Page 5 of 10
Re: Polo 6R 2016 Mod.
Posted: Tue Aug 08, 2017 12:33 pm
by rdasadia
ciclo wrote: Sat Aug 05, 2017 9:08 pm Not for the moment, now I do not have all the information within my reach ...
As for your Polo, thank you very much for all the information you provided me by email, it is of great value to me ...
Please, can you do a test on your 6R?, with VCDS uncheck Byte2 Bit1 from your instrument cluster and tell me if the direct TPMS is still working without vcds faults.
If you need a new BCM coding for your 6R tell me what lights and wires (all) you currently have installed, please one by one (better by email), It will be a provisional coding until you install the dimmer and Bixenon headlights.
Surprisingly still works without any error after unchecking :shock:
Not required my freind. Dimmer switch already installed and working fine. New front lights on its way!!
Posted: Tue Aug 08, 2017 12:53 pm
by ciclo
Haha ... thanks for this checking (here we are making new discoveries, again) ... haha
As for the Dimmer, well done!!, we will wait for your Bixenon.
I'm still investigating the direct TPMS of your Yeti. :wink:
Posted: Sun Aug 20, 2017 6:52 pm
by rdasadia
VCDS Version: 17.8.0.1 (x64)  HEX-NET CB: 0.4401.4
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: MEXA16604GT072590   License Plate: 2099
Mileage: 12430km-7723mi   Repair Order:
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 56 65 0B
VIN: MEXA16604GT072590   Mileage: 12430km-7723miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 KC    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 6270
   Revision: --H10---    Serial number: 00000000000000
   Coding: 00250056232400080000
   Shop #: WSC 01234 785 00200
   ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
   VCID: 6D9229D8BC778B2E51-8038
Readiness: 0110 0101
Address 02: Auto Trans        Labels: 0AM-927-769.clb
   Part No SW: 0AM 300 065 N    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 6501
   Revision: 00043014    Serial number: CU501511017434
   Coding: 0000020
   Shop #: WSC 01324 785 00200
   VCID: 3A38D28475B9EC9684-806E
   Part No SW: 6R0 907 379 BH    HW: 6R0 907 379 AS
   Component: ESP9.0i front H03 0001
   Serial number: --------------
   Coding: 62DD2463422A03C2461924724251C0800908
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
   VCID: 0542717884C7536EB9-8050
   Serial number: 05061504651234
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X_VW25.rod
   VCID: 7EB01E94E11100B6F8-802A
   Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
   Component: Climatronic   H12 0615
   Revision: V0000000
   VCID: 41CAA568D86FBF4EC5-8014
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 352161294
   Coding: 3AB02BB848B30000013806917CEB9E90BAC067FF600D30C1200000030000
   Shop #: WSC 51200 002 104857
   VCID: 2A18E2C445195C16F4-807E
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 271115 03  37  0059
   Coding: 0730DD
   Subsystem 2 - Part No SW: 6R0 959 802 EF    HW: 6R0 959 802 EF  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  020 2551
   Serial number: 13102848151112221545
   Coding: 050008
   Subsystem 3 - Part No SW: 6R0 959 801 ED    HW: 6R0 959 801 ED  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  020 2551
   Serial number: 13202849151112235703
   Coding: 050008
   Subsystem 4 - Part No SW: 13 202 849 15    HW: 132 028 491 51
   Component: RLS 271115 03  37  1122
   Serial number: ÿ132028491511122357
   Coding: 353730
   Subsystem 5 - Part No SW: 6R0 959 811 S    HW: 6R0 959 811 S
   Component: J388__TSG_HL  019 1552
   Serial number: 13202728151109234823
   Coding: 020000
   Subsystem 6 - Part No SW: 6R0 959 812 S    HW: 6R0 959 812 S
   Component: J389__TSG_HR  019 1552
   Serial number: 13202729151110091329
   Coding: 020000
3 Faults Found:
00901 - Back-Up Lamps
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 12432 km
                    Time Indication: 0
                    Date: 2017.08.20
                    Time: 09:59:26
02745 - Bulb for Daytime Running Light; Left
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 107
                    Mileage: 12432 km
                    Time Indication: 0
                    Date: 2017.08.20
                    Time: 09:59:26
02746 - Bulb for Daytime Running Light; Right
