Inviato dal mio SM-G950F utilizzando Tapatalk
DJ's Polo 6R
claudio-dj
- Drives: Polo 6R - 1,6 TDI - Highline
Re: DJ's Polo 6R
Wow
Re: DJ's Polo 6R
best looms in the world. best instructions you can get. nothing can go wrong. you got this
claudio-dj
Re: DJ's Polo 6R
The bcm max is arrived...thank you firegrafik!!! waiting for the wiring! [emoji38][emoji38]
claudio-dj
Re: DJ's Polo 6R
as always our ciclo is different in quality, professionalism and big heart ... thanks for the wiring and now we move on to the most demanding phase ... help meeeeee [emoji23]
Re: DJ's Polo 6R
Many thanks Claudio.
Intallation Guide
viewtopic.php?f=56&t=71076&start=45#p532970
Sorry for the size and color of the following words.
Please Claudio,
- Do not use the smartphone to see, get, read, understand the installation guide.
Use the personal computer or the laptop.
- Do not use translators, please read in English.
My English can be understood by anyone.
The smartphone is a tool with very poor conditions to build or create.
I have a great experience with other people and other electrical installations.
In all cases, the problem of lack of understanding of installation guides was due to the "...." smartphone.
Intallation Guide
Please Claudio,
Re: DJ's Polo 6R
Route the wires along the sides of the BCM support. As simple as that.
Do not do this installation if you are not absolutely sure beforehand how to do this installation.
claudio-dj
Re: DJ's Polo 6R
sisi, for the guides I always use the pc ... for the English I hope I can understand everything [emoji28][emoji28]
Re: DJ's Polo 6R
Codings
Because I do not know the day that you'll finish the installation of the new wiring looms, I leave you here the new codings for your 6R.
They should only be introduced once you have installed my wiring for BCM adaptation (with foglights wires included) + my wiring for automatic lights + the new 7E0 BCM + Bixenon headlights.
NEVER enter the new codings before the installation is complete.
These are the new codings for your RLS and your new 7E0 BCM.
RLS
New coding
06302D
BCM (Bixenon, autolights, new 7E0 BCM)
New coding
3CB02BBF48F32F00933807C17CEB0ED15A8867FF60053041200000030000
When you post a new autoscan with everything installed I'll provide you with more links to adapt some lights in case it's your wish.
At your disposal for anything you need.
RLS
New coding
06302D
New coding
claudio-dj
Re: DJ's Polo 6R
even the last piece has arrived ... finally! [emoji16]
claudio-dj
Re: DJ's Polo 6R
First step
Re: DJ's Polo 6R
In response to your email:
http://wiki.ross-tech.com/wiki/index.ph ... l_Matching
(I copy the text from the link and paste here)
Channel 001: Remote Control Matching
Start Matching new/additional Remote Controls by entering 0, then Test and Save the New Value.
Press and hold the Unlock button for at least one second on the Remote Control you want to add, the Blinkers will light up to confirm the Adaptation Process of each Remote Control.
So...
1st remote control ..... 01 Channel .... 0 ... test ... save ... process
2nd remote control ..... 01 Channel .... 0 ... test ... save ... process
and so on... 3rd, 4th, etc, remote controls.
So...
Re: DJ's Polo 6R
Well, your VCDS is very old, but you do not need any description or adaptation list.
You can go to the adaptation channels directly and change the values as indicated.
claudio-dj
Re: DJ's Polo 6R
I followed this procedure, but it only works on opening doors, opening the trunk. but the closure does not work. instead for the other problems I listed you?
moreover, when I go to bcm coding all the bits come out without description.
Re: DJ's Polo 6R
In the autoscan that you send me by email:
You have two problems:
1- Your VCDS is old to detect some units at 100%.... 'no problem', Bits descriptions on the BCM label are not necessary, I know them all.
-Bits can be modified by Binary or Hexadecimal.
-My recommendation is that you update your VCDS cable.
2- You have not correctly installed your Bixenon Headlights adaptation wiring, nor have you made the basic setting and coding of AFS unit for Bixenon headlights.
Post the autoscan here if you want me to help you with the Bixenon headlights installation. As you already know, this is a part that does not correspond to me, but I will help you install them correctly (here in the forum).
According the autoscan, my wiring and my coding are correct, this is a part that you should not worry about anymore.
Re: DJ's Polo 6R
Repeat the process. (correctly, as indicated... )claudio-dj wrote: Sun Sep 02, 2018 6:02 pm I followed this procedure, but it only works on opening doors, opening the trunk. but the closure does not work. instead for the other problems I listed you?
Many have had this same problem before (something was not done correctly).
Your VCDS is very old, but it's not related to the above.claudio-dj wrote: Sun Sep 02, 2018 6:02 pm moreover, when I go to bcm coding all the bits come out without description.
