UK-POLOS.NET - THE VW Polo Forum • 6R Cruise Control Retrofit Problems - Page 41
Page 41 of 41
Posted: Sun Apr 19, 2026 10:32 pm
by prutt
hi, im having some problems when coding the 01 module. i dont know what bit to change, i dont get a explanation.
i dont have vcds, im running obd11 so dont know its possible to get it right..
01 Engine
System description: CGGB MM4HV
Software number: 03C906024BJ
Software version: 8997
Hardware number: 03C906024BH
Hardware version: 000
the code im running: 03158851
this is all info im geting from obd11. might have to switch to vcds :roll:
Posted: Mon Apr 20, 2026 6:50 am
by ciclo
This is the most common coding for CGGB:
1
Address 01: Engine Labels: 03C-906-024-BXW.lbl
Part No SW: 03C 906 024 CN HW: 03C 906 024 BH
Component: CGGB MM4HV G 8994
Revision: --H09--- Serial number:
Coding: 0000071
Shop #: WSC 00788 648 00255
VCID: 6CD1B4F24CFC9D7E575-5072
Readiness: 0000 0000
2
Part No SW: 03C 906 024 BH HW: 03C 906 024 BH
Component: CGGB MM4HV G 8327
Coding: 0000071
Shop #: WSC 00445 210 70264
VCID: 65C1EB5BAF9D8F16F8-515E
Or perhaps this is the procedure:
Go to / click on "Login - 11" or "Coding II".
Enter the activation code: 11463. 'Do it' to save.
The letter G will then appear in the component's readout.
Posted: Mon Apr 20, 2026 1:44 pm
by prutt
that’s short code. Mine is long code unfortunately.
Posted: Mon Apr 20, 2026 6:24 pm
by ciclo
It's a second login/code. Try it!
(clearer image if you're using the stupidphone)
Good Luck!
