ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP. 🧙‍♂️
Locked
Re: ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP. First and Last pages UPDATED !!!
Golf 7.5 New Rotary Light Switch with a cute symbol. 🌧😁
The lights work the same way as the old Rotary light switch, except that with this new Rotary light switch you cannot activate the front and rear fog lights from the parking light position, which is a legal condition (where I live 🤭).
Doing some research on the internet in order to expand my knowledge, I find the following ways in which the lights that were previously the front fog lights are called:
- All weather lights.
- Poor weather lights.
- Bad weather lights.
... what a disaster!
Something that may be bad/poor weather for you may be a wonderful weather for me. Please, try not to parameterize my brain with what is considered habitual/normal or standardized, thanks! ... 😁
The lighting point/s of these 'All Weather Lights' are depending on the type of Headlight and its components (bulbs or LED/s).
Example: :arrow: https://www.youtube.com/watch?v=Fk_TDNwZUrQ&t=87s
Due to a huge lack of information, I don't know if my 8IU LED headlights will be able to handle these 'All weather lights'.
Could it be through the Static Cornering lights on my 8IU headlights?
As you know, my wife's golf has front fog lights, and also 'Plus' static cornering lights (on both 8IU headlights and front fog lights). viewtopic.php?p=582843#p582843
So I code to know what happens:
09 Adaptation (SA 31347):
[LO]_Allwetterlicht:	[VN]_installed
4B coding:
[LN]_all_weather_light:	[VN]_enabled
+ 4B Basic Settting
I suppose one day I should show the status of all the adaptation channels of my BCM, but it is something that anyone can know if they read this whole thread. :mrgreen:
:arrow: viewtopic.php?p=580473#p580473
Now, where I live, temperatures between 39ºC and 45ºC are reached daily, so I don't know if the All-weather lights would work properly.
I'll go thinking of finding some enlightening cloud:
... though I settle with the nice/cute new symbol on the NEW Rotary Light Switch. :lol:
Finaly and after some tests, in the BCM Adaptation I do not configure the static cornering lights that are included in my Matrix 8IU headlights as All-weather lights because I like their operation better as predictive static cornering lights, and because my Golf 7.5 already have front fog lights, that they also have the static cornering lights function.
But the main reason to not activate them is that the dedicated LEDs can reach high operating temperatures inside the headlights, which will be reflected in the diagnosis and the BCM will limit its operation when they are active for long periods of time.
I think having front fog lights with static cornering lights function, predictive static cornering lights in the Matrix 8IU headlights, Dynamic Cornering Lights (low and high) and Dynamic Light Assist with multiple functions is more than enough to guide my way/path with complete clarity.
https://www.youtube.com/watch?v=j2qAu7ulFe0
Golf 7.5 Fixation of 2Q0 rear radars on supports/brackets for 5Q0 rear radars.
Another way to hold the new 2Q0 radars.
💎💎💎Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/FqJu58tMB ... autoplay=1
I used aluminum rivet nuts applying just the right amount of force with the tool, and after tests in the fridge-freezer (-18ºC) the fixing seems to be extraordinarily perfect.😊
Lane change. From 5q0 to 2q0 radars.
Pin reassignment in connectors:
-Remove Battery ground.
SG1 Master (686), Right side connector.
-4 to 1 (CAN Extended Low, GW)
-3 to 2 (CAN Extended High, GW)
-7 to 3 (CAN Low, radars)
-6 to 4 (CAN High, radars)
-5 to 5 (Ground)
-Extract 3 from left side connector,
splice new wire to 3 ,isolate ,
and run this new wire to 6 right side connector. (W lamp in right ext mirror)
-8 to 8 (+15)
SG2 Slave (685), Left side connector.
-7 to 1 (CAN Low, radars)
-6 to 2 (CAN High, radars)
-5 to 5 (Ground)
-4 to 6 (W lamp in left ext mirror)
-8 to 8 (+15)
Notes:
- From 5Q0 radars Golf 7.5 to 2Q0 radars TRoc/Tiguan/Passat/...
