Franciswat's Polo 6R 1.6 Bifuel
Franciswat
Drives: 6R 1.6 Bifuel
Re: My polo 6r bifuel
Post by Franciswat »
Thank you mate i really appreciate your interest. :!:
Do not worry aboout It :roll:
Ciclo May i asked if you still sell installation instruction?
Installation instructions are free for everyone.
Franciswat
Are those the One you posted in previous page ? :wink:
Franciswat
Allright thank you Ciclo. :roll: I Will try to remove terminals from bcm connectors and re-make wirings. :wink:
Remember to do this when you install the new BCM.
viewtopic.php?f=56&t=70398&start=45#p526658
Everything that is written there. :)
ciclo wrote: Fri Nov 10, 2017 12:39 pm :arrow: viewtopic.php?f=56&t=70398#p525089
7H0 ...... T73b/1
7E0 ...... T73b/4
Franciswat
Got It thank you Ciclo. :wink:
Franciswat
Hi Ciclo, I apologize but I looked a lot of times this image and I am still unsure about wirings. :roll:
I painted a wiring diagram, can you please tell me If It's wrong or correct? Thank you mate :wink:
That's right! :wink:
Franciswat
Thank you Ciclo for confirmation. :wink:
I noticed "A" and "B" letters behind fusebox.
So I suppose B pins are in the middle and A pins are on the sides.
(a part from looking wiring colours to distinguish wires)
I used with a tester (- on ground = car key) and + on pin terminals.
---> with fused removed, engine and lights on i detected current on pins 34a, 39a, 59a and no current on pins 34b, 39b, 59b.
Is that correct? :roll:
As you can see I'm not so good as electrician and I am trying to improve.
Thanks for patience! :wink:
Have a good sunday!
Logic:
The 6R fuse box has its tricks, but with the following image everything should be clear to you:
Why A and B (INPUT/OUTPUT) marked in white in the link image above depends on the color of the cables in fuse slots that do not have a supply from an internal bar?
Because there are multiple configurations in the same option (equipment) in the different 6R model/range. (trendline, comfortline, advance, highline, etc... e.g in UK they are named S, SE, etc...)
On the other hand the colors of the wires also depend on the Year in which the car was manufactured (Model Year).
It is necessary to have the diagrams of your 6R model and its year of manufacture to determine the wire colors and thickness.
Everything has an excellent logic, a perfectly ordered chaos. :lol:
so,
Franciswat
Thank you for explanation Ciclo :wink:
That explain why some wires have different colours from the one elsa shows.
Therefore in order to identify input/output is safer to use a tester, right? :roll:
input ---> wire with current
output ---> wire with no current
(—) ground
(+) wire
Yes, a multimeter will help you a lot.
Franciswat
Hi guys anyone know if original front/rear bumper of r-line fits standard polo? Thanks :wink:
Ps sorry Ciclo i still did not have time to try reinstall bcm. :( university is taking all my free time to study..