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 12432 km
                    Time Indication: 0
                    Date: 2017.08.20
                    Time: 09:59:26
   Part No SW: 7E0 919 475 J    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0105
   Revision: --------    Serial number: 28261224902578
   Coding: 300101
   Shop #: WSC 02756 790 50316
   ROD: EV_EPHVA18VW250GPCS.rod
   VCID: 393ACD88B8BFE78E8D-806C
   Revision: --------    Serial number: 003GW012EG31
   Coding: 003036
   VCID: 49DABD48E85F770E1D-801C
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 6RD 920 870 A    HW: 6RD 920 870 A
   Component: KOMBI         H05 0805
   Coding: 141C01
   Shop #: WSC 12345 123 12345
   VCID: 47DEBB70FE4B817E0B-8012
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 002300
   VCID: 689C58CC9B95AE0622-803C
   Component: IMMO          H05 0805
   VCID: 6A9822C48D999C1634-803E
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Coding: 0001000000000000
   ROD: EV_SteerAssisNSK_014_VW12.rod
   VCID: 41CAA568D06FBF4EC5-8014
Address 56: Radio (J503)       Labels: None
   Part No SW: 6RF 035 187     HW: 6RF 035 187
   Component: Radio         013 0116
   Revision: --------    Serial number: VWZGZ1R3521196
   Coding: 0000044000000F
   VCID: 06407674B1C15876B0-8052
   Serial number: 30000000054715
   ROD: EV_RDKBERU30.rod
   VCID: 373ECBB08EABF1FE7B-8062
End----------(Elapsed Time: 01:34, VBatt start/end: 13.7V/13.6V)-----------
Would like to enable the side mirror auto folding with KEY FOB. Have folding mirrors right now. Is only coding needed or will require new door modules?
Posted: Sun Aug 20, 2017 8:50 pm
by iichel
Check ciclos topic for DRM coding
Posted: Mon Aug 21, 2017 6:23 am
by ciclo
Coding: 050008
Coding: 050008
I do not know if this software (for WRMs in 6R IND RHD) is able to manage the folding mirrors automatically (with remote). I would say 99% NO.
What is known so far is that the software for WRM with automatic function for folding mirrors starts with 8XXX (6R, T5.2, T6)
Now :lol: ,
Fault Priority: 3
Fault Frequency: 1
Reset counter: 107
Mileage: 12432 km
Time Indication: 0
Date: 2017.08.20
Time: 09:59:26
You already had this fault before making the BCM wiring adaptation (we talked about it at the beginning of this topic). My question is the following, did you install the dimming mirror with the light sensor on your 6R or they are from factory?
It is likely that the installation that you did is not correct and you broke the wire that gives power to the reversing light. (check this wiring installation)
However make sure that the bulb is not blown.
This is your Light sensor.
Coding: 0730DD
And the next one is your multifunction steering wheel (from a Golf) that you bought in México (hmm...Viva México cab.....! :lol: -popular and funny sentence on films, nothing more-).
As you can see (and even if it works correctly) it is not read correctly. BCM believes it is a second light sensor with corrupt software.
Coding: 353730
Did you install the wiring I sent you to try to solve this problem?
Fault Priority: 3
Fault Frequency: 2
Reset counter: 107
Mileage: 12432 km
Time Indication: 0
Date: 2017.08.20
Time: 09:59:26
Fault Priority: 3
Fault Frequency: 1
Reset counter: 107
Mileage: 12432 km
Time Indication: 0
Date: 2017.08.20
Time: 09:59:26
To solve when installing Bixenon headlights. :wink:
Posted: Mon Aug 21, 2017 6:44 am
by rdasadia
ciclo wrote: Mon Aug 21, 2017 6:23 am Subsystem 2 - Part No SW: 6R0 959 802 EF HW: 6R0 959 802 EF Labels: 6R0-959-802.CLB
Coding: 050008
Coding: 050008
Now :lol: ,
Fault Priority: 3
Fault Frequency: 1
Reset counter: 107
Mileage: 12432 km
Time Indication: 0
Date: 2017.08.20
Time: 09:59:26
Coding: 0730DD
Coding: 353730
Fault Priority: 3
Fault Frequency: 2
Reset counter: 107
Mileage: 12432 km
Time Indication: 0
Date: 2017.08.20
Time: 09:59:26
Fault Priority: 3
Fault Frequency: 1
Reset counter: 107
Mileage: 12432 km
Time Indication: 0
Date: 2017.08.20
Time: 09:59:26
Hi Ciclo. Yes backup bulb is indeed blown and needs replacement. Was aware of the same. My RLS & dimming mirror are factory fit. VW started giving this in all GT TSi from 2016 onwards
DRL lights error will be solved as soon as I get the delivery of the OE front lamps and install them.
