Giannis20vt's Polo 6c 1.0MPI
Re: Giannis20vt's Polo 6c 1.0MPI
Use ODIS to install and adapt the BCM
2fast4ya
Drives: polo 1.8 tsi gti bluetec
Post by 2fast4ya »
giannis20vt
Post by giannis20vt »
iichel wrote: Thu Dec 08, 2022 2:12 pm Use ODIS to install and adapt the BCM
I am going to go to a garage with online connection with the VW servers for this job.
I am exciting for this but also i am afraid of failure, i have already tried 3 times to swap the BCM without any luck. The first 2 BCMs were used, the 3rd was "new" but it wasn't so new as the seller claimed.
giannis20vt
And suddenly a strange problem. I want your help.
First the right turn signal started working all the time by itself. It stops only when i turn the ignition off.
The left turn signal working fine, as it is suppose to work, but the right doesn't stop at all. The hazard switch working fine also.
I checked all the bulbs and the fuses.
And after an hour trying to find any solution, the car doesn't start. It's not a battery problem, i checked it, even try to start it with wires from another car. Nothing.
I took a message on the screen "Press clutch to start" but i am pressing the clutch.
I unplugged the car battery for half an hour, nothing. I unplugged the BCM still nothing. I am at dead end. Any suggestion, would be appreciated
is this problem out of nowhere or after a bcm swap?
giannis20vt
iichel wrote: Mon Dec 12, 2022 9:22 pm is this problem out of nowhere or after a bcm swap?
I didn't do anything with the car, apart from some wiring between the roof and the fuse box. I am preparing for the Rain/light sensor installation.
Today i will connect the VCDS to scan for errors.
giannis20vt
Lots of errors, it's like nothing is working.
I don't know what to say.
I am thinking of towing the car to a garage for further diagnosis and repair.
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: WVWZZZ6RZGY308378   Mileage: 64776km-40249miles
15-Airbags -- Status: Cannot be reached 0100
Address 01: Engine (J623-CHYB)       Labels:. 04C-906-020-CHY.clb
   Part No SW: 04C 906 057 AB    HW: 04E 907 309 CB
   Component: R3 1.0l MPI   H20 2496
   Revision: 33H20000
   Coding: 01110012020400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM10MPI01104C906057AB 001002
   ROD: EV_ECM10MPI01104C906057AB.rod
   VCID: 65C104936461CFA350-8030
3 Faults Found:
5273 - Output for Starter Relay
          P0616 00 [167] - Short to Ground
          MIL ON - Not Confirmed - Tested Since Memory Clear
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 64776 km
                    Date: 2022.12.12
                    Time: 21:54:11
                    Engine RPM: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 12 °C
                    Intake air temperature: 12 °C
                    Ambient air pressure: 990 mbar
                    Voltage terminal 30: 11.049 V
                    Starter control: terminal 50 feedback-Bits 0-7: 0
                    Number of manual engine starts-Bits 0-7: 0
                    Number of automatic engine starts-Bits 0-7: 0
5459 - Control Circuit for Starter Relay 2
          P3048 00 [167] - Short to Ground
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 64776 km
                    Date: 2022.12.12
                    Time: 21:54:11
4710 - No Communications with Airbag Control Module
          U0151 00 [039] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 64776 km
                    Date: 2022.12.12
                    Time: 21:54:10
                    CAN status - engine control module-Bits 0-7: 0
                    selected gear-Bits 0-7: 0
Readiness: 1110 0001
   Part No SW: 6C0 907 379 K    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0004
   Serial number: 08512057160424
   Coding: 21DD2485492333C8091700700059842492CC90000005C9098F00
   Shop #: WSC 49716 005 1048576
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
   VCID: 377D9EDB8E4D8D3332-8062
2 Faults Found:
0922 - No Communications with Airbag Control Module
          U0151 00 [009] - -
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 216
                    Mileage: 64776 km
                    Date: 2022.12.12
                    Time: 21:59:24
1171 - Multiple collision brake
          B13BC F2 [009] - No function
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 216
                    Mileage: 64776 km
                    Date: 2022.12.12
                    Time: 21:59:24
Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
   Part No SW: 6C0 820 045 C    HW: 6C0 820 045 C
   Component: AC Manuell    H03 0202
   Serial number:  1605161B-0418
   Coding: 200000000000100000
   ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
   ROD: EV_ACManueKMMValeoPQ26.rod
   VCID: 1F4D567B06BDD573DA-804A
4 Faults Found:
262916 - High Pressure Sensor
          B10AE 14 [013] - Open or Short to Ground
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 216
                    Mileage: 64776 km
                    Date: 2022.12.12
                    Time: 21:55:03
262917 - High Pressure Sensor
          B10AE 29 [013] - Signal Implausible
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 216
                    Mileage: 64776 km
                    Date: 2022.12.12
