Retrofitting of Auto leveling headlight system (AFS) for Polo 6R
- CNK
- Drives: 6R
Re: Retrofitting of Auto leveling headlight system (AFS) for Polo 6R
I thought my AFS work well, but probably I did something wrong.
Maybe I use incorrect part (6R0 907 357 C).
VCDS:
AFS test:
but...
when I try change in my coding Byte 01 from 07 to 01 (label VW Polo 6R) I have alert:
So what's wrong with my AFS?
(I have VCDS 12.12)
VCDS:
Address 55: Xenon Range (J431) Labels: 6R0-907-357.clb
Part No SW: 6R0 907 357 C HW: 6R0 907 357 B
Component: AFS-ECU 005 0050
Revision: -------- Serial number: --------------
Coding: 0708000001000000
Shop #: WSC 85046 004 02308
ROD: EV_HeadlRegulVWLWRCC.rod
VCID: 3A7D42AABD28F3CE959-806F
No fault code found.but...
https://1drv.ms/f/s!Ap3Ii1h33vISgrcCc1IaDYYDvxkh8QCoding rejected
Error 31: Request out of range
your AFS seems to be the incorrect part number. I think it should be the 6R0 907 357.
I.e this is my AFS with the OEM LED headlights (just as your Polo):
Address 55: Headlight Range (J431) Labels: 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Coding: 0192000001000000
Shop #: WSC 00788 648 00255
VCID: 77F7EDA3CE3F36FA91-8023
You have the 6R0 907 357 B (see HW in your autoscan). That part is only delivered on the Passat CC
- CNK
- Drives: 6R
ciclo's unit 55:
firegrafik said, that the coding 0D4A000001000000 in the AFS 6R0 907 357C have all polo sedans 2016 with bixenon headlights and ESP from the factory.
firegrafik told me, that 6R0907357C control units could be in two EEPROM preset (Z0A — for ESP and Z0D — for ABS only)
The Z0A control unit could change headlight level not only by the rear axle sensor, but by the ESP sensors also — dinamic leveling.
Some guy from Russia wrote me, that my AFS module is not for my AFS sensor. Then I started exploration on forums. It's strange, because it looks like it works
Coding: 0112000001000000
VCID: 77B8CCA5BB8365C940-8022
No fault code found.firegrafik told me, that 6R0907357C control units could be in two EEPROM preset (Z0A — for ESP and Z0D — for ABS only)
Is this still unfixed? I have fixed some AFS modules with this issue, needs a new file flashed to the module
- CNK
- Drives: 6R
So I need to buy this one: http://allegro.pl/sterownik-zasiegu-xen ... 24520.html ?iichel wrote:I'm not sure...http://www.oemepc.com/tvn_result/search/tvn/6R0907357C
H02 0070 like your AFS/
- CNK
- Drives: 6R
Ok, thanks!iichel wrote:i think so, yes
6R0907357C and 6R0907357B are also in Polo but not in models from Europe.
Eg. http://www.oemepc.com/vw/part_single/ca ... d/0/lang/e
RoFIREmaN from drive2.ru said me, that 6R0907357C is always in tandem with the sensor 5Q0907503 (800Hz).
6R0907357C is OEM part in T6 California '16:
that can very well be, i don't know much about the china spec AFS system. it sounds very probable! the 5Q0 is based on the golf 7 according to the part number, so it makes sense that it only works on a selection of moduls
I wonder why you deleted the video sound.CNK wrote: AFS test:
https://www.youtube*.com/watch?v=b9CwIJy1Gns
I agree with everything previously mentioned.
graaja
- Drives: Polo GT TSi
Hi iichel,
In the Bi-Xenon headlights, when AFS is installed, does the AFS control only the up/down movement of the headlight? Or does it also control the left/right movement when the steering wheel is turned when the car is running?
I read in one of the descriptions of the Bi-Xenon headlights that these support bend lighting, but the diagram in the below link of the Bi-Xenon shows only one range control motor.
http://www.oemepc.com/vw/part_single/ca ... g/e#sec_15
in the Polo 6R, we only have up-down and no left-right swiveling.
Exactly iichel.
graaja,
AFS can include many additional functions but it is not the case of the Polo 6R with Bixenon or Led Headlights.
Cornering Light function is static in 6R, no has the dinamic cornering light. Static cornering lights in Bixenon headlights is much better than in the fog lamps, the vision field is more wide.
Static = up to 40 Km/h (according traffic rules) but it can be modified in 32 channel (BCM adaptations) up to ∞ & --->...
(put in your book it was discovered by ciclo for the PQ25 BCM)
Dinamic = for example
graaja,