- In the diagrams for 5Q0 radars Golf 7.5 'Variant' the pin assignment
 for CAN lines between radars is swapped. No problem with that, a wire is a wire. )))
https://www.youtube.com/watch?v=szRJia_lXn4
Later, when I install them, I'll wrestle with the datasets.
https://www.youtube.com/watch?v=03f8gEm ... VfKg&t=62s
Golf 7.5 Door units update from N to P.
Previous info: :arrow: viewtopic.php?p=591740#p591740
Before this new update, I flashed the Original door units from F to K to N and finally to P, and checked with the Golf 7.5 2021 N-datasets on my test bench.
F must be flashed to K, N or P to support these datasets as valid.
Flashing N to P door units in the car:
Same with driver's door unit.
The P version is Perfect!! Better than any other.🧙‍♂️
Friday,29,July,2022,10:32:21:32438
VCDS Version: 22.3.1.4 (x64)  HEX-V2 CB: 0.4615.4
Data version: 20220407 DS337.0
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: DOOR MODULES N FLASHED TO "P" = PERFECT!!! )))
Mileage: 47230km-29347mi   Repair Order: GOLF 7.5 DATASETS
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 29 39 3C 42 44 4B 52 5F 65 6C A5
          A9 BB BC D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 47230km-29347miles
29-Left Light -- Status: OK 0000
39-Right Light -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DKRF)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 025 L    HW: 04C 907 309 BB
   Component: R3 1.0l TFS   H20 6198
   Revision: D7H20000    CVN: 92B19492
   Coding: 01190032234415082000
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_ECM10TFS01104C906025L 002003
   ROD: EV_ECM10TFS01104C906025L_002.rod
   VCID: 290F00D8897EC923B81-807C
   VINID: 9E69EAAAA465A9B8000041051C011774D2
Readiness: 0110 0001
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 DD    HW: 5Q0 614 517 AC
   Component: ESC           H25 0424
   Revision: 00000000    Serial number: 51998000000173
   Coding: 01FA6AA114202170477B060560CA2580562884E26006A4733420F00A40AA430B00000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 76B51BA40840D6DBE53-8022
Address 08: Auto HVAC (E87)       Labels:| 5G0-907-044.clb
   Part No SW: 5NA 907 044 AJ    HW: 5NA 907 044 AJ
   Component: AC Automat    H50 1301
   Revision: 20K03000    Serial number: 00000A00202735
   Coding: 000200032001100D1115004C0018542A
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_ACTouchPrehVW37X 001010
   ROD: EV_ACTouchPrehVW37X_VW37.rod
   VCID: 074B66607FAADF538E5-8052
   Air quality sensor:
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 4H0 907 658 D    HW: 4H0 907 658 D
   Component: G935 MuFu  H05 0010
   Serial number: AAE88B8400PAG0MUFU05
Address 09: Cent. Elect. (J519)       Labels: None
   Part No SW: 5Q0 937 084 EC    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H40 0511
   Serial number: 72007150025702
   Coding: 000000000000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_BCMMQB 022001
   ROD: EV_BCMBOSCH_022_VW27.rod
   VCID: 7DA704882D768583A49-8028
   Wiper motor control module:
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS    180621  043 0551
   Serial number:         180705074106
   Coding: 0F4DFD
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  052 0107
   Serial number: S5Y20M05D14H05M53S24
   Coding: 06A8DD
   Anti-theft alarm system sensor:
   Subsystem 3 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY191251XZQ
   Alarm horn:
   Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Component: Sirene, DWA  005 0313
   Serial number: 00002854456462182207
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 507 GB    HW: 5Q1 953 549 F
   Component: J527 SMLS MQB  005 0080
   Serial number: 00000023032104400679
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5QA 919 298 K    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H07 0073