                    Time: 21:55:03
459009 - Databus
          U1121 00 [013] - Missing Message
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 216
                    Mileage: 64776 km
                    Date: 2022.12.12
                    Time: 21:55:03
1114115 - Fan 2 Control Circuit
          P0693 00 [013] - Short to GND
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 216
                    Mileage: 64776 km
                    Date: 2022.12.12
                    Time: 21:55:08
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 6C0 937 087 C    HW: 6C0 937 087
   Component: BCM PQ26 Me4R H08 0087
   Serial number: 006088052444
   Coding: 000008404053005B4F844000400703000000580051010000000000000000
   Shop #: WSC 131071 1023 2097151
   ASAM Dataset: EV_BCMA0 005005
   ROD: EV_BCMA0_005.rod
   VCID: 2E53BBBF71174CFB61-807A
   Driver door control module:
   Subsystem 1 - Part No SW: 6R0 959 801 DG    HW: 6R0 959 801 DG  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 0610
   Serial number: KU0KU012051661335260
   Coding: 0000A0
   Front passenger door control module:
   Subsystem 2 - Part No SW: 6R0 959 802 DL    HW: 6R0 959 802 DL  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 0610
   Serial number: KU0KU030041661212448
   Coding: 1000A0
   Rear Driver Side Door Control Module:
   Subsystem 3 - Part No SW: 6R0 959 811 AA    HW: 6R0 959 811 AA
   Component: J388__TSG_HL  003 0610
   Serial number: KU0KU028041661198823
   Coding: 0000A0
   Rear Passenger Door Control Module:
   Subsystem 4 - Part No SW: 6R0 959 812 AA    HW: 6R0 959 812 AA
   Component: J389__TSG_HR  003 0610
   Serial number: KU0KU002051661233279
   Coding: 1000A0
3 Faults Found:
227080 - Turn Signal Switch
          B1144 29 [009] - Signal Implausible
                    Fault Priority: 2
                    Fault Frequency: 4
                    Mileage: 64776 km
                    Date: 2022.12.12
                    Time: 21:56:25
528405 - Databus
          U1121 00 [009] - Missing Message
                    Fault Priority: 4
                    Fault Frequency: 4
                    Reset counter: 216
                    Mileage: 64776 km
                    Date: 2022.12.12
                    Time: 21:56:25
558101 - Databus
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 216
                    Mileage: 64776 km
                    Date: 2022.12.12
                    Time: 21:56:25
Address 15: Airbags
Cannot be reached
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 6C0 920 740 C    HW: 6C0 920 740 C
   Component: KOMBI         201 1420
   Coding: 0724090021000008110828000000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009046
   ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
   VCID: 224B5F8F35CFF89BF5-8076
3 Faults Found:
13697024 - Component Protection
          U1100 00 [009] - No Basic Setting
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 195
                    Mileage: 63548 km
                    Date: 2022.01.14
                    Time: 00:07:17
16776962 - Databus
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 216
                    Mileage: 64776 km
                    Date: 2022.12.12
                    Time: 21:58:26
9603840 - Incorrect Key Programming for Remote Control
          B128B 00 [009] - -
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 26
                    Mileage: 63548 km
                    Date: 2022.01.14
                    Time: 17:45:46
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 087
   Component: GW MQB A0     H08 0087
   Revision: --------    Serial number: 006088052444
   Coding: 01000008200A640071000000000000000001010000000000000000000000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_013_VW26.rod
1 Fault Found:
131605 - No Communications with Airbag Control Module
          U0151 00 [009] - -
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 216
                    Mileage: 64776 km
                    Date: 2022.12.12
                    Time: 21:56:52
                    Terminal 30 power supply: 11.2 V
                    Terminal 15: On
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C1 909 144 AG    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  312 3232
   Serial number: PG5Q1139
   Coding: 000700
   ASAM Dataset: EV_SteerAssisUDSTRW 016026
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 6DD17CB3BC91F7E318-8038
9 Faults Found:
1072128 - Databus
          U1121 00 [008] - Missing Message
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 1
                    Engine RPM: 0 /min
                    Vehicle speed: 0.00 km/h
                    System status: Waiting for start request
                    Terminal 15 status: Terminal 15 on
                    Voltage terminal 30: 10.71 V
                    Power steering current consumption: 0.50 A
                    max.value: 0.50 A
                    End stage temperature: 21 °C
                    Steering assistance: engine output: 0.00 %
                    Engine angle: 0 °
                    Electric motor speed: 0 /min
                    Steering assistance: target engine torque: 0.00 Nm
                    Steering torque: 0.08 Nm