I havent yet replaced the steering harness that you have send. Will do it this week.
Still any suggestions to try any other coding for subsystem 2 & 3 please to enable auto function
Posted: Mon Aug 21, 2017 7:49 am
by ciclo
Test with:
05000A for both WRM. (but I'm afraid it will not work)
Once the two WRMs are coded, you must reset the comfort function in both windows. Even if this function already works.
I insist:
1. First you encode both WRM.
2. And then you enable the comfort function in both WRM.
click :arrow: Image
Your BCM coding is correct for it.
Posted: Wed Aug 23, 2017 7:15 am
by ag69
ciclo wrote: Thu Apr 13, 2017 9:21 pm Info for followers: :lol:
ImageWhite background illumination? From golf?
could you please explain how did you remove the older steering?
There are two dimples at the back. Once you puncture them what was next step?
Posted: Wed Aug 23, 2017 7:40 am
by rdasadia
ag69 wrote: Wed Aug 23, 2017 7:15 am
You need to remove the cover between steering and the cluster. Once you remove that you will see two locks at the back of the steering which requires some skill to take out the air bag. You need to then disconnect the harness from the air bag. You will see another lock nut in the front centre of thr steering. You will need special tool to open this
My advise is to get it removed by a VW technician. Dont forget to disconnect negative terminal of the battery before commencing any work.
Posted: Wed Aug 23, 2017 7:41 am
by rdasadia
ciclo wrote: Mon Aug 21, 2017 7:49 am Test with:
I insist:
click :arrow: Image
:( Does not accept new coding
Posted: Wed Aug 23, 2017 7:58 am
by ciclo
As expected. :|
Posted: Wed Aug 23, 2017 8:10 am
by ciclo
ag69 wrote: Wed Aug 23, 2017 7:15 am could you please explain how did you remove the older steering?
http://workshop-manuals.com/volkswagen/ ... lumn_trim/
http://workshop-manuals.com/volkswagen/ ... bag_unit/
viewtopic.php?f=10&t=42713#p466570
Similar to:
:arrow: https://www.drive2.ru/l/7125547/
Posted: Wed Aug 23, 2017 9:22 am
by ag69
Thanks Cialo.
I had seen some videos but they had different mechanism. Rather no so called "Technological plugs"
But this russian link is definitely useful.
Posted: Mon Aug 28, 2017 8:46 pm
by rdasadia
So most recently got complete GTI body kit upgrade including bumpers (front & back), side skirts, interior "black" panels, etc
However require help for below two retrofits.
1) Sun visors with vanity light
2) front bumpers are with headlight washer space.
1) For sun visors tried to search for retrofit details but couldn't find any. Would like to know part no. of the light which is fixed on the roof and wiring details of this light and connector coming out of the visors.
2) for the headlight washer retrofit from the past posts got the below parta details which needs to be procured.
- 6R0 955 978 nozzles. ( Can someone advise where they can be procured from)
- wire harness (https://www.kufatec.de/shop/en/Volkswag ... VW-Polo-6R)
However could not gather from where to find the pumps(does it use the same pump that of windshield washer), and the hoses and connection diagram.
Posted: Mon Aug 28, 2017 9:14 pm
by iichel
There is a thread for headlight washer retrofit somewhere (or maybe 6R bi xenon retrofit). There is a list of parts, including the washer system.
I'm not aware of any retrofit kit or topic but it shouldn't be too difficult to make a wiring set for the new roof lining.