   Serial number: 000308417318277
   Coding: 8271567841
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_EPHVA2CAU3700000 009055
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 58E9751CE29480ABD7F-800C
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 S    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0780
   Coding: 2B0D7FE35DFFC728979F81A4614006800000000000B9C00024
   ASAM Dataset: EV_ACCBOSCHVW416 003015
   ROD: EV_ACCBOSCHVW416_003_VW37.rod
   VCID: 47CBA6603F2A1F534E5-8012
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    006 0339
   Serial number: 003VWR4F1CUQ
   Coding: 98CCC000000000005C0000CF000800000065
   Shop #: WSC 00028 028 00064
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
   ROD: EV_AirbaVW20SMEVW37X_VW37.rod
   VCID: 094F605869BEA923981-805C
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 5G0 980 945 B    HW: 5G0 980 945 B
   Component: BeltPretRevFL  H37 0350
   Serial number: 34169667E30071820325
   Coding: 333135
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 5G0 980 946 B    HW: 5G0 980 946 B
   Component: BeltPretRevFR  H37 0350
   Serial number: 34169668E31071830145
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 307 18
   Component: SideSensor_Df  001 0887
   Serial number: 35700000000F8745C23S
   Coding: 2D2D2D
   Subsystem 4 - Part No SW: -----------    HW: 480 002 807 18
   Component: SideSensor_Pf  001 0887
   Serial number: 358000000000EC18233G
   Coding: 2D2D2D
   Subsystem 5 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001A729FD154210-
   Coding: 2D2D2D
   Subsystem 6 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001A929FD1515577
   Coding: 2D2D2D
   Subsystem 7 - Part No SW: -----------    HW: 480 402 306 18
   Component: FrontSensor_D  003 6149
   Serial number: 3550001A326704A3C63.
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5G1 920 791 B    HW: 5G1 920 791 B
   Component: KOMBI         404 4191
   Coding: 07A532806E8C000801887A0F5401000080000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009058
   ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
   VCID: 2B03FAD08382DB334AD-807E
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AR    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5502
   Serial number: 09012020001767
   Coding: 030900047F085700FB0002FE080F00010001070000000000000000000000
   GVL: 014E3C100000000040CC80000002480000000000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF_VW37.rod
   VCID: 7F5BFE80277A9793B65-802A
   Generator:
   Component: 4-01-02-01-04
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 1EA 959 442 F    HW: 1EA 959 442 F
   Component: MFL  H50 0420
   Serial number: 17044958021162102894
   Coding: AE2B00
   Subsystem 3 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Component: J367-BDMHella  H10 9070
   Serial number: 9353818504
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   ASAM Dataset: EV_LCMLeftHELLAAU736 001012
   ROD: EV_LCMLeftHELLAAU736_VW37.rod
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   ASAM Dataset: EV_LCMRightHELLAAU736 001012
Address 3C: Lane Change (J1086)       Labels:| 5Q0-907-686.clb
   Component: HRE_Master    H12 0081
   Serial number: 0519386082
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D27C4886DF64583E49-8068
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 5Q0 907 685 C    HW: 5Q0 907 685 C
   Component: HRE_Slave  H12 0081
   Serial number: 0519601132
   Coding: 020111
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 P    HW: 5Q4 959 593 N
   Component: TSG FS        010 0912
   Serial number: 0000424549193
   Coding: 00150220D000048000001000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
   ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
   VCID: 52FD8734C468AAFB29B-8006
   Rear Driver Side Door Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000009798407
   Coding: 010000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1081
   Coding: 931F0000
   Shop #: WSC 12345 102 209715
   ASAM Dataset: EV_SteerAssisMQB 015157
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73B322B01B32C3F3C2D-8026
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0371
   Serial number: 01081930001280
   Coding: 00000005090016C200207F07620000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 003003
   ROD: EV_MultiModulContiVW48X_003.rod
   VCID: 372BD6A04FCA6FD33E5-8062
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 P    HW: 5Q4 959 592 N
   Component: TSG BFS       010 0912
   Serial number: 0000423867168
   Coding: 00150220DE00048000001000
   Shop #: WSC 00020 999 12345
   ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
   ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
   VCID: 51FF8838C16ED1E3101-8004
   Rear Passenger Door Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000009846262
   Coding: 090000
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    853 0879
   Serial number:
   Coding: 02731001FF0000004111010140880A231F0507E401200400CF
   ASAM Dataset: EV_MUStd4CDELP 001001
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 323DE7B4A4A88AFB09B-8066
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZHV2691212
   Data carrier:
   Subsystem 2 - Part No SW: 5NA 919 866 CA    HW: -----------
   Component: ECE AS 22/23  --- 1810
   Part No SW: 5Q0 907 273 F    HW: 5Q0 907 273
   Serial number: 30000000250801
   ASAM Dataset: EV_RDKBERU30 006001
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 3829D59C42D460AB37F-806C
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-980-556.clb
   Part No SW: 5Q0 980 556 B    HW: 5Q0 980 556 B
   Component: RVC Compact   H18 0231
   Coding: 01040201C600201F000060
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
   ROD: EV_CamSysRVRVCPANAMQBAB_006_VW37.rod
   VCID: 392FD09879DE79A3C81-806C
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
   Part No SW: 2Q0 980 653 C    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H16 1302
   Serial number: E80320004213340
   Coding: 0000018811CEC028889F2C801030004400438000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   ROD: EV_MFK3ValeoMQB_007_VW27.rod
   VCID: 3537DCA855C69DC32C9-8060
Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb
   Part No SW: 5F0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 Z001
   Serial number: 181027201414
   ASAM Dataset: EV_SoundActuaGen2AU64X 003010
   ROD: EV_SoundActuaGen2AU64X.rod
   VCID: 6A8D3FD44CF8023B71B-803E
Address BB: Door Rear Drv
Cannot be reached
Address BC: Door Rear Pass
Cannot be reached
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-572.clb
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-572.clb
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----------(Elapsed Time: 01:40, VBatt start/end: 12.8V/12.8V)-----------
https://www.youtube.com/shorts/qciWfVN-Cvo
Golf 7.5 Coming Home and Leaving Home also via reversing lights (RVC High -> CAN lines).
My dear friends, the white light will guide your way... 🧙‍♂️😁
Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/Zgm7VTvGS ... autoplay=1
- I did it with the 3rd brake light first (the usual mod), but that intense red color can hide colored snakes (Australian outback, Indonesian jungles, "De wallen"🤣).
- With RVC High, the VW logo flip-open for the reversing camera will not activate, allowing you to open the boot lid on demand.👌
Golf 7.5 CH/LH by reversing lights. RVC High.
09 Cent Elect  (SA 31347)
New value = ...
