Retrofit golf mk7 steering wheel on polo mk5
Re: Retrofit golf mk7 steering wheel on polo mk5
firebulletz wrote: Thu Mar 22, 2018 10:52 am It is possible that the airbag is not compatible? Or that i have to take +12v and LIN signals from other pins?
NO.
As you can see, the airbag and MFSW unit (BCM - Subsystem 3) are recognized in the autoscan (no faults).
The auto scan shown is incomplete.
Where are?
56-Radio -- Status: Cannot be reached 1100
56 and 19 issues are related.
Test, ...with old radio installed/plugged, disconnect/re-connect the battery and do the same checks.
Maybe the new big radio and its connections generated a chaos in your BCM.
We are giving a lot of thought to something that should be absolutely simple... 'something weird is happening here'.
firebulletz
Drives: Polo comfortline 1.6 tdi 90cv
Post by firebulletz »
NO.
Where are?
I have rcd310 but i need the "code safe 2". It there is not on radio manual
Inviato dal mio SM-G935F utilizzando Tapatalk
Ask for it at your VW dealer.
firebulletz
ciclo wrote:Ask for it at your VW dealer.
I tried with another not original radio and the buttons work, but not work the IC buttons
Solved!! :lol:
You need an IC with MFA+ for the MFSW IC buttons.
firebulletz
ciclo wrote:Image
Solved!! [emoji38]
The problem is the radio. I don't know how set on the steerung wheel buttons
Ok ...i will buy skoda fabia II IC [emoji16][emoji16]
I wonder why everyone has the tendency to install parts that are not exactly the ones that correspond. :lol:
In the sales section of the forum there is or had an VW IC for 6R/Amarok Diesel with some of the best technical assistance for its installation.
firebulletz
ciclo wrote:I wonder why everyone has the tendency to install parts that are not exactly the ones that correspond. [emoji38]
I can install fabia IC with blue VW needles... Polo or amarok diesel IC with Km/h are not easy to find.
I have resolved the problem, i have finded the correct option [emoji7][emoji7]
Thank you so much ciclo, really.
That is fantastic!!! 8)
Please, please, please, show us a video with your big radio working.
Thanks to you.
firebulletz
ciclo wrote:That is fantastic!!! 8)
Thanks to you.
there is another small problem, the lighting of the buttons hahaha
can i add a cable directly on the buttons or another way to illuminate them without changing bcm?
I'll be doing a video tonight with the radio in operation[emoji16]
firebulletz
Here the video of radio [emoji16]
Awesome!!! BIG thanks.
From now, we've to get a completely clean autoscan from your 6R, without any faults. You'll have my assistance for it here in this topic.
You must install the BCM High that I told you before (6R0937087AD) so that everything fits correctly and you have backlit steering wheel buttons. It's something rare that you do not find one at a reasonable price, considering that it is not a BCM Max. (i'll help you with this)
With this new BCM High you don't need additional wiring and you will save time and money trying to do weird things.
Its installation is very simple, only need the VCDS.
firebulletz
ciclo wrote:Awesome!!! BIG thanks.
You must install the BCM High that I told you before so that everything fits correctly and you have backlit steering wheel buttons. It's something rare that you do not find one at a reasonable price, considering that it is not a BCM Max. (i'll help you with this)
The price of bcm high is 150€ with shipping.
The problem is that if i will want to install automatic lights in future it will not be possible, and i will have to change the bcm again.
Installing bcm high i will have the possibility to install some extra optional or it is the same as mine but with updated software?
Do a better search, there are High ones for half the price that you say. 70-80€ (2017).
Avito.ru
But if you are going to install a BCM Max in the future don't buy the BCM High and wait until then.
firebulletz
ciclo wrote:Do a better search, there are High ones for half the price that you say. 70-80€ (2017).
Avito.ru
One seller told me that the 6r0937087ad has all the options except bi-xenon. if it were so it would be perfect.
I attach photo of 6r0...AD if it is good i will buy it for 100€ with shipping
