aug 25, 2009 5:08 pm
by Gillen
200bhp with those modifications and Stage 1 map isn't too bad? I don't think it is anyway. Get a FMIC and Stage 2 and you should be around 225bhp?
What were your torque figures mate?
Posted: Sun Aug 30, 2009 12:16 pm
by vlad_pvs
Revo stage 2, Forge FMIC, BMC CDA, stock exhaust without cat: 190 wheel horse power, 367 Nm (271 lb ft) :D
Posted: Fri Sep 11, 2009 8:28 pm
by Turbomier
so, here is my dynochart.
GTI with K&N filter and Full milltek.
This is a comparision between my stock dynochart and the recent chart with K&N and Milltek.
both dynoruns where on the same dyno :wink:
Posted: Sat Sep 12, 2009 3:51 pm
by RoSonic
Looks good.
As i can see there are about ~10NM gained on most of the rev range - between 2700-3200rpm and the same above 3800rpm.
Posted: Sun Sep 27, 2009 2:34 pm
by Dink
i had mine rr'd at awesome gti after stage 2
got 226bhp and 257lbs/ft
thats apr stg 2, forge fmic, forge dv, miltek turbo back+ sports cat and bmc air filter
Posted: Wed Sep 30, 2009 8:34 pm
by jimlad09
posted a while ago regarding my stage 1 225.8bhp i am going to try and get a copy of my print out up! Im looking at a milltek turbo back and full induction. Has anyone gone down the route of cams/pistons? good gains? also saw throttle bodies mentioned somewhere! Just looking to get a result for a car already driving brilliantly! Upon research and chatting to a VW technician instructor apparently when cars leave the factory they are set up to a set spec but obviously human error or whatever some leave better than others.
This was mentioned at my dyno run that they cant believe it was a flat 150 before it was flashed! Ideas?? :?:
Still im smiling every time i drop a gear! Surely thats what its all about!? :lol:
Posted: Thu Oct 01, 2009 2:35 pm
by Instigator
not every dyno is the same, some give more than others, and others may give less.
but most of them are about right nut it can happen.
and it can also happen that some leave better from factory, and it also does alot how you drive it from the begining :wink:
verry good results BTW!!
Posted: Sun Oct 18, 2009 9:41 pm
by jimlad09
haha yeah driving style might come into it. I dont rag her by any means but they are designed to be driven. Attended a local meet today with some nice cars there incl. new mk6 gti and gtd and they were impressed with the figures. But i guess when these things happen theres all sorts of variables that even the blokes operating the dynos dont know about. hmm.
Decided i need some h&r in my life tho!
Posted: Thu Nov 19, 2009 5:56 pm
by drennan
mines a standard 1.8t but with a remap however it is suposed to take it up to 225bhp........ sound bout right? as i see ppl on here with stage 2's as that kinda power. was a mate of mine in verve that did it. also do you all run your cars on super? 99?