[VO]_Leuchte28RFL LC11:
[LO]_Lasttyp 28:	[VO]_43 - allgemeine LED
[LO]_Lampendefektbitposition 28:	B
[LO]_Fehlerort mittleres Byte DTC-DFCC 28:	31
[LO]_Lichtfunktion A 28:	[VO]_Rueckfahrlicht
[LO]_Lichtfunktion B 28:	[VO]_nicht aktiv
[LO]_Dimmwert AB 28:	127
[LO]_Lichtansteuerung HD AB 28:	[VO]_only_if_closed
[LO]_Lichtfunktion C 28:	[VO]_nicht aktiv
[LO]_Lichtfunktion D 28:	[VO]_nicht aktiv
[LO]_Dimmwert CD 28:	0
[LO]_Dimming Direction CD 28:	[VO]_maximize
[LO]_Lichtfunktion E 28:	[VO]_nicht aktiv ...  Coming Home oder Leaving Home aktiv
[LO]_Lichtfunktion F 28:	[VO]_nicht aktiv
[LO]_Dimmwert EF 28:	0                       ...  127
[LO]_Dimming Direction EF 28:	[VO]_maximize
[LO]_Lichtfunktion G 28:	[VO]_nicht aktiv
[LO]_Lichtfunktion H 28:	[VO]_nicht aktiv
[LO]_Dimmwert GH 28:	0
[LO]_Dimming Direction GH 28:	[VO]_maximize
[VO]_Leuchte29RFL RA64:
[LO]_Lasttyp 29:	[VO]_43 - allgemeine LED
[LO]_Lampendefektbitposition 29:	1B
[LO]_Fehlerort mittleres Byte DTC-DFCC 29:	32
[LO]_Lichtfunktion A 29:	[VO]_Rueckfahrlicht
[LO]_Lichtfunktion B 29:	[VO]_nicht aktiv
[LO]_Dimmwert AB 29:	127
[LO]_Lichtansteuerung HD AB 29:	[VO]_only_if_closed
[LO]_Lichtfunktion C 29:	[VO]_nicht aktiv
[LO]_Lichtfunktion D 29:	[VO]_nicht aktiv
[LO]_Dimmwert CD 29:	0
[LO]_Dimming Direction CD 29:	[VO]_maximize
[LO]_Lichtfunktion E 29:	[VO]_nicht aktiv ...   Coming Home oder Leaving Home aktiv
[LO]_Lichtfunktion F 29:	[VO]_nicht aktiv
[LO]_Dimmwert EF 29:	0                       ...   127
[LO]_Dimming Direction EF 29:	[VO]_maximize
[LO]_Lichtfunktion G 29:	[VO]_nicht aktiv
[LO]_Lichtfunktion H 29:	[VO]_nicht aktiv
[LO]_Dimmwert GH 29:	0
[LO]_Dimming Direction GH 29:	[VO]_maximize
https://www.youtube.com/watch?v=nqwYWAEjeyg
Golf 7.5 (MQB) Lane Change - Side Assist. From 5Q0 to 2Q0 radars. Easy way. OK!🥇
Previous info:
:arrow: viewtopic.php?p=592068#p592068
- Another way = Radar connectors facing outwards = Easy way.
✌ https://i.makeagif.com/media/7-21-2018/LdZOnD.gif :arrow: https://www.youtube.com/watch?v=-dyyQXQ ... kxc&t=129s 😲💗👌😁
- The correct VW way, with the radar connectors facing inwards. :arrow: https://www.drive2.ru/l/572027797371881067/
Old info:
5Q0 radars installation. :arrow: viewtopic.php?p=575988#p575988
2Q0 radars installation.
💎💎💎Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/iUPxBU4jY ... autoplay=1
I took advantage of the fact that I had the bumper guard removed to install one of those original GSM antennas and thus be able to compare the reception levels with respect to the original shark antenna with GSM + GPS that I installed on the roof.😊
Parameters.
Coding. 5Q0 + 2Q0.
Lane Change (BSD+RTA) 5Q0907686C.
VCP parameterization ...
VCDS
Gateway Inst List ... 3C enable
Check in adapt channels, SA 20103 , specified installations - Lane change assistance  ... coded
Coding:
ABS
Byte29 Bit7 ... enable
Instruments
Byte5 Bit3 ... enable
Byte11 Bit3 ... enable
Byte12 Bit6 ... enable
Park/Steer Assist
Byte3 Bit6 ... enable
Lane change  5q0 (long coding, Hex)
02011103 Master
020111   Slave
Adaptation:
5F
SA 20103
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,not activated ,60   ... activated
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,not activated ,60  ... activated
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,not activated ,64  ...activated
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Databus extended ,64
2Q0907686B same as before +:
A5 coding
[LO]_SWA:	[VO]_Not_coded ... coded
3C 2Q0 radars coding:
52A54640
We get a new menu. Brightness level.
