Locked
Re: New Member. R-line 1.2 TSI 90hp 119gr.
Do not worry hornmeister all opinions on my topic are welcome.
Your option for shark antenna is very interesting and cheap. I think I've bought from that seller (angeno) any product, but in Alibaba.
Thanks for the information, I hope to see those pictures. Please leave me a link to see the result when you post.
mattymdm
Post by mattymdm »
Cheers ciclo , Going to buy a genuine aerial and fit that just (not the cheapest option but will be a stright swap and work fine.) I'll let you know how i get on
Ok.... :wink:
New mod:
Net side trunk
After watching a few models I finally decided on the net of Seat Leon 2013. I bought on a Seat dealer and the cost was 15 € along with the clips.
Pieces:
Must be slightly adapt the net structure to the form where goes located. This can be done by hand easily.
For installation I recommend removing the side panel to make the holes where the clips are. I have used a punch and scissors, I have introduced a part of the scissors perpendicularly to the flaps of the clip.
With the three clips is enough for a solid and durable fastening.
More images:
Image Image Image Image Image
New mod:
Rear footwell lights
Parts
http://www.aliexpress.com/item/Fashion- ... 76106.html
http://www.aliexpress.com/item/No-error ... 58051.html
Electric Scheme.
The following image is a composite I made from the Elsawin.
Location.
Installation.
Connect the positive to pin 65a of the BCM and the negative to pin 4a of the BCM.
Using a guide wire insertion below the carpet to the seats.
I have used this type of LED. The lighting is good. Also I installed the front and in the trunk. They are perfect for this installation (temperature and lighting).
Check before installation.
My camera is not good and the lighting is better than that seen in the following images.
Everything works perfectly and is achieved very pretty ambient lighting...
Using the multimeter and measuring on the fuse:
I installed all LED interior lights and actual consumption total is 1.06 Amps. Including those of the mirrors and trunk.
With all the bulbs incandescent real consumption was 3.46 amps.
Comment that the links I posted are just to lower the price of installation. It's easy to make the accounts of the parts needed.
I did the wiring from bcm to the seats, I did not use the one supplied with the lamps of the link. Also say that the brackets belong to skoda superb and I bought a Skoda dealer.
PS: Sorry for my English, if any phrase or word that is inaccurate please tell me to correct it. Thank you.
New mod:
White LED Interior Lights
The images are of very low quality. Sorry. :cry:
Links at the end of the post.
With flash.
Without flash.
True Color.
And as you have spent your time in viewing these images of low quality maybe you overlooked this detail in the second image.
Links:
For the mirrors and rear dome:
http://www.aliexpress.com/item/10pcs-Lo ... 17376.html
For dome:
http://www.aliexpress.com/item/Free-shi ... 70803.html
For the footwell lights and trunk:
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Post by Mart!n-GTI-DK »
Looks awesome. :)
Love the little skiing man. :D
Does the interior light stil dim down slowly when it turns off now that you have LED's??
Thanks Martin-GTI-DK. :D
Everything works fine as with incandescent bulbs. The diminution and increased lighting as before.
There are no bugs and do not stay slightly lit LEDs.
You must put at least one CANBUS led bulb. That is enough.
Mart!n-GTI-DK
Nice. :)
Now Available chromed mirrors switch on aliexpress to purchase easily. When I did the tutorial to change the knob was not available.
http://www.aliexpress.com/item/OEM-Brus ... 25881.html
Also the link to the window switches:
http://www.aliexpress.com/item/OEM-Chro ... 08378.html
http://www.uk-polos.net/view ... 30#p466758
joelburbidge
Post by joelburbidge »
would you ever do auto folding wing mirrors?
I will do after the 2014 restyling...
In any case you have interesting information in the description of this video:
https://www.youtube*.com/watch?feature=pl ... luUPSujo2M
"The video information is old"
The correct information for the part numbers of the parts needed I have published some posts later. (RHD and LHD)
Also here:
https://www.youtube*.com/watch?v=XLYtk9y2 ... r_embedded
and :shock: :wink: ,
https://www.youtube*.com/watch?feature=pl ... T9WRhcKjwk
joelburbidge
will the part number work in the UK?
joelburbidge
Did you get yours from vw?
Locked
