6R - Multifunction Steering Wheel Retrofit
Re: 6R - Multifunction Steering Wheel Retrofit
you'll probably need to re-route the horn wire from the horn plate to T5/4. Remove T5/5.
i don't give you any chance to make the CC work without major changes.
for the lighting you need to change the BCM to a model that does support lighting, from 2018 or younger
Hiroki
- Drives: 6r Polo 1.2 TSI 2011
Thanks for the lightning fast reply.
I'm trying to past the OBDeleven report here but it said "Forbidden"
My BCM is
09 Central Electrics
System description: BCM PQ25 H+3
Software number: 6R0937087G
Software version: 0221
Hardware number: 6R0937087A
Hardware version: H46
Serial number: 0344 264100269
Long coding: 3CB82FF828FB060092300E003FAB9CD0F640417F60800040200000000000
My BCM is
Hiroki
iichel wrote: Tue Feb 28, 2023 5:39 pm you'll probably need to re-route the horn wire from the horn plate to T5/4. Remove T5/5.
And also T5 you mean by this one?
Thanks for your kind patient.
Yes exactly
Just like to give a big thanks for the info on this thread having successfully fitted and coded a 6R MFSW with left hand buttons, RCD510 and Bluetooth module.
Having fitted the 6R MFSW I have now got hold of a 6C MFSW with Cruise Control buttons on the left and radio/phone on the right
Having done a fair bit of reading around the forum I'm looking for confirmation that as I understand it CC won't work from the MFSW on a 2012 Polo Match 6R?
TIA
TIA
Hiroki
So sorry I was busy and didn’t get a chance to try
I just got the wiring 5K0971584A.
I tried replacing this to my C version. Also no luck with other buttons except for the page left and right plus the “ok” button as volume down.
Is there anything that I’m missing out?
When I remove T5/5 the horn not working.
I already wire up for CC. Waiting the
“VOLKSWAGEN POLO SEL TDI HATCH 3dr 2011 INDICATOR STALK SQUIB CLUSTER 6Q0953503EJ” which will be here next week.
And also my BCM is 6R0937087G. Can I make the light work?
I don't think 087G will have the software for mqb mfsw backlight
Hiroki
Noted with thanksiichel wrote: Fri Mar 17, 2023 11:36 pm I don't think 087G will have the software for mqb mfsw backlight
Hello,
I have 2012 polo 6r. My wheel is standard plasticky or rubber?!? wheel with out buttons.
I saw a wheel with buttons on the left side for radio and bluetooth answering.
Will this wheel fit without changing the airbag it self.
- The current one
- Screenshot_20240705_074504_WhatsApp.jpg (854.52 KiB) Viewed 238613 times
No you will need a new airbag too
Do you maybe know airbag part number and part number for wiring mfsw?
Thanks.
Buci wrote: Sun Jul 07, 2024 9:24 amDo you maybe know airbag part number and part number for wiring mfsw?
Also if the wheel is made just from leafher without buttons will I need to replace the airbag?
Here is the picture of the leather one..
Thanks.
- Leafher one..now I have the rubber..
- Screenshot_20240706_155957_Njukalo.jpg (280.11 KiB) Viewed 238505 times
Can somebody help?
Please can somebody confirm that the leather one without buttons is direct retrofit to the rubber one without the buttons?
Thanksss
- jammydodger
- Drives: 6R GTI