Test. Brightness level + RCTA.
💎💎💎Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/6FCVsoUO0 ... autoplay=1
In the video you don't see the change in brightness level of the BSD LED lights, but in the real world you can really see it.
VCDS Autoscan.
Thursday,11,August,2022,13:15:31:32438
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: DB_03C_7100_2G0_MBX3_SK3260EUK0BA  OK!!! )))
Mileage: 47442km-29479mi   Repair Order: 2Q0 RADARS!
          A9 BB BC D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 47442km-29479miles
Readiness: 1110 0001
   Air quality sensor:
   Coding: 0F4DFD
   Coding: 00A8DD
   Alarm horn:
   Coding: 8271567841
   Coding: 333135
   Coding: 333135
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Generator:
   Coding: AE2B00
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H07 0150
   Serial number: 00000587514012
   Coding: 52A54640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15_002_VW27.rod
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H07 0150
   Serial number: 00000587481913
   Coding: 010000
   Coding: 931F0000
   Coding: 090000
   Serial number:
   Data carrier:
   Coding: 0000018811EEC028889F2C801030004400438000000000000000000000000000
Cannot be reached
Cannot be reached
End----------(Elapsed Time: 01:40, VBatt start/end: 12.7V/12.7V)-----------
Works like a charm!🧙‍♂️💎 https://www.youtube.com/watch?v=347pLSZLU7w
Although the 5Q0 radars worked fine, the 2Q0 radars work much better. Better detection of lateral traffic at all speeds and also more range for RCTA. They also communicate perfectly with the other units dedicated to driving assistance to support other functions (BSD "Plus" or Side Assist "Plus"👌 - with Lane Assist -).
Notes:👨‍🎓😊
- All datasets for 2Q0907686B can be downloaded from the VCP server, etc...
- I have tested many data sets of VW models, none works correctly for this way of installing the 2Q0 radars (with the connectors facing outwards), in the road tests you will have lateral ghosts... 👻, and RCTA no works.🤭 https://www.youtube.com/watch?v=3bZxnMzCtWw&t=44s
As far as I know, the 2Q0 radars of the new VW models are installed with the connectors facing inwards (or downwards?).
- I also tested the SK Kodiaq datasets, they work fine, but the radars fail to complete the automatic dynamic calibration, so they stop working and report that it is impossible to complete the dynamic calibration.
In my case, the perfect datasets for Golf 7.5 with 2Q0 radars are from the SK Karoq.💎👌 https://www.youtube.com/watch?v=LHRA6whwVLM
- The VCDS EXPerimental label does strange things, IMHO I think it should be reviewed (when coding a Bit it changes by itself the value in another Bit/s...?). I apologize in advance for the following, but it's one of those super funny pranks.🤣 (Ross-Tech 💖)
https://www.youtube.com/watch?v=DscBU8wVUpo
Golf 7.5 Battery Adaptation. ODIS SERVICE. Guided function.
For this original battery... VARTA AGM 68Ah 680A, my current battery, ...
... these are the adaptation values set from the factory (after reviewing multiple VW group vehicle diagnostic protocols):
-Rated battery capacity --> 68 Ah
-Battery technology --> Fleece
-Battery manufacturer --> JCB
-Battery adaptation-Battery Serial Number --> 1111111111
They can be configured in the adaptations of the Gateway with VCDS, VCP, ODIS E, etc... and can also be adapted with the ODIS S guided function .
Video with the ODIS S guided function :
💎💎💎Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/xpHxtv1Zu ... autoplay=1
(video made with captures in my test bench)
With ODIS E in the car it looks like this.