                    Status: OK
1065472 - Databus
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 1
                    Engine RPM: 0 /min
                    Voltage terminal 30: 11.09 V
                    max.value: 0.50 A
                    Engine angle: 0 °
                    Status: OK
1066752 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 64772 km
                    Date: 2022.12.11
                    Time: 00:16:31
                    Engine RPM: 153 /min
                    Vehicle speed: 19.88 km/h
                    System status: Driving mode
                    Voltage terminal 30: 8.54 V
                    max.value: 24.82 A
                    End stage temperature: 30 °C
                    Steering assistance: engine output: 0.95 %
                    Engine angle: 158 °
                    Electric motor speed: 7 /min
                    Steering torque: 0.27 Nm
                    Status: OK
1068288 - Databus
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 1
                    Engine RPM: 0 /min
                    Voltage terminal 30: 11.29 V
                    max.value: 0.50 A
                    Engine angle: 0 °
                    Steering torque: 0.11 Nm
                    Status: OK
1068800 - Databus
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 1
                    Engine RPM: 0 /min
                    max.value: 0.50 A
                    Engine angle: 0 °
                    Status: OK
1070336 - Databus
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 1
                    Engine RPM: 0 /min
                    Voltage terminal 30: 11.32 V
                    max.value: 0.50 A
                    Engine angle: 0 °
                    Status: OK
1069568 - Databus
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 1
                    Engine RPM: 0 /min
                    max.value: 0.50 A
                    Engine angle: 0 °
                    Status: OK
1048832 - Databus
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 216
                    Date: 2000.00.00
                    Time: 00:00:00
                    Engine RPM: 0 /min
                    Voltage terminal 30: 12.00 V
                    max.value: 0.50 A
                    End stage temperature: 17 °C
                    Engine angle: 0 °
                    Steering torque: -0.02 Nm
                    Status: OK
1052160 - Databus
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 1
                    Engine RPM: 0 /min
                    max.value: 0.50 A
                    Engine angle: 0 °
                    Status: OK
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
   Part No SW: 6C0 035 888 B    HW: 6C0 035 888 B
   Component: MU-E--ER      851 6490
   Serial number: 19041600012060
   Coding: 026200003C00000041110001010000001F0000840000010001
   ASAM Dataset: EV_MUEnt4CGen2LGE 001025
   ROD: EV_MUEnt4CGen2LGE_VW26.rod
   VCID: 2B55B2AB420539D346-807E
1 Fault Found:
6697 - Databus
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 216
                    Mileage: 64776 km
                    Date: 2022.12.12
                    Time: 22:01:51
                    Voltage terminal 30: 11.0 V
                    Network diagnosis-Status: Enabled
End-------------------------(Elapsed Time: 02:15)--------------------------
looks like a ground point in your interior wiring harness is having a bad time. but that's a very rough guess!
giannis20vt
iichel wrote: Tue Dec 13, 2022 8:06 pm looks like a ground point in your interior wiring harness is having a bad time. but that's a very rough guess!
It's a thought that i have done, but it is very difficult to search it.
Yes, I agree it's not easy. Here I'm seeing an increase in failures of electrical components due to water/corrosion because of cold weather and bad batteries.
I would start with a certain error like a starter relay and measure all wires to it. Or find a common denominator in the wiring schemes like a relay, ground point, fuse, etc.
giannis20vt
I am reading the faults and i feel very sad.
To much error codes, so much different issues. I really hope this ends easily without many changes and big costs.
Today I am going to tow the car to a garage for further diagnosis and repair.
I understand, this is a complex case. But I think you can get a good start with simply a wiring diagram and a multimeter. You can very easily reach the E box in the engine bay, for example, where the starter relays are.
giannis20vt
giannis20vt
Update for those problems.
1rst problem: broken stalks (turn signal switch). It gives signal for the right turn light all the time. :(
2nd problem. 2 broken fuses (i checked all the fuses without removing all of them). Maybe i didn't check them right or i took a false measurement. :shock:
3rd problem. I remove a couple of fuses from the fusebox to check the operation of their circuit, but i didn't put them to the right place :oops:
On the garage the electrician guy found the problem in 15 minutes. I was sure for the faulty stalks because i test them with my original ones.
So final the car is running again without any problem until now.
Make a picture of your fusebox next time before you work on it.
