Skoda Rapid BCM Max Adaptation. 6R093708P upgrade 7h0937090d BUT!
omerkartal
Drives: Skoda Rapid & VW Tiguan 5N
Re: Skoda Rapid BCM Max Adaptation. 6R093708P upgrade 7h0937090d BUT!
Post by omerkartal »
I tried it and now it doesn't work. Coming home. I uploaded the log you wanted to Google Drive.
Thanks for the BCM adaptation channels. All OK.
What is not working "now"?
I need you to explain it more clearly...
Have you done a new Autoscan with the new BCM coding?
omerkartal
Did you watch the video on Google Drive High Beam.mp4? The long lights are not on permanently. I couldn't do a full scan, I will do it tomorrow.
Yes, of course I saw the video where the high beams don't work when pushing the lever. Thanks for the video, it's clear. 👍
What I didn't understand is that in your previous post you used the expression 'Now' if the Coming Home function 'Never' worked.
'Now' I understand what you meant since you 'still' haven't done the new Autoscan with the new BCM coding (tomorrow) to check the high beams in ALL positions of the light switch, ... concluding that you were referring to the CH function doesn't work.
In the world of assumptions (helped by the old/yesterday google drive BCM Max Autoscan), I imagine that if you don't have complaints about the operation of other lights, it's because they work as expected, such as for example the Automatic lights...?
In advance.
The fact that the Coming Home function and the High Beams don't work is a possible indication that something is happening with the new wire that goes from SB36a to T73a/62, which should have been installed according to my installation guide for BCM Max adaptation (pg 3 here).
Check that this new wire is installed correctly with a multimeter (continuity).
For example, remove the BCM connector T73A and use a contact pin terminal to insert it into the T73a/62 position, then check the continuity between this test terminal and SB36a. Easy.
First/Before, don't forget to do the new Autoscan with the new BCM coding (test it and inform me), it is important!
atifzafrak
Drives: Skoda
Post by atifzafrak »
omerkartal wrote: Tue Dec 17, 2024 5:07 am Good morning Fernando. I noticed it yesterday when I stopped by the car. When I want to turn the high beams on steadily, they don't come on. When I pull the signal lever forward, it stays on for a long time, when I let it go, it goes off. When I push it back, it doesn't stay on steadily.
I'm experiencing the same issue :)) My car is a 2015 Skoda Rapid. It has the factory-installed PQ25 BCM.
Edited by ciclo:
Please open a new thread with your concerns.
Thank you.
omerkartal
Hello Fernando. I added the autoscan logs with the new long coding to google drive.
Ok, seen.
Have you noticed any change in the behavior of the high beams in all positions of the light switch when pushing the HB lever?
Your comments on this are needed.
omerkartal
Everything works as it should. There is nothing abnormal.
That is, the high beams work correctly in all positions of the light switch, right?
atifzafrak
Drives: Skoda
ciclo wrote: Sat Dec 21, 2024 8:49 am Ok, seen.
I shared an old auto scan in the message I wrote above.
Below I am sharing the current auto scan. 1 before cleaning the errors, the other after cleaning the errors.
https://drive.google.com/drive/folders/ ... sp=sharing
If you have any additional information you may need to know, I would be happy to answer your questions.
omerkartal
ciclo wrote: Sat Dec 21, 2024 9:26 am That is, the high beams work correctly in all positions of the light switch, right?
yes it works fine
So the last BCM coding I did fixed the HB issue, right?
Or did you make any repairs to the wiring?
Please, when possible post here the full Autoscan (Clear All DTCs).
atifzafrak wrote: Sat Dec 21, 2024 9:28 am
Thank you.
atifzafrak
Drives: Skoda
ciclo wrote: Sat Dec 21, 2024 10:08 am
Thank you.
I'm having the same problem. Is it necessary to open a new topic for this? I didn't want to clutter the forum by opening another topic about the same thing.
omerkartal
HB is already working. When I pull it forward, HB lights up, but when I push it back, it doesn't light up steadily.
