13 R Line; Nimbus Grey;
Calvin's R Line; eibach spring kit :)
Wow scooba that sounds pretty in depth
Re: Calvin's R Line; eibach spring kit :)
Hi Wixay
Eddie-GT is the master of retrofit it all looks OEM and you wouldnt have known he had the car in bits . Just waiting for the new GTI Cluster with full mfd .
Mine came with cruise control and rear parking sensors as standard so no need to retrofit lol. How much is the gti cluster costing?
Re: 13 R Line; Nimbus Grey;
Hi ,the cluster swap to a GTI Mfd was a must for me so it hooked up the RNS and VAG BT Kit also because we had already fitted the MFSW buttons the same as a MK6 Golf having buttons on both sides of the steering wheel I'm told Polos only have them on the left side, It cost £250 for a new cluster and fitting and coding.Wilxay wrote:Mine came with cruise control and rear parking sensors as standard so no need to retrofit lol. How much is the gti cluster costing?
- greypolo9n3
- Drives: white 6r 1.6 tdi rline/gti
is it still not too high from the back?