I have tested the various possible and correct combinations of the GW adaptation channels for the adaptation of this AGM battery, with all of them everything works perfectly.👍
I cannot conclude if the battery adaptation with the ODIS S guided function is better or worse than directly modifying the channels with VCDS, VCP, ODIS E, although I feel more confident with the ODIS S guided function... 🤷‍♂️😄
https://www.youtube.com/watch?v=2mVZvFZSCy4
Golf 7.5 Rear door control units/modules 'Cannot be reached'. SOLVED!🧙‍♂️
Previous info:
- :arrow: viewtopic.php?p=591647#p591647
- :arrow: viewtopic.php?p=591740#p591740
- :arrow: viewtopic.php?p=592150#p592150
With ODIS E and through Bus Master Coding of the front door control units 42 and 52, the non-existent rear door control units disappear from the diagnoses.🎉
The same with the front passenger door control unit.
VCDS Autoscan.
Tuesday,23,August,2022,09:24:55:32438
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: CODING BUS MASTER RDCM OUT OK!
Mileage: 47549km-29545mi   Repair Order:
          A9 D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 47549km-29545miles
   Air quality sensor:
   Coding: 0F4DFD
   Coding: 00A8DD
   Alarm horn:
   Coding: 8271567841
   Coding: 333135
   Coding: 333135
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Generator:
   Coding: AE2B00
   Coding: 52A54640
   Coding: 010000
   Coding: 931F0000
   Component: FCM MQB Low   003 0370
   Coding: 090000
   Serial number:
   Data carrier:
End----------(Elapsed Time: 01:39, VBatt start/end: 12.8V/12.7V)-----------
Notes: :lol:
- I tried the Bus Master Coding of the front doors control modules immediately after my changes/flashes without success.
Therefore, an interval of space-time is necessary for it to be successful.
- I do not know the space-time interval in which the Bus Master Coding can be successfully carried out on the front door control units so that the non-existent rear door control units disappear from the diagnostics.
Perhaps some conclusion of the 'maximum interval' can be drawn from the dates of posting, or included in the posts, from the previous information, but it would be quite imprecise.🤭
Update (12/12/2022):
I didn't want to reveal the secret at first to avoid some parasites... 🍊🐛
It is not necessary to wait for anything, it is done directly with positive and immediate results.
Please follow the following order scrupulously.
- First - 'Automatically' coding the Coding Bus Master of the 'GW'.
- Second - Immediately afterwards, 'Automatically' coding the Coding Bus Master of the door modules. You may have to restart ODIS E - exit/open again - for each door module.
It can be done on the test bench or directly in the car.
Good luck!
https://www.youtube.com/watch?v=jIIrky6eMMk&t=171s
Tests - info:
This data set for 2Q0 radars with the connectors installed facing outward also works correctly.
https://www.youtube.com/watch?v=8p4lYNCJvAM&t=203s
Firmware 0371 (E) for FCM also works fine for 8IU Matrix LED headlights.
I have them under observation in long-term tests.
Thursday,25,August,2022,17:29:36:32438
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: 3C DS SKKX6 OK! , 4B SW 0371 OK!
Mileage: 47610km-29583mi   Repair Order:
          A9 D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 47610km-29583miles
Readiness: 0000 0000
   Air quality sensor:
   Coding: 0F4DFD
   Coding: 00A8DD
   Alarm horn:
   Coding: 8271567841
   Coding: 333135
   Coding: 333135
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Generator:
   Coding: AE2B00
   Coding: 52A54640
   Coding: 010000
   Coding: 931F0000
   Coding: 090000
   Serial number:
   Data carrier:
End----------(Elapsed Time: 01:39, VBatt start/end: 12.5V/12.5V)-----------
https://www.youtube.com/clip/UgkxcRi5xM ... EJFrgXouwD :arrow: https://www.youtube.com/watch?v=EfEoLHT2wAw
I bet with you what you want that my/this thread will always try to be the first in this section of the forum providing information. What do you think?... ah sorry, in my/this thread you can't comment, have fascist attitudes or generate false black legends typical of people with low IQ. 🤭
https://youtube.com/clip/UgkxJi8IVpJjwX ... tlw5RYUHZ2
Locked
